Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
zhp dropped me SES / 2240 OBDII code
BMW 330i ZHP / code 2240 OBDII
my car dropped me a SES. only one code posted as 2240 -O2 sensor positive current circuit/open Bank 2 sensor 1 so with some looking it appears to be the pre-cat O2 getting stupid at only 52K miles. so the question is: is replacing this O2 sensor the solution? what are the other things that could force the ECU to pass this code? intake, coil, injectors? my symptoms are what feels like misfiring...or stumbling upon accelerartion in 3-6th gears- its a slight stuttering that appears to quiet down or disappear with reduced(minimal) throttle input. I replaced the plugs yesterday just as a maintainance move but without effect either on the situation. should i just replace the noted O2 sensor or both pre-cats ? then review the situation again......then look at ignition coils...or what ? thanks |
This sounds very familiar, like a thread may have been posted recently with a similar situation. Search the forum and see what you come up with.
It's unlikely the O2 sensor is gone this early. I think intake or vacuum leak could cause the problem and result in the code you reference since the sensor is reading out of it's normal operating range.
Jeff Quote:
![]() "You drive like old people $#@%... slow and sloppy!" - George Carlin |
o2 sensors possible, changed plugs, maybe wiring harness?
Trouble Code: P2240 O2S Sensor Positive Current Control Circuit/Open Circuit (Bank 2 Sensor 1) Possible Causes: * Check plugs * Check wiring harness * Replace sensor I think ignition coils throw a different code don't they?
///M3 Steering Wheel, Black Leather Trim, Black Aluminum Cube, BMW M Short Shift Knob, Euro Short Center Console - armrest delete, BMW Performance Suspension, TMS Sways, Euro Clears, Michelin PS2's, CDV Delete . . . |
off to my morning appointment for diagnostic with the stealer for my 2500 - 3000 acceleration stumbles with the 04 ZHP 6mt
car will demonstrate: intermittent SES O2 bank 2 sensor 1 open code 2500 - 3000 rpm stumble no Vanos rattle, no idle issue, nothing else will report back Quote: Originally Posted by racemor bimmerforums Here is the statement from the repair receipt: Engine Repair Diag.: Customer states that when accelerating in 5th or 6th gear, rpm 2500-3000, the engine stumbles, hesitates. Tech ran a DME scan. Pulled F/C 2973/2974 for oxygen sensor. Referred to SIB 12 08 05. Technician completed program update per SIB. 2 weeks on and this seems to have fixed the problem. Hope this helps. (fyi, my car is an '04 330i ZHP sedan with 6-speed manual) Quote: Originally Posted by pureco99 Hey OP I just had latest software installed and it seemed to fix the problem. Now the car works better than when I first bought it. I paid about $250 total. Included diagnostics and d/l. So far so good i also was experiencing the exact symptoms and made my appointment. i had no stalling or other vanos related problems or audible indicators. i only experience SES bank 2 sensor 1 O2 code and the surging/jerking on acceleration through 2500 - 3000 prm. after tech agreement with software update he also suggested that O2 be replaced but i wanted to test the code O2 patch first. 250 and tax later i drove home with none of the symptoms and i tried like mad to get them to present themselves. if SES and code gets thrown for O2 again and i'm not experiencing the past symptoms i will then swap the 2 pre cats. i'll report back upon better weather and more spirited driving results. Last edited by throttlehead; 12-17-2008 at 02:06 PM. |
the software update for the SES and O2 fault code was the solution. another thousand miles and spirited miles attempting to get code thrown has resulted in well.....only fun and no code !
however, if ses is thrown again with the same O2 fault....i would then replace the sensors...but at 50Kmiles i was more inclined to believe the software parameter oversight for the precats. it worked ! i'll keep all posted if there is change other than great fun |
Good to hear
2005 Imola Red 330i 6MT, ZHP, ZCW, Xenons ![]() Previous Bimmers ( All sorely missed ):2007 Mystic Blue 530i - ED 12-15-06 ![]() 2003 Grey Green 330i 2003 Electric Red 325iTa Angular velocity is where it's at ![]() ![]() -Jay |
I was experiencing frequent "service engine soon" lights due to P2240 codes and noticed when accelerating between 2500 to 3000 rpm a hesitation. I had my car diagnosed by a BMW Master Mechanic and he told me that cylinder 1 was not getting any fuel resulting in a "lean" fuel condition.
H said to replace the fuel filter, I asked how can the fuel filter go bad at 25000 miles, he repleid that if the car sits for a long time without being used, the water content in the gas can corrode the inside of the fuel filter thus resulting in he symptoms I was experiencing with my car. I replaced the fuel filter and problem solved...just my two cents |
