Old 10-18-2008, 02:18 PM
BMW5MT's Avatar
BMW5MT BMW5MT is offline
Mein Auto: Silver 00' 540i 6 Speed
Rear Main Seal?
OK, can someone please tell me why after only ten thousand miles and just a little over two years is my rear main seal gone bad again. The first time I had it fixed was from the dealership in Sterling VA under CPO..... So I called the dealer to see if it was still under warranty and of course they said the warranty for that is for only two years. Of course ten months short, A day late and a dollar short!!!! The part that frustrates me the most is that after I finally get my suspension problems worked out this happens. I feel like sometime I just can't catch a break with this car. You fix one thing and "BAM" something else breaks. OK enough complaining... do anyone know why this is?
Mike
2000 Titanium Silver, Six speed, Sports
Mods:
CDV Delete, M5 Rear Sway Bar, M5 Grill, M5 trunk spoiler, M5 Mirrors, Hella Angle Eyes, Clear Side Markers, MZ3 SSK, Hella Celis Brake Lights, MKIV upgrade, Wide Screen Nav Display, 19" Moven S5R Wheels, ACS Pedals, iPod Icelink, Eisenmann Race Exhaust, M-Tech Rear Bumper, Umnitza Predator ICE, M Steering Wheel, Z4 shift knob.
Old 10-18-2008, 02:24 PM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
Are you sure it the rear main? That is not a common failure point on that engine. Who diagnosed it and how?
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 10-18-2008, 02:36 PM
BMW5MT's Avatar
Actually, I looked at it myself. The last time I had the rear main seal go bad I took the bell housing plugs out and you can see where the oil is leaking. This time what I'm also seeing again by looking up in the holes in front of the fly wheel is oil coming from the front of it.
Mods:
Old 10-18-2008, 05:40 PM
Al's540i's Avatar
Al's540i Al's540i is offline
Mein Auto: 2000 BMW 540i
Where is the rear main seal? I have a leak after changing my valve cover gaskets and I'm pretty sure it's not the gaskets?
2000 BMW 540i
2010 Mercedes ML350
1998 Audi A6 Quattro (Sold)
Old 10-18-2008, 05:48 PM
Ryan M's Avatar
Ryan M Ryan M is offline
Go Army!!!!!
Mein Auto: 1998 540i/6
Behind the flywheel/flexplate on the block.
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 10-18-2008, 05:58 PM
Al's540i's Avatar
IS it hard to change out? Would I need to take it into a shop??
IF it is my rear main seal, is it easy to tell if that's whats leaking?
2000 BMW 540i
2010 Mercedes ML350
Old 10-18-2008, 06:05 PM
Ryan M's Avatar
Go Army!!!!!
Well, it's behind the flywheel, so you'd have to remove the transmission, pressure plate, clutch disk, flywheel, and finally the seal. It's a lot of work. If you don't have a lift or don't feel 110% confident in your abilities or experience, it's a job best left to the pros. You also need a few special tools for the job.
If you see oil leaking from the bottom of your bellhousing, there is a good chance the rear main is leaking.
Old 10-18-2008, 06:09 PM
Al's540i's Avatar
IS the bell housing what sits in front of the transmission...or is that the torque converter?
2000 BMW 540i
2010 Mercedes ML350
Old 10-18-2008, 07:02 PM
razzy530's Avatar
razzy530 razzy530 is offline
Send a message via Yahoo to razzy530
Mein Auto: 2007 530i 6 Speed
my rear main is leaking too. but i think most of the leak is from the oil pan gasket
2007 E60 530i - Current
2002 E39 530i - RIP
BMWCCA MEMBER #397411
Old 10-18-2008, 07:08 PM
BMW5MT's Avatar
Mike
Mods:
Old 10-18-2008, 07:09 PM
kishg's Avatar
kishg kishg is offline
E30 Maniac
Send a message via Skype™ to kishg
Mein Auto: too many bmws
most likely because the install was not done right..
'91 SpecE30 #523
'03 540i/6 M-Sport
'00 Ford F-350 Dually Tow Vehicle
BMWCCA #360858 NASA #
128290
My Track Schedule
Old 10-18-2008, 07:12 PM
Ryan M's Avatar
Go Army!!!!!
The bellhousing is what houses the flexplate and torque converter in an auto, and houses the flywheel, clutch, pressure plate, and throwout bearing in a manual trans. It is connected to the tranny and bolts directly to the block.
The red arrow points to the bellhousing.
Old 10-18-2008, 07:32 PM
BMW5MT's Avatar
I'm trying to rap my head around how something like a seal that last for 10K miles and over two years wasn't installed correctly. I would think if it wasn't installed correctly after the initial install, you would very soon after get a leak
not two years later.
Mods:
Old 10-18-2008, 07:41 PM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
Correct diagnosis is they key. How many miles in your car?
In my 1983 E23 735i 5spd, the Rear Main Seal leaks at 130K, the FRONT Man Trans Seal leaked at 140K miles.
I suspect you have man trans oil seals leak.
Wipe the whole area dry, drive a short while and look again. The problem is: the engine oil and man trans oils look very similar and almost impossible to tell the difference.
(In contrast, if one has an AUTO trans, then the auto trans fluid usually has a red dye that can tell you it is ATF).
Google for "engine oil dye", I think there is a dye you can put in engine oil to trace leaks.
The dealer should have changed ALL 4 seals in the man trans when it was removed from the car for the RMS leak.
Old 10-18-2008, 07:44 PM
Ryan M's Avatar
Go Army!!!!!
Are you losing oil or trans fluid? Checking both would be a good idea.
Old 10-18-2008, 08:07 PM
BMW5MT's Avatar
I have about 86K miles on my car. The fluid thats leaking don't smells like transmission fluid. To me it smells like regular oil.
OK let me ask this question! If my car is leaking fluids from the bell housing when the engine is just running wouldn't that be the RMS because that seal is on the engine side? That is what my car is doing. I would think that the only time I would see that the Man Trans Seal would be leaking is if I had the car in gear and driving the car with the transmission turning right. Wouldn't that be the seal on the transmission side?
I will also take some pictures inside the bell housing through the plug holes.
Mods:
Old 10-19-2008, 08:46 AM
The hole at the bottom of the bell housing drains any fluid that gets inside:
- leaking RMS
- Leaking slave cylinder
- leaking FRONT INPUT shaft seal of the man transmission.
Research on tracing dye, easy to do.
Old 10-19-2008, 08:52 PM
Al's540i's Avatar
- leaking RMS
Can automatic tranny fluid get in there and leak from that hole?
2000 BMW 540i
2010 Mercedes ML350
Old 10-19-2008, 08:55 PM
Ryan M's Avatar
Go Army!!!!!
It's possible. The input shaft seal could leak and ATF could run out of the bellhousing. What does the fluid look/smell like?
Old 10-19-2008, 09:06 PM
Al's540i's Avatar
Well, the reason i ask is because I drained/refilled my tranny yesterday but when I was draining, I wasn't draining at temp so I think i may have overfilled the tranny. Now I have a leak there. I alwasy had hanging drops there that never actually dropped to the floor but now I have several drips from that area.
I didn't have time to investigate today, maybe tomorrow but I think it might be ATF...of course oil and new ATF mixed with old dark ATF look the same.
2000 BMW 540i
2010 Mercedes ML350
Old 10-19-2008, 09:09 PM
Ryan M's Avatar
Go Army!!!!!
If you can, wipe the area clean with some type of solvent and a rag. Then, check the area again after some time, and you should get a good reading of what color the fluid is.
Old 10-19-2008, 09:13 PM
Al's540i's Avatar
If it's ATF, could my overfilling be causing this leak? and If so, will a 2nd drain/refill at temp fix the leak?
2000 BMW 540i
2010 Mercedes ML350
Old 10-19-2008, 09:25 PM
chiefwej's Avatar
Freude am Fahren
Yes and yes. Clean the area, then put some paper towel or other white paper under the car. Check later for stains, auto trans fluid should be red.
Old 10-20-2008, 03:52 AM
Al's540i's Avatar
While I agree with this statement on other vehicles, BMW OEM ATF is a light brown color...kinda like the color of a light beer. That's why many times it's hard to distinguish between used ATF mixed with new and oil.
But thanks for that response, i'll monitor the situation and if it keeps up I"ll definitely do another drain/refill.
2000 BMW 540i
2010 Mercedes ML350
Old 10-20-2008, 07:10 AM
This thread points to the necessity of good mechanic fore-sight: whenever the transmission is removed from the car for whatever reaons, take care of all the seals (even they are not leaking) because of the labor costs (seals are cheap but labor of removing trans very expensive).
1. Clutch Job: do the clutch but a good mechanic will ALSO replace:
- Engine's RMS
- Man Trans seals x4
(Auto Trans seals x3)
2. Changing transmission, same deal as #1.
3. Replacing RMS, same deal as #1.
