Which wheel is speed sensor A on? - Bimmerfest - BMW Forums
Old 12-17-2008, 05:23 PM
flyboy310 flyboy310 is offline
Mein Auto: 528i
I've got a '97 528I. The ABS and ASC lights came on and I'm getting a P0500 Vehicle Speed Sensor A malfuntion. Which wheel is sensor A on?
Old 12-17-2008, 05:56 PM
Waveho Waveho is offline
Mein Auto: '07 335xi 6MT 4door
If you have ASC, then you have speed sensors in your front right (passenger side) and rear left wheels. Stands to reason that "A" would be front right, but that's just speculation....
'07 335xi 6-spd 4dr, Montego blue
'98 540i 6-spd Sport, Jet Black II(sold)
'92 325i 5-spd 4dr, burgundy(sold)
Old 12-18-2008, 05:20 AM
velvetMonkey velvetMonkey is offline
Send a message via MSN to velvetMonkey
Mein Auto: 1999 523i
It's one of the front ones, there are four wheel speed sensors on an E39. Front right is used to tell the gearbox electronics how fast you're going. The rear left is used to tell the instrument cluster/navigation etc the vehicle speed.
UK 05/99 BMW 523i SE, 190k miles, steptronic, black leather, hella AEs and cellis, style 32s, MTEC front and rear bumpers, sport exhaust tip, shadowline, HID headlamps, OEM satnav retrofit
Old 12-18-2008, 08:16 PM
cpatstone's Avatar
cpatstone cpatstone is offline
it's NOT old man gray...
Mein Auto: 528it, 5M, born 7/2000
if your car is like my '00 528it with dsc, then speed sensor a is the processed speed signal coming from the abs module. it doesn't refer to one of the four wheel speed sensors. have a bentley manual? if so, on the abs module connector, find the four pair of pins which lead to each sensor, then measure the resistance across each, and measure the resistance both ways. all sensors should read about the same. then again, if the resistance of just one of them is infinite or zero, then you have your faulty sensor.
528iT/5M; Premium, Cold Weather, Nav, Xenons, OEM sport rims, ZHP shift knob, DSC Disabled!
Wife's: 325iT/5M; Premium, Cold Weather,
Stereo that doesn't suck, Xenons, Sport Package, ZHP shift knob, PDC, DSC still working.
'88 R100GS - and yeah, it's been offroad
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein (1879-1955)
Old 12-19-2008, 08:25 PM
Mein Auto: 528i
best info yet, need a little more
Cpatstone, you've given the best info yet. Even with ASC, there is a sensor on each wheel. I rotated the two front ones and the message stayed the same, which lends credence to your explanation. Problem is, I don't have a Bentley (for a BMW?) manual, and I don't know where the ABS module is. New to BMWs. Could you tell me where the module is located, and more importantly, which pins are the sensors. Pin numbers, or wire colors maybe. If you have some additional info and don't feel like typing, please e-mail me your number and I'll call you. Save you the long distance. Thanks in advance, I really need some informed help with this. flyboy310@yahoo.com
Old 12-20-2008, 06:24 AM
cpatstone's Avatar
what year is your car? I don't know if that's important, but it might be. Just to confirm, does the button below the radio say ASC or DSC?
Bentley says that the module is to the left of the glove box... I'll let someone else chime in who's actually seen it and knows what it looks like.
I might be able to dig up pin numbers, but do you have access to a voltmeter?
Old 12-20-2008, 04:30 PM
BMW_525i_Noob's Avatar
BMW_525i_Noob BMW_525i_Noob is offline
A Purist's Nightmare LOL
Mein Auto: 525i
If anyone needs an ASC Control Unit, I have one for sale cheap in the parts forum.
20" Gloss Black powder coated Voxx wheels
custom powder coated window/pillar/door trim
gloss black door/bumper trim
carbon fiber roof spoiler
silver M5 trunk spoiler
front lip spoiler
euro eyelids
two tone silver/black interior
rear armrest subwoofer (10" DVC Orion) w/Fosgate 5002
custom painted gloss black head unit (6.5" flip out DVD)
Aluminum pedal set w/dead pedal
H&R SPrings w/Bilstein Shock
Custom catback exhaust w/flowmaster muffler
4.10 Diff swap
Conforti Shark Injector
Old 12-20-2008, 05:49 PM
Mein Auto: 528i
my ride info
It's a '97 528I, automatic. The button below the radio says ASC, and there is a sensor on each front wheel. Haven't visually verified the back, but I'll bet there is one on each rear also. When you refer to a Bentley manual, is that the publisher, or is there actually BMW info in a Bentley auto repair manual. I know that sounds like a stupid question, but I am new to beemers and honestly don't know.
Here's a twist. The lights went out and both the ASC and anti-lock are now functioning. I wonder if the module is about to take a dump on me. Lastly, I have a multimeter, so if someone can give me pin numbers or wire colors of the sensors I can ohm them out at the module plug.
Old 12-21-2008, 05:18 AM
Next time you skid or brake hard, the lights will come back on and the ASC and ABS will again cut out. Pretty sure that you only have speed sensors in front right and rear left wheel wells with ASC. You have brake lining sensors in each wheel well also, which looks similar. Anyone else confirm this?
Old 12-21-2008, 02:21 PM
blz456's Avatar
blz456 blz456 is offline
Mein Auto: 2000 528i
I think your right about only two wheel speed sensors with ASC. I can't really confirm though since I have the DSC with sensors at all four wheels.
2000 528i steptronic
Blacked out
Old 12-21-2008, 02:26 PM
blz456's Avatar
I had the same problem not too long ago. I thought it was a wheel speed sensor at first because I had the dsc brake and abs lights on and everything else worked. As the months passed it got worse. When I stared the car in the morning it was fine but as the car heated up everything failed including my speedo, odometer, cruise, the fuel gage flucuated, and the p0500 code popped up. The reason this code was on though was because since the whole module wasn't working none of the sensors were and since the computer monitors the sensors it threw a code saying that they weren't working. Once I got my module fixed the sensors worked again and the code cleared itself.
Blacked out
Old 03-16-2009, 03:37 PM
williemac williemac is offline
Mein Auto: 523i
original Post----I had the same problem not too long ago. I thought it was a wheel speed sensor at first because I had the dsc brake and abs lights on and everything else worked. As the months passed it got worse. When I stared the car in the morning it was fine but as the car heated up everything failed including my speedo, odometer, cruise, the fuel gage flucuated, and the p0500 code popped up. The reason this code was on though was because since the whole module wasn't working none of the sensors were and since the computer monitors the sensors it threw a code saying that they weren't working. Once I got my module fixed the sensors worked again and the code cleared itself.
This is the exact sympotoms I have just had today, I was on mororway just outside London (400 miles from home).
What module did you have to repair to sort this.
Thanks Williemac
Old 03-17-2009, 04:51 PM
apdriver69 apdriver69 is offline
Mein Auto: 2002 530i
Williemac,
Just had the same thing happen to my 2002 530i-DSC,Brake and ABS has been coming on periodically for the past week. A bunch of guys on this site and "bimmerforum" are saying it could be the wheel speed sensors OR the ABS module AND i've even heard it could be wheel bearings?????????? I have a decent mechanic so i'll take it to him and let him figure it out!! If it is the ABS module,you can get them rebuilt for about 300 bucks!! I belive there are 2 options when having your ABS module rebuilt-module masters and bbs!! I am sure i'll be corrected if i'm wrong about that!! Good luck and enjoy that good scotch and golf you have over ther!!
Old 03-18-2009, 05:27 PM
540iman's Avatar
540iman 540iman is offline
resident, old fart
Mein Auto: 2002 540i sport
Mind if I ask what brand code reader you are using? Thanks.
Old 06-23-2011, 02:30 PM
For the cross-linked record, I ran into this (old) thread researching wheel speed sensors for someone ...
This is the latest set of links for these types of questions:
- All about DSC (1-pdf) (2-pdf) & comparisons to ASC+T (1) & how to diagnose & fix the ABS DSC (or ASC) BRAKE trifecta (1) or the amber ABS DSC (or ASC) bifecta (1) (2) (3) (4) (5) (6) (7) or just the DSC light (1) & what is the ABS control module testing pinout for the older E39s (1) & what is the logic of ABS diagnostics (0) (1) (2) (3) (4) (5) (6) (7) & how to test brake systems (1) & how to test the brake pressure sensor (1) & how to autopsy & fix your Bosch ABS control module yourself for free (1) (2) & what anomalies occur while the ABS control module is out of your vehicle for repair (1) (2) (3) & how to replace wheel speed sensors (1) (2) & why you want OEM wheel speed sensors (1) & what happens if you don't code your VIN into a new/salvage ABS control module (1) & how to test (and align) your E39 DSC steering wheel sensors (1) (2) (3) (4) (5) (6) & how to turn off DSC traction control (1) (2).
Old 09-08-2013, 05:07 PM
erichall erichall is offline
Mein Auto: 01 530i
speed sensor location
I have an 01 530i that is doing the same thing. Check engine light,abs light, and transmission light all on. Speedo doesnt work, or cruise, or sport shift. It also pulled the same p0500 code but was told the sensor is not located on any of the wheels, it is actually on top of the transmission which must be removed to access the sensor. This was told to me by a very trusted mechanic(my father) with over 40 years experience working on german cars
Old 09-08-2013, 10:12 PM
There are about 20 things that sense that are used in the ABS system (as explained in the PDF in the aforementioned threads).
I don't remember how many of those are on the transmission - but - yes - there are transmission speed sensors also.
For more information about the P0500, you might see these threads:
- ABS Diagnostic DIY + P0500 Vehicle Speed Sensor Malfunction
Old 02-29-2016, 08:15 AM
Rodneyjallen Rodneyjallen is offline
Rodneyjallen
Mein Auto: 97 bmw 528i
Im having this issue now sensor A trouble code p0500 on my cent-tech professional scanner cuz my creator 310 just says communications error. Now ive heard if u get a new or used/rebuilt abs module u have to have it reprogrammed but ive also read comments of ppl who havent done that n it worked fine. I own a o7 528i with the asc button not dsc but i have 4 speed sensors ive replaced them all before i got code reader cuz car wouldnt shift automatically which by the way fixed that issue but car is a bit sluggish on take off however i got 2 bad o2 sensors and idle air control system code p0505 is that the idle air control valve oh n my car still says bad cam sensor which i replaced maybe a bad new one it was an aftermarket one after all
Old 02-29-2016, 10:55 AM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
Did you connect the Creator to the OBD port under the hood? Mine reads live data wheel speeds from all four sensors in the "chassis" menu, but I have a later model car with only the under-dashboard OBD connection.
Old 02-29-2016, 11:46 AM
alex5er's Avatar
alex5er alex5er is offline
Mein Auto: e39 1997 528i
Did you use OEM wheel speed sensor?
Especially on 97 to 08/98 many if not all aftermarket ABS WSS Do Not Work on our 97.
It been my experience with sluggish take off and or performance is due to a bad or failing Vanos seal. Is your SEL on? And you're getting CPS code it definitely your Vanos seal. But first check and be sure you have a OEM ABS wheel speed sensor. You will be surprised with the results.
Old 02-29-2016, 12:35 PM
Rodneyjallen
A friend has the round under hood adapter i was able to reset airbag but dont think abs read or i forgot to try dont get me wrong i love my creator too but its nice to have one that does all cars n saves data n prints
Old 02-29-2016, 12:37 PM
Rodneyjallen
Theyre not oem i know thats an issue but i havent replaced the ones that arent oem yet but will n god i hope i have no vanos issue the one thing i dont want to do on either of my bimmers lol
