Old 10-14-2008, 05:51 PM
bl335i08's Avatar
bl335i08 bl335i08 is offline
Where do we go from here?
Mein Auto: '08 E90 335i
Engine Warm-up time
This is my first bimmer and I'm not too familiar with it. My previous Hondas and Toyotas usually took a mile or so to reach normal engine operating temp. or the needle said so anyway. The 335i on the other hand takes at least 3 miles or something for the needle budge any at all. Is this true with your bimmers too? Caveat: I have not changed my route to work.
Who is John Galt?
Old 10-14-2008, 06:29 PM
AzNMpower32's Avatar
Tar Heel Faithful
Your previous Hondas and Toyotas, and most non-performance cars, have a coolant temperature gauge. This warms up significantly faster than the motor oil temperature, which is what is displayed in your 335i.
Old 10-14-2008, 06:56 PM
TheCritic's Avatar
TheCritic TheCritic is offline
Mein Auto: 2007 BMW X3
The manual for my X3 says specifically not to idle to let the motor warm up. What's the reasoning?
Old 10-14-2008, 07:19 PM
vadim's Avatar
vadim vadim is offline
Mein Auto: '08 E92 335i MT
Idling is not the most efficient way to warm up the engine. Nor is it environment-friendly. The best way is to get going applying light load, i.e. no flooring until the engine reaches its nominal temperature.
vadim
'2008 E92 335i MT / Space Gray / Coral Red / Aluminum / ZSP / ZPP / iPod+USB / Heated seats
'2011 X5 35d
Old 10-14-2008, 07:39 PM
Tar Heel Faithful
The above posts are true, but since the OP states it takes 3mi for the oil temp to budge, we can assume that he/she is driving said vehicle.
I suggest giving the motor 10-15secs on a cold start to settle down, but I would not exceed 40s of just "sitting" because it puts a load on the catalytic converter and is otherwise harmful.
Old 10-14-2008, 07:44 PM
AndrewZ's Avatar
AndrewZ AndrewZ is offline
Super Moderator
Mein Auto: 91 E30
Would that be for all vehicles?
I let my e46 get to just above the blue in the temp gauge, which is usually within a minute of starting.
Old 10-14-2008, 07:51 PM
bl335i08's Avatar
the motor oil temperature, which is what is displayed in your 335i.[/QUOTE]
Thank you for clarifying that for me. Didn't even consider that. So, does yours take that long to get to 200?
Who is John Galt?
Old 10-15-2008, 09:39 AM
desertdriver desertdriver is offline
Mein Auto: 335i sedan, sport paddles
The warm up time will depend on ambient temperature. When it is cold out it will take longer. It will also depend on how long it has been since youve driven your car. I believe that BMW states that you should not apply full throttle until at least 170F(?) or so. Coolant temp is not a good indicator of engine warmup, so I doubt your hondas were really warmed up. the 335i has a oil temp gage and this is the safe way to interpret warmup. I am a little more conservative and will not redline my car until 200F is reached.
Old 10-15-2008, 09:49 AM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
Here is my protocol: Start the car and let the engine run with the car parked until the engine idle drops down to the 800 rpm territory. Then drive slowly for about 1 - 2 miles. After the 1 - 2 mile point, normal driving. The initial high revs are programmed in to get the catalyst up to operating temperature as quickly as practical; so I let the catalyst get happy and then driving slowly for the 1 - 2 miles gets the rest of the engine 'warmed up'.
Old 10-15-2008, 09:56 AM
jxr209 jxr209 is offline
Mein Auto: 4runner
I have heard of engine heaters that can plug into your garage outlets. Do they make one for this car?
[/SIGPIC]
2007 E90 335i >Black Sapphire, terra/walnut, paddles, sport, prem, cold, ipod, CA
Old 10-15-2008, 11:47 AM
imoksoami imoksoami is offline
Jim
Mein Auto: '08 335i Coupe
Originally Posted by desertdriver View Post
the warm up time will depend on ambient temperature. When it is cold out it will take longer. It will also depend on how long it has been since youve driven your car. I believe that bmw states that you should not apply full throttle until at least 170f(?) or so. Coolant temp is not a good indicator of engine warmup, so i doubt your hondas were really warmed up. The 335i has a oil temp gage and this is the safe way to interpret warmup. I am a little more conservative and will not redline my car until 200f is reached.
+1
'08 335i Coupe - Sparkling Graphite Metallic/Cream Beige Dakota Leather / Sport Pkg / Premium Pkg / Comfort Pkg / Cold Weather Pkg
Old 10-15-2008, 12:57 PM
franka franka is offline
Mein Auto: E39 540i Sport
I would like to see the exact wording in the manual.
Frank
540/6
540, Dirrezas (4) @ 275/35-18 ea, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 10-15-2008, 12:59 PM
There are block heaters and oil heaters and blanket heaters to put your battery on. They are generic. They are generally 110V.
For the block you knock out a water jacket plug and insert a heating coil into the water jacket. Oil heaters are a straight heating element and go in via the dip stick tube.
There are many kinds. I used two in a car I had when I lived in Alaska. They worked great.
Frank
540/6
Old 10-15-2008, 01:03 PM
Oil temp really? Are you sure? Its strange that a mfgr would show oil temperature and at the same time not show water temp. Unless it is related to the turbos
Frank
540/6
Old 10-15-2008, 01:10 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A-220K-traded
"Unconventional" is a much more friendly word than "strange." These are BMWs we are talking about here.
Old 10-15-2008, 01:12 PM
OK unconventional.
Frank
540/6
Old 10-15-2008, 01:20 PM
philippek philippek is offline
Proud S ponsor
Mein Auto: Z4 M Cpe, Miata, X6 50i
I can't attach the entire manual as the pdf is too big, but you can see it here:
http://www.bmwusa.com/Standard/Content/Owner/dgh.aspx
On page 37 it states:
Originally Posted by 2007 BMW X3 Owner's Manual
Do not allow the engine to warm up while parked; instead, start driving immediately at a moderate engine speed
Old 10-15-2008, 01:23 PM
That is pretty clear. Thanks
Frank
540/6
Old 10-15-2008, 01:30 PM
the most critical apsect of warmup is the oil temp. this is because oil viscosity changes with oil temp. When the oil is cool, it does not lubricate your engine properly(its too thick), especially if you run it hard. BMW's use of the oil temp guidelines will help your car last longer by preventing you from running your engine hard under substandard lubrication conditions. With an engine that has such close tolerances(any finely engineered powerplant), the oil must come up to a sufficient temperature so it is not too thick to lubricate properly. Kudos to BMW for using a better way to help you take care of your car. If you ignore their recommendations, the risk is higher engine wear and shorter engine life. If you live in temps near freezing, it can take 20 mins or more to warm up your engine to the optimal operating temperature needed to run it hard if left out overnight.
Old 10-15-2008, 01:55 PM
raleedy's Avatar
raleedy raleedy is offline
Mein Auto: 2016 228i 6-speed
All of that palaver might be true if it were actually "oil" we were talking about, but BMW engines are not lubricated with "oil". The lubricant is not especially viscous when cold. Moreover, cold engine parts are smaller than warm ones. As a result, there's no special thing about low operating temperatures that would inhibit lubrication of engine parts, and the engine will accept normal operating loads when cold without damage. The oil temperature gauge does not help with this because its cold peg is at 160 degrees -- the internal temperature of well-done meat. If the gauge serves any useful purpose, it is to flag high operating temperatures, which are detrimental to both the lubricant and the metal engine parts.
Old 10-15-2008, 02:11 PM
oranje335i oranje335i is offline
Snap je?
Mein Auto: 2008 335i
Help me out here. Jello? Peanut butter?
Please. You're talking about the molecular level.
desertdriver did not issue a 'palaver'; he was simply providing reasonable advice. No need to go 'high and mighty'.
Daily Driver - 2008 335i, Dinan Stage 1
Apex Practice - 2013 Boxster S
Retired 2001 Audi S4
Deceased 1993 Mitsubishi Eclipse - Rest in Pieces
Old 10-15-2008, 03:23 PM
Dont confuse yourself with the synthetic vs petroleum oil arguements. Its all about hydrocarbon chain length and its relation to temperature dependent viscosity. All synthetic oils are hydrocarbons, just like petroleum based oils, they just have different polydispersity(better in synthetics). Think like a scientist not a lawyer. Molecular physics is molecualr physics, whether you pull the molecules out of the ground or synthesize them in a lab or plant the behaviors are consistent. the greater polydispersity of the mineral oils make them a bit better at lower temps.
Here is an article that compares the two if you care to read it. The (petroleum based)mineral oils actually lubricate better at low temps(thicker film before parts expand). this means that its even more important for synthetics to warm them up. Yeah, I used to be a metallurgist, so I know about expanding metals.
http://www.machinerylubrication.com/...?articleid=586
Old 10-15-2008, 03:33 PM
Jim
Well then you should be very comfortable running WOT when cold, have at it.
Old 10-15-2008, 06:23 PM
BerkleyBMW's Avatar
BerkleyBMW BerkleyBMW is offline
Can't control my fingers
Mein Auto: .
Just what I was going to say.
Old 10-15-2008, 06:35 PM
Tar Heel Faithful
Since the E46 and X3 are essentially the same (we also have a buffered coolant temp gauge), I suggest you do the same. I actually do this with all cars. I think its a reasonable time for the engine to settle, without letting it idle needlessly.
