Rear Main Seal?
OK, can someone please tell me why after only ten thousand miles and just a little over two years is my rear main seal gone bad again. The first time I had it fixed was from the dealership in Sterling VA under CPO..... So I called the dealer to see if it was still under warranty and of course they said the warranty for that is for only two years. Of course ten months short, A day late and a dollar short!!!! The part that frustrates
me the most is that after I finally get my suspension problems worked out this happens. I feel like sometime I just can't catch a break with this car. You fix one thing and "BAM" something else breaks. OK enough complaining... do anyone know why this is?Thanks Mike
2000 Titanium Silver, Six speed, Sports Mods: CDV Delete, M5 Rear Sway Bar, M5 Grill, M5 trunk spoiler, M5 Mirrors, Hella Angle Eyes, Clear Side Markers, MZ3 SSK, Hella Celis Brake Lights, MKIV upgrade, Wide Screen Nav Display, 19" Moven S5R Wheels, ACS Pedals, iPod Icelink, Eisenmann Race Exhaust, M-Tech Rear Bumper, Umnitza Predator ICE, M Steering Wheel, Z4 shift knob. Last edited by BMW5MT; 10-20-2008 at 04:58 AM. |
Are you sure it the rear main? That is not a common failure point on that engine. Who diagnosed it and how?
chiefwej 2003 540i ///m-tech 6-speed Black Sapphire Metallic w/gray
2000 Titanium Silver, Six speed, Sports Mods: CDV Delete, M5 Rear Sway Bar, M5 Grill, M5 trunk spoiler, M5 Mirrors, Hella Angle Eyes, Clear Side Markers, MZ3 SSK, Hella Celis Brake Lights, MKIV upgrade, Wide Screen Nav Display, 19" Moven S5R Wheels, ACS Pedals, iPod Icelink, Eisenmann Race Exhaust, M-Tech Rear Bumper, Umnitza Predator ICE, M Steering Wheel, Z4 shift knob. |
Where is the rear main seal? I have a leak after changing my valve cover gaskets and I'm pretty sure it's not the gaskets?
![]() 2000 BMW 540i 1998 Audi A6 Quattro |
Behind the flywheel/flexplate on the block.
IS it hard to change out? Would I need to take it into a shop??
IF it is my rear main seal, is it easy to tell if that's whats leaking?
If you see oil leaking from the bottom of your bellhousing, there is a good chance the rear main is leaking.
my rear main is leaking too. but i think most of the leak is from the oil pan gasket
2007 E60 530i - Current 2002 E39 530i - RIP ![]() BMWCCA MEMBER #397411 |
'91 SpecE30 #523 '03 540i/6 M-Sport '00 Ford F-350 Dually Tow Vehicle BMWCCA #360858 NASA # 128290 My Track Schedule |
The red arrow points to the bellhousing.
I'm trying to rap my head around how something like a seal that last for 10K miles and over two years wasn't installed correctly.
I would think if it wasn't installed correctly after the initial install, you would very soon after get a leaknot two years later.
Correct diagnosis is they key. How many miles in your car?
In my 1983 E23 735i 5spd, the Rear Main Seal leaks at 130K, the FRONT Man Trans Seal leaked at 140K miles. I suspect you have man trans oil seals leak. Wipe the whole area dry, drive a short while and look again. The problem is: the engine oil and man trans oils look very similar and almost impossible to tell the difference. (In contrast, if one has an AUTO trans, then the auto trans fluid usually has a red dye that can tell you it is ATF). Google for "engine oil dye", I think there is a dye you can put in engine oil to trace leaks. The dealer should have changed ALL 4 seals in the man trans when it was removed from the car for the RMS leak. |
Are you losing oil or trans fluid? Checking both would be a good idea.
I have about 86K miles on my car. The fluid thats leaking don't smells like transmission fluid. To me it smells like regular oil.
OK let me ask this question! If my car is leaking fluids from the bell housing when the engine is just running wouldn't that be the RMS because that seal is on the engine side? That is what my car is doing. I would think that the only time I would see that the Man Trans Seal would be leaking is if I had the car in gear and driving the car with the transmission turning right. Wouldn't that be the seal on the transmission side? I will also take some pictures inside the bell housing through the plug holes.
The hole at the bottom of the bell housing drains any fluid that gets inside:
- leaking RMS - Leaking slave cylinder - leaking FRONT INPUT shaft seal of the man transmission. Research on tracing dye, easy to do. |
Can automatic tranny fluid get in there and leak from that hole?
It's possible. The input shaft seal could leak and ATF could run out of the bellhousing. What does the fluid look/smell like?
I didn't have time to investigate today, maybe tomorrow but I think it might be ATF...of course oil and new ATF mixed with old dark ATF look the same.
If it's ATF, could my overfilling be causing this leak? and If so, will a 2nd drain/refill at temp fix the leak?
Yes and yes. Clean the area, then put some paper towel or other white paper under the car. Check later for stains, auto trans fluid should be red.
But thanks for that response, i'll monitor the situation and if it keeps up I"ll definitely do another drain/refill.
#25
This thread points to the necessity of good mechanic fore-sight: whenever the transmission is removed from the car for whatever reaons, take care of all the seals (even they are not leaking) because of the labor costs (seals are cheap but labor of removing trans very expensive).
1. Clutch Job: do the clutch but a good mechanic will ALSO replace: - Engine's RMS - Man Trans seals x4 (Auto Trans seals x3) 2. Changing transmission, same deal as #1. 3. Replacing RMS, same deal as #1. Last edited by cn90; 10-20-2008 at 07:16 AM. |
