E46 (1999 - 2006)
Old 10-10-2008, 08:18 AM
Techniek Techniek is offline
Mein Auto: 330i SP
Cool cross-drilled or slotted Brembos?
Need to change front rotors on my 03 330i. Does anyone know which are the best value and quality? Also, I'm unsure about the difference between cross-drilled and slotted types. Will consider all the advice on brakes. Thanx
Old 10-10-2008, 08:23 AM
desertrat desertrat is offline
Mein Auto: non-BMW
Depends on what you plan on using your car for. For normal street use I would say neither, just use the stock Brembo replacement rotors. I assume you are using stock rotors now, if so are you experiencing any brake fade or other problems you think might be solved by drilled or slotted rotors?
Old 10-10-2008, 08:31 AM
Mein Auto: 330i SP
mostly highway. no other problems except the usual symptoms--slight vibration felt on the steering wheel when brakes applied, as well as uneven surface and rust on the rotors.
Old 10-10-2008, 08:32 AM
Fast Bob's Avatar
Keeping it surreal
Drilled & slotted look cool, but are totally unnecessary for street driving....
Old 10-10-2008, 08:33 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
I recommend Brembo or Zimmerman "blanks". Bang for the buck, they are at least twice as good as slotted or cross-drilled.
Old 10-10-2008, 08:58 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Obviously we have talked this topic to death, but I am wondering why you say stock blanks they are twice as good. I know drilled aren't "better", but I figured them to be as good as non-drilled/slotted. I want some on my next set for eye candy.....now I am re-thinking. Please give me some more feedback....
Old 10-10-2008, 09:15 AM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
I didn't say they were twice as good.
I said they were twice as good bang for the buck. If slotted/drilled are only just as good performance wise but cost twice as much... then the blanks are therefore twice as good, bang for the buck.
Old 10-10-2008, 09:24 AM
smolck's Avatar
ROLL TIDE!
So it was a trick question....the cheap ebay one's aren't twice as expensive, even if they blow up a little....
I get your logic now, thanks!
brakes, brembo, cross-drilled, rotors, slotted
