Old 10-17-2008, 12:17 PM
nonamerequired nonamerequired is offline
GRC
Mein Auto: 740Li
Originally Posted by Orient330iNYC View Post
5mm between the hub and the wheel? 5mm is quite a bit, when i tested it on the front, the spare bottomed its back face against the hub
the wheel should be centered on the hub, and the wheel should bottom against the hub around the lug bolts.
are you saying the wheel doesnt press against the hub on your car?
i'll investigate this tomorrow as i'm going to be putting new wheels on, but i'm not sure what you are referring to. a spacer would only move the same mating surface out further. I have a set of 15mm spacers for my old summer wheels and literally, its the face of the hub extended 15mm, there's nothing that would allow more contact with the hub face.the rim would bottom against the caliper if anything. the chamfer on the front and rear wheels is the same.
yeah, i know it doesn't make much sense. i'll re-do the install today and see if i i can confirm my findings. hopefully not.
G12 750i on order - ED June 2016
F02 740Li
SOLD - E92 335i coupe A52/ZSP/ZPP/4AB/415
Old 10-17-2008, 02:41 PM
Orient330iNYC's Avatar
Flying monkey herder
Mein Auto: Daihatsu Terrios
are you talking about the space you can see around the lug holes?
thats normal, the lugs have a tapered head and the wheel is stamped to accomodate that.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 10-25-2008, 04:18 PM
NeilQ NeilQ is offline
Mein Auto: 328i, Z3
I just tried my 36 11 0 308 889 kit today (purchased from Tischer). Everything works perfectly. Thanks Orient330iNTC for doing all the researach.
2008 328i w/sport
Old 10-26-2008, 11:30 PM
WhoMe?! WhoMe?! is offline
I was the other guy!
Mein Auto: 08 335i Coupe
2008 328i w/sport
NeilQ;
Did the test fit on the front? I'm assuming the sport package on the 328i has the same brake caliber dimensions as the 335i sport. (Hoping any way. ) Would be confirmation that the kit will fit my car.........and I can order without stressing.
Old 10-28-2008, 11:38 AM
JST's Avatar
JST JST is offline
A sudden sense of liberty
Mein Auto: 535xiT, Golf R, 987S
I'd still love to know whether this wheel will work on an E9X M3, perhaps with a spacer. If anyone has access to one of these wheels and to an M3 and wouldn't mind doing a bit of detective work, I'd really appreciate it.
Old 10-28-2008, 07:21 PM
Originally Posted by WhoMe?! View Post
NeilQ;
the 328i has smaller brakes than the 335i, sport package doesnt affect the brake system spec.
Old 10-29-2008, 01:46 PM
CRAP!
Thanks for the info.
Old 10-30-2008, 01:53 PM
jlipton jlipton is offline
Mein Auto: 08 335i e92 6MT Sport 230
WhoMe?!, I think that means that if it will fit the 335, it will fit the 328, as the 335 has larger brakes
Old 10-30-2008, 09:10 PM
exactly, the issue is brake clearance. the 328i should have no problems
Old 11-02-2008, 02:33 AM
blue335xi blue335xi is offline
Mein Auto: 535 xdrive
tire in trunk
here is the space used in an e90 trunk.
thanks for the useful research.
Old 11-07-2008, 02:31 AM
deems deems is offline
Mein Auto: 08 328i|6MT|ZSP|ZPP
Many thanks Orient335iNYC!
I've been looking for a compact spare for months. Leatherz has been out of stock and their prices seem too high. I just ordered the kit form Tischer. Once I get it, I'll replace my RFT's with Michelin Pilot Sport PS2's (245/45/17 & 255/40/17).
Just to be clear, this kit will work on most E90's, front or rear, with no spacers or long lug nuts, right?
Thanks again.
Old 11-07-2008, 09:07 AM
Thanks again.
correct
Old 11-10-2008, 09:26 PM
I have the 2008 335i Coupe with Sport Package. I do not recall confirmation in this thread that anyone has test fit the kit on the front of 335i /w Sport Package. (Test fit done on the rear only.)
I'm just confused. :P
If anyone has test fit the spare on the front rotor, I would appreciate if you could let me know.
Old 11-10-2008, 09:37 PM
the brakes on the 335i are the same, coupe or sedan, sport package or not.
Part 34116773202 (CALIPER HOUSING RIGHT) was found on the following vehicles:
E90: Details on E90
E90 335i SEDAN
E90 335xi SEDAN
E90N: Details on E90N
E90N 335d SEDAN
E90N 335i SEDAN
E90N 335xi SEDAN
E92: Details on E92
E92 335i COUPE
E92 335xi COUPE
E93: Details on E93
E93 335i CONVERTIBLE
Part 34116770729 (BRAKE DISC, VENTILATED) was found on the following vehicles:
E90: Details on E90
E90 335i SEDAN
E90 335xi SEDAN
E90N 335d SEDAN
E90N 335i SEDAN
E90N 335xi SEDAN
E92: Details on E92
E92 335i COUPE
E92 335xi COUPE
E93: Details on E93
Old 11-10-2008, 09:43 PM
In other words......it fits the 335i series.
Time to place the order......just in time to make the border for the Christmas rush of packages.
Thanks for the ALL the information....I'm more educated re my motorcycle than my car. (Newbie.)
Old 11-11-2008, 11:41 AM
GemBM GemBM is offline
Mein Auto: 535i
Orient335iNYC,
I have a question do you know if this spare will fit 135i thank you?
Old 11-11-2008, 02:52 PM
I placed my order to get this response a few hours later:
"Hello and thank you for your order. Since these wheels have such little mark-up from BMW, we can only discount them to 275.00."
They could not sell at the $239.21 listed on the web site. That, plus $90 shipping costs to CANADA, plus exchange rate of nearly 20%, plus duty....I'm looking at an estimated $450+ CAD.
I figure I'll try BMW directly here in Vancouver to determine the costs.
Old 11-23-2008, 03:09 PM
MadMan77 MadMan77 is offline
Mein Auto: '08 135i
Originally Posted by GemBM View Post
Orient335iNYC,
I am going to have to tag along with GemBM on this one. I know this thread is in the 3 Series forum but hey, it's a shot in the dark and I hope it does.
Old 11-24-2008, 04:38 PM
Shocktopus Shocktopus is offline
Driving like I stole it.
Mein Auto: 2009 335i Cabriolet 6MT
Originally Posted by dale512 View Post
Thanks for the reply. I went out to the car and measured 25.5" x 5." The compact spare tire size is a deal breaker for me...I wish it weren't so. It just takes up too much trunk space. Thanks again. dale512
Ah man, me too. Won't be able to fit the two suitcases. Dammit why didn't they at least leave a well under the trunk?
I farking hate RFTs. And I've had a tire shred so bad 150 miles from nowhere that RFTs wouldn't have done squat. It was bad enough limping into the next town at 50mph on the spare.
Guess I'll have to just pray that I don't repeat that experience.
Old 11-27-2008, 12:59 PM
no idea, maybe u can ask ure dealer if they'll let u test fit a spare out of a 5 series?
Old 11-28-2008, 12:10 PM
Mein Auto: '08 135i
That is a good idea. I will check with the dealer.
Old 11-29-2008, 06:20 AM
While not a suitcase, here is an example of what I was able to fit in the trunk with spare in there.
ID:	168100   Click image for larger version
Old 11-29-2008, 11:40 AM
tombrown23456 tombrown23456 is offline
Mein Auto: 2006 gray 325I
I have a 2006 325I what are my options for a spare tire?
Old 11-29-2008, 12:34 PM
wow, thats quite a bit of stuff!
only the non sport package cars have them, so a 528i or xi is probably ure best bet
