Old 10-20-2008, 10:37 AM
rntvin rntvin is offline
Mein Auto: 1997 BMW 540I
1997 540i-Can't open hood --HELP!
My hood is stuck on the drivers side. When I pulled the hood release, the passenger side opened just fine, but the drivers side is stuck. Does anyone know how to get the hood open when it sticks like this? My "Check Coolant Level" message keeps coming up and I can't get the hood open. Thanks!
Old 10-20-2008, 10:42 AM
andyffer andyffer is offline
WTB - your E39 M5
Send a message via AIM to andyffer
Mein Auto: 02 530i, 09 335d
crowbar?
get a flashlight in there check it out.
I dont know any other way
Just drive to your nearest dealer. Im sure they will do it for free
Unencumbered by the thought process
If you're not a ******* at twenty you have no heart, if you're not a ************ at forty you have no brain.
Old 10-20-2008, 10:45 AM
Thanks! I already tried prying it. I even had my wife sit on it to put pressure on it. Now it has a butt dent in the hood. LMAO....LOLOLOL
Old 10-20-2008, 10:47 AM
WTB - your E39 M5
^ are you serious?
Now all you have to do is sell it and LEARN YOU DRIVE A BMW, NOT a civic. Dont sit on it.
Old 10-20-2008, 11:06 AM
Talking not serious
Originally Posted by andyffer View Post
^ are you serious?
no there is no dent........that went with your "crow Bar" advise.........i have never even owned a honda car....lmao......have a great mechanic in town.......but he is not open on mondays.......and we worked all last week in L.A area so tomorroe is the day........
but thanks for your help
Old 10-20-2008, 12:36 PM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
I wrote this a while ago, not exactly a DIY but rather a routine maintenance tip but will give you a very good idea what to do:
http://www.bimmerboard.com/forums/posts/366665
Also:
http://www.bimmerfest.com/forums/sho...hood+cable+diy
Old 10-20-2008, 02:31 PM
Johnny Canada's Avatar
Johnny Canada Johnny Canada is offline
2003 530 5 speed
Mein Auto: 2003 530 5sp 53K Miles
Recently, my hood stuck on my 2003 530. I pulled the interior latch, and as usual, the secondary latch release popped out from the grill. However, when I pulled up on the grill latch, nothing happend. I continued to apply upward pressure until I thought something might break. I forced the hood back down (closed) and pulled the interior latch , repeating the process. On the 4th time, the secondary latch handle activated the latch.
After inspection, I noticed that a round pin slides inside a groove to move the latch open. The pin was stuck inside the groove. Just a lack of lubrication. But it was enough to freeze things up.
For you, I'd suggest soaking that secondary latch the best you can with wd-40. Hope this helps.
Old 10-20-2008, 03:10 PM
John@AstigRacing John@AstigRacing is offline
Past Sponsor
Send a message via MSN to John@AstigRacing Send a message via Yahoo to John@AstigRacing
Mein Auto: 2000 528i Sport
Also:
This is a good tip. Thanks cn90!
Old 10-20-2008, 04:31 PM
Rustyzipper's Avatar
Rustyzipper Rustyzipper is offline
97' 540i
Mein Auto: 540iA
Omg
LOL.. this is like deja-vu all over again...
This happened to me, and was about to pull my hair out.....
First, to open the hood ( this is if you tried the push, pull yank here and there tricks), you need to pull the Driver side grill off... it comes off, but when it does your going to fly. grab it at the most outside slats, work the top first, and pull like hell... it will come off. I was lucky and didn't break it.. if ya do, there cheep.
ok, now you need a cotter pin extractor tool, or something like it,( anything with a curve like screw driver tip) there is a latch up by the cable that needs to push away from you. that will release the driver side. once its open you need to check all the cables and lube them.. in my case it was the small plastic box hooked on the side by the oil filter.. make sure nothing move, as in lose cable linkage... that was my prob. clean and lube the top and bottom catch.
........ gawd i was there and wasn't fun... but if it ever does it again, BUT won't now, I know what to do... GOOD LUCK!!
let us know how it goes.
Old 10-21-2008, 11:35 AM
Also:
THANKS....I WAS SEARCING FOR THE DIAGRAM OF THE HOOD ASSEMBLY
LIFE SAVER
Old 10-21-2008, 12:36 PM
94mugen 94mugen is offline
Mein Auto: 1998 540i
Happened to me, have to take the grill out and used a wrench and unscrew the hood pin little by little, cause the half moon wire is stuck.
Old 10-22-2008, 08:09 AM
pankaj3536 pankaj3536 is offline
Mein Auto: 01 530i
Happened to me too
it happened to me too last summer, what I did was pull the latch inside the car and then pull the lever on the right side grill as to open the hood and then pull the latch inside the car again and it releases the driver side, couldnt figure out what was the problem but it fixed itself.
Old 10-26-2008, 11:47 AM
I want to thank each and everyone of you for all your help.....today being sunday and my 1 day off i am going to tackle this one way or the other....keep me in mind.......this is the greatest forum out there....and a heck of alot cheaper then taking it to the dealer
THANKS EVERYONE
RICK
Old 01-08-2009, 02:18 PM
drac05 drac05 is offline
Mein Auto: 97 540i
so this is going to sound funny but I'm stuck in the same situation and I really need your help. my battery is dead and I can't open the hood. any help pls.
Old 01-08-2009, 02:56 PM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
you can use your key to unlock the trunk, i forget wich way you turn but you have to turn it a little further than normal, you should hear is pop, then push the key inwards to open. and just in case you don't know the batt. is located in the trunk. but if you need to open the hood, have someone pull the inside lever and hold it in the open position, while you pull the hood up.
The more you complain, the longer God makes you live. SPHOBA #00002
Old 01-08-2009, 03:45 PM
dannyc9997's Avatar
dannyc9997 dannyc9997 is offline
Send a message via AIM to dannyc9997
Mein Auto: 540i
You cant get the hood open or you cant get the doors open to get to the hood latch? Try the above post to get into your trunk, its a hard turn to the left or right (varys from car to car for some reason)
Old 01-08-2009, 06:12 PM
Mein Auto: 97 540i
I'm sorry I didn't explain better the latch is broken so I can't pop the hood to get to the car battery. Is there anyway to open the hood so I can replace the battery or jump start it?
Old 01-08-2009, 07:13 PM
lild's Avatar
livin the 'Fest
ok. to start with the batt. is located in the trunk of the car. on the pass. side. you can jump it there. on the latch which i assume your talking about the one on the inside, then if there is any peice of cable left, use a pair of pliers to pull the cable and the hood should pop.
540i, hood, latch, stuck
