1978 320 with a shimmy. - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series > E21 (1975 - 1983)
E21 (1975 - 1983)
Old 11-06-2008, 03:25 PM
7kman 7kman is offline
Mein Auto: 1978 320i
What is causing this and how do I fix it?
Old 11-06-2008, 03:28 PM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
Considering the car is 30 years old, what have you done already?
Generally the Control arms, brakes, wheel bearings, tie rods, shocks and anything I havent mentioned are pretty worn.
Put some effort into your question.
Old 11-06-2008, 04:28 PM
New rotors, new control arms, upgraded to 1983 steering rack with new bushings, and new steering shaft. I am also getting a rattle into the steering column whenever the front wheels hit a bump.
I may go back to the 78 rack and rebuild it with a new damper. Is there an easier fix?
Old 11-07-2008, 06:47 AM
Banned
Mein Auto:
There is a guibo in the stearing linkage. Id think of that with a stearing column shake, or a mounting bolt is loose somewhere.
Old 11-08-2008, 02:20 PM
geraldgj geraldgj is offline
Mein Auto: 1982 320is
I have just replaced my lower control amrs and the took care of my shimmy.
Old 11-13-2008, 04:39 PM
Thanks for the input, I am going to remove the steering column and look for guibos, and replace my control arm and sway bar bushings.
Old 11-15-2008, 10:15 PM
PBC///2.7 PBC///2.7 is offline
Mr.Evil...E30
Mein Auto: 87 E30
how are your rims???
