E46 Starter R & R - Bimmerfest - BMW Forums
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 11-22-2008, 04:54 PM
Detroit Badger Detroit Badger is offline
Mein Auto: 2001 325i Conv.
Angry E46 Starter R & R
I've replaced starters in Detroit iron in the past, but the starter on my 2001 325ci appears to be pretty tough to access. Can anyone give me any tips that might ease the job? I'll have to do it on my back with the front wheels on ramps.
Old 12-05-2008, 11:04 PM
DanSteeves DanSteeves is offline
Mein Auto: F-350
No real easy way to do it. Most of the starters are not threaded so that makes it even more challenging. Best if you can get it on a hoist and use long extensions from the back of the tranny to get the bolts out. Some of them it's actually easier to lower the subframe and/or transmission.
Old 12-11-2008, 06:38 PM
fun2drive's Avatar
BMWCCA 149159
Mein Auto: 335 vert/14JGC/ 17Outback
First you need a Bentley manual and you have two choices, take the manifold out or take the transmission out if manual.
You need the starter that has threaded holes
http://www.pelicanparts.com/bmw/tech...84-Starter.htm
This is the part number you want regarding threaded starter
SR0448X
2001, 325ci, e46, starter
