Noisy Skipping Windshield wipers - Bimmerfest - BMW Forums
Old 11-25-2008, 12:20 PM
gunship911 gunship911 is offline
Mein Auto: 2003 530i 2011 550xi
Here is another quirky, idiosyncratic BMW trait. Why does the windshield wipers skip and chatter across the windshield? The blades are new and clean. The windshield is free of any grime or dirt. But in light or heavy rain, in intermittent or constant setting the damned blades can't do it's job quietly. I just bought the 303 wiper treatments and I hope they will work. Thanks for letting me vent.
Old 11-25-2008, 12:35 PM
freethrowdunk freethrowdunk is offline
Banned
Mein Auto: '03 525i
I get this too. Under the same circumstances described above.
Old 11-25-2008, 05:48 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
No problem with mine yet. Are you using BMW refills?
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 11-25-2008, 06:15 PM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
This was on my E38 back in 2002, but maybe it will give you some ideas. My wiper chatter was only my driver's side. I tried so many things:
Dealer checked alignment of the blade.
OEM inserts changed.
OEM blade changed.
OEM arm changed.
Basic aftermarket inserts tried.
Bosch and Trico more deluxe aftermarket blades tried.
P21S washer fluid "intensive" additive
Cleaned with Stoner's Invisible Glass.
Cleaned with SprayAway Glass Cleaner.
Cleaned with Windex.
Cleaned with Bon Ami.
Had a new OEM windshield installed. ($$$!)
Finally, the PIAA Sporza worked for me, but only on the driver's side. Using the PIAA on the passenger side was bad... it clicked loudly at the end of each swipe. PIAA on the driver's side, OE on the passenger side. Working great the last six years with no other product (like Rain-X, etc.) on the glass. Some swear by the Bosch Microedge, others the Trico Exact Fit. Sounds like it's alot of trial and error to get the right combination.
PIAA on the driver's side. Fin looks close to the BMW passenger side.
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 11-25-2008, 06:16 PM
Oh haha Oh haha is offline
Mein Auto: 1999 528iT
I use rain-x on all of my cars and I do not have any skipping/chattering whatsoever.
I don't use my wipers very often as I don't need them with the Rain-x.
I also wax the windows whenever I do the paint. I use my orbital buffer to polish them.
Wayne
1999 528iT
1981 Euro Spec 911 SC
Old 11-25-2008, 07:21 PM
pinkslip1 pinkslip1 is offline
Mein Auto: bmw 528i 98
i also use rain x it works wonders. before i had the same problem after smooth as ice.
Old 11-25-2008, 09:52 PM
I have used RainX in the past, but I dislike the fact it wears off fast in the wiper path. I've been using the acrylic synthetic wax, Klasse All-In-One, on the windshield when I apply it to the paint. It works as well as RainX and stays on much longer. Another option is a product called AquaPel, which is supposed ot last longer than RainX. I have never used AquaPel so I am certain of that.
Steve
OSRAM CBI
Old 11-25-2008, 10:54 PM
M.Wong's Avatar
Mein Auto: The E38
AquaPel was the next thing I was going to try when I found my solution. I heard good things about it, but it was not a DIY product.
M.Wong
Old 11-26-2008, 05:57 AM
I have used Rain X in the past. However, I dislike it because it gums up on the windshield after awhile. I will google aquapel and see what that's all about. Thanks.
Old 11-26-2008, 09:47 AM
BruceSEA993 BruceSEA993 is offline
Mein Auto: 2002 540i/6
Hey Guys,
The reason wipers chatter and skip is the blade is not perpendicular to the glass. When the wiper sweeps one way it is smooth as it is not leaning into the glass. On the return it is leaning into the glass and chatters. Changing blades and arms sometimes can help but doesn't fix the problem.
You can look at this by turning off the key while the wipers are on and stop them in the area where they chatter. You should be able to see the blade "leaning" into the glass.
To fix them, twist the arm (the part attached to the motor post being carefull not to torque the motor) so the rubber blade is at right angles to the glass. I have used a couple of cresent wrenches with a shop rag over the wiper to protect the black finish.
Cheers!
Old 02-11-2012, 04:31 AM
ruff2001 ruff2001 is offline
Mein Auto: 2008 X3 3.0xi
Noisy skipping wiper blades
I agree with bruce this is a logical reason for the blades to skip, I will try this fix, since changing the blades did not work. I will post results.
Old 02-11-2012, 04:59 AM
gtxragtop's Avatar
gtxragtop gtxragtop is offline
Mein Auto: 2003 530IA
Originally Posted by BruceSEA993 View Post
Hey Guys,
Cheers!
And why would an arm twist out of its original position that would require the amount of force you will apply with a wrench to straighten it? Something seems odd.
A wax or glaze on the windshield can cause this. Bon Ami cleaner (use ONLY bon ami) can be used to remove the wax/glaze from the windshield. It will not scratch glass. I've also had a theory that with wear in the linkage bushings the wiper may start to chatter and with the slop in the bushings, the arm resonates which causes the chatter. Not sure if bushings can be replaced or if the linkage assembly is the replacement part. In various cars owned, never had any luck replacing the blades or arm assemblies to solve the problem. Never have this issue on low mileage vehicles, only after years of wear and tear
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
Old 02-11-2012, 11:41 AM
Just for the record, mine make no noise whatsoever.
Of course, it hardly ever rains in California ... but when it does rain ... my wipers don't make any undue noise.
If it helps, I replaced my rubber inserts as described in this thread:
- How to buy E39 25" driver side & 22" passenger side wiper refills
Old 02-11-2012, 01:27 PM
I usually see this happen from snow or ice on the windshield and that puts a load on the blades. I am sure there are lots of other ways to get them out of alignment.
I have stopped the chatter on about 5 or 6 cars with this method so it works for me. YMMV!
Old 02-12-2012, 04:15 AM
shaftdrive's Avatar
shaftdrive shaftdrive is offline
Matching beemer & bimmer
Mein Auto: 1999 K1200 & 2001 525
I never get any chatter on my beemer!
Old 12-11-2012, 09:15 PM
Wayne's World Wayne's World is offline
Monkey Wrencher
Mein Auto: 2005 325i Sport 5spd
I can confirm this resolved the issue for me with an E39 M5. Even left the old blades in and just adjusted the angle on the driver side and chatter disappeared. Replaced the blades and it's even quieter.
2002 Sterling Gray M5
'nuff said
Old 12-12-2012, 04:31 AM
Fudman's Avatar
Fudman Fudman is offline
Just a clarification to an earlier post on this thread: Aquapel is a DIY treatment. And it is similar to Rain-X but lasts 3-4 months. Highly recommended.
Old 12-12-2012, 05:02 AM
poolman poolman is offline
Mein Auto: 525i station wagon
Have been using Aquapel for the last couple of years now--this stuff really lasts--along with that the best wiper refills I ever used --Trico bought at the Local Advance Auto--26 inch length--the height of the baldes are just a little taller and they are Silent while working back and forth. To install them, I removed the metal from my old blades and them trheaded the Rubber blades into the arms and then threaded the Bmw blades into the wipers--tight fit but worked and they are the best that's been on the car since I have owned her new--245k miles now
Old 12-12-2012, 05:43 PM
moots's Avatar
moots moots is offline
Dinggg....what now!
Mein Auto: '04 525i
yup.what bruce said.
fixed this on other car makes and cured chatter.
it chatters because the rubber blade is going against the sweep direction and not sweeping with it.....like painting a house door with a 2 inch paint brush
sometimes its fixed by replacing wiper blades sometimes by adjusting the arm angle.
some instance when the wipers are not used for prolonged periods,the blade tend to 'rest' in one angle and 'forms' itself to that angle state...and the first sweep will cause chatter as the blade is pointing 'to' the sweep direction....
Old 12-13-2012, 03:24 AM
Tuskfish Tuskfish is offline
Mein Auto: 2001 530iA Sport
Aquapel is the best and longest lasting product of it's type I've used you just won't find it on the shelves of the local auto parts store.
There is a rain repellant that works way better than RainX and is easy to find locally. Check out Rain Clear, it's a gel by Glass Science.
Old 12-13-2012, 08:01 AM
rdl rdl is online now
Mein Auto: 530i 2003
EDIT: Opps, alignment was mentioned in earlier posts. Sorry for the oversight. Meantime, I hope these instructions will help on the details of adjustment.
In addition to issues listed above, consider the angle the wiper arm/blade makes to the windshield. If the angle is too far off, the wiper will skip & streak or chatter.
The TIS procedure for checking & adjusting the angle
And an image of the BMW tool with angle indicated
ID:	353076   Click image for larger version
ID:	353077   Click image for larger version
Regards
RDL
Old 12-13-2012, 08:15 AM
Come to recall, another source of noisy wipers (although not so much for chattering) is wear in the blades and spoiler. See this thread describing my eperiences.
http://www.bimmerfest.com/forums/sho...d.php?t=583984
Regards
RDL
Old 12-17-2014, 07:40 PM
MUSCLEBOY's Avatar
MUSCLEBOY MUSCLEBOY is offline
Mein Auto: 528i
Question
Moot. Anyone else out there? How do you adjust the angle of the wiper arm to bring it to perpendicular? A wrench and cloth over the arm to protect finish is all i gathered so far...but doesn't this mean you would be torquing the wiper arm in a direction....? Is this like tightening a bolt or something where there may be room to turn the unit a bit further without actually snapping it off? Iposted a recent post (yesterday) about chatter on my one year old Bosch replacemnet wiper...i even called them junk. Now i am rethinking this that maybe the problem is the wiper arm? I used the wipers a bit over winter last year...some ice and snow ... maybe this did in my wipers? I don't recall having any chatter at that time last year. Could someone describe to some detail on how to correctly make this tightening or perpindicular turn with the rench? Thanks a million .
Val
Old 01-03-2015, 02:02 PM
Edgy36-39's Avatar
Edgy36-39 Edgy36-39 is offline
Constantly Learning
Mein Auto: 2006 M3, 2002 M5
This problem was really noticeable today. Will try the alignment adjustment, very carefully.
BLUE HEAVEN:
Interlagos Blue 06 M3, Autologic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here.
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Euro rotors, iPod integration. MRegistry listing here.
Old 01-04-2015, 11:04 AM
MKJS MKJS is offline
Mein Auto: '99 540iA
Mine were chattering before I read this thread. I ordered a direct replacement from RockAuto and put it on, no more chatter.
doc
