Old 11-08-2008, 10:07 AM
540i2003 540i2003 is offline
Mein Auto: 540 Dinan
Check lowbeam lights problem
I have a 2003 540 with Xenon low beams. Intermittently (2-4 times a month) I get the following message when I start the car "CHECK LOWBEAM LIGHTS." I step out of the car and sure enough the driver side Xenon is out. If I turn the car off and then back on again the light comes on and everything is fine. My local dealer suggested changing the bulb which we did. It looked to him like it was close to failure but that has not solved the problem. I did get to spend about $250 on the bulb though which was nice.
Has anyone else experienced this and / or does anyone have any suggestions for what might be happening? It's not the bulb ;-)
Old 11-08-2008, 11:02 AM
chewyz_me's Avatar
chewyz_me chewyz_me is offline
Send a message via AIM to chewyz_me
Mein Auto: '83 BMW 633CSi '98 540i
try disconnecting the headlights and cleaning the connectors and replacing the fuse.
my cars:
'83 633CSi [RIP/sold]
'98 540i
Old 11-08-2008, 01:19 PM
skydryice's Avatar
skydryice skydryice is offline
Farewell
Send a message via AIM to skydryice Send a message via MSN to skydryice
Mein Auto: CBR954RR
Check the wiring for the Xenon. ensure all connections are solid and good. try to move the wires around and see if you can make the light go off. That way you can find the problem, if it is a connection issue.
Sky
Hushpower II, Stoptech BBK, UUC V12 Clutch Conversion, UUC LTW Flywheel, UUC 9-Button Clutch, Eibach Sways, CF hood, Zionsville HD conversion
UUC EVO3 SSK w/ DSSR, UUC Clutch Stop, DICE, 2point5, Eibach Pro Coilovers, High Flow Cats, Simulated O2
Old 11-08-2008, 01:28 PM
sc 540i's Avatar
sc 540i sc 540i is offline
Mein Auto: 540/6 Sport
If none of the above solve the problem it could be a early sign that your LCM ( light control module) is on its way out, but I doubt that, i've had the same symptoms as you before and they unexplicably went away.
Old 11-08-2008, 02:36 PM
Thanks. Ill try these. Makes sense. I've been a little reluctant to mess with the wiring given al the high voltage warning labels but I think I have a pair of insulated gloves I can use. SC540i, you said the problem just went away. How long did it linger?
Old 11-08-2008, 02:49 PM
sc 540i's Avatar
It lingered for approximately 2 months, ocassionally the hazard lights would flash on their own too, but that's all gone away. It's most likely a loose connection though, let us know what happens.
Old 11-10-2008, 03:35 AM
Mine does the same so please keep me in the loop.
Old 11-10-2008, 08:04 AM
mattmartindrift mattmartindrift is offline
Mein Auto: E39 540i; '89 240sx race
Originally Posted by 540i2003 View Post
I have a 2003 540 with Xenon low beams. Intermittently (2-4 I did get to spend about $250 on the bulb though which was nice.
ouch, that bulb shouldn't be that much!
sylvania has an OEM reference and they should only run $30-50 a piece.
Old 11-10-2008, 09:25 AM
dannyc9997's Avatar
dannyc9997 dannyc9997 is offline
Send a message via AIM to dannyc9997
Mein Auto: 540i
you paid how much for the bulb?? Did you add that 0 by accident?
Old 11-10-2008, 07:31 PM
Xenon bulbs (Installed) are a lot at the dealership. I'll get a credit for some of it since it wasn't the issue.
I purchased an electronic contacts cleaner and sprayed the connectors at the LCM. They were dirty. I think they got soaked last year when the radiator / expansion tank failed (as expected) at about 50K. We'll see if that works.
Old 11-15-2008, 06:25 PM
Well it does not appear to be the contacts at least not after cleaning them. They still may be bad. I may need change the physical connector. If it's not tat I think I am looking at the LCM.
Old 11-16-2008, 01:49 PM
nicky l nicky l is offline
Mein Auto: 540i auto
my car had this problem. thought it was the bulb to but turned out it was the controller. cost me 200 for a new one!! thats about 360 dollars i think!!
Old 10-27-2011, 10:55 AM
jcgabe2007 jcgabe2007 is offline
Mein Auto: X5
Low Beam lights on -- X5 2006
Just purchased a 2006 X5 and I start the vehicle and "check low beam lights on" pops up...any suggestions/advice would be appreciated. Thank you!
Old 10-27-2011, 11:13 AM
BentValve's Avatar
BentValve BentValve is offline
Mein Auto: 00 528i 3 pedals
Your HID ballast. Mine does it too. You dont have to restart the car, just turn the lights off and back on. You may have to do it a couple of times for the ballast to fire.
Old 09-14-2012, 05:23 AM
Randy Seman Randy Seman is offline
Mein Auto: 540i Sport Wagon
Whatever became the result of this? I am having the same issue with my 540i Sport Wagon (2003). Thanks.
Old 06-29-2015, 04:13 PM
coreyz coreyz is offline
Mein Auto: 2006 BMW x5
Same problem
Anyone have any luck getting this fixed? I just picked up a 2006 x5 that has this same issue after 2 months. "Check low beam lights" shows on the dash and then my passanger side low beam doesnt work. But its inconsistent. Sometimes it works and other times it doesnt.
Any suggestions?
Old 04-15-2016, 05:40 AM
dzajic dzajic is offline
Mein Auto: 2007 328i
I also have the same issue, "check lowbeam lights" message on dash, and both low beam (halogen) headlights are not working. After researching the issue online, seems like it could be wiring, or maybe a lamp control module issue. Anyone have any suggestions on how to diagnose? I suppose it could be the bulbs, but seems unlikely for both to go out at the exact same time.
Old 04-15-2016, 05:41 AM
"check low beam lights" message, both low beams not working
Old 04-15-2016, 07:01 AM
Sroor9001 Sroor9001 is offline
ALGhoul
Mein Auto: Bmw 525i 2002
For me it was angle eye problem it was wiring was loose just pressed it and all fine
Old 04-15-2016, 07:16 AM
It was the bulbs. (facepalm) Always assume the simplest explanation.
Old 04-15-2016, 07:18 AM
QSilver7's Avatar
Since you have halogen headlights (not the HID xenon headlights that most are discussing here)...I suggest checking if you need new bulbs. You didn't mention if you've actually looked at the bulbs yet.
If the bulbs were manufactured around the same time, installed at the same time...they've been burning at the same time...so its not that uncommon for both to fail around the same time.
You can easily remove the halogen bulb to see if it is burnt out. Do a visual check to see if the filament is burnt or disconnected...or shake it...if you hear rattle...it's a goner.
Q {BMW CCA Member #191509}
(SOLD)
Old 04-15-2016, 08:49 AM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
or just hook a multimeter across the bulb out of the car in ohms mode...infinite or OL reading, the bulb is shot, low resistance its ok.
99 528i 5sp sport
