Old 06-05-2008, 07:55 PM
besheer besheer is offline
Mein Auto: R6
Thanks to everyone who contributed to this thread! It made what would have normally been a 5 hour disaster turn into a 15 minute job. My two cents though...once you get the radio out, it's insanity to try to pull the AC panel through the radio opening. You guys who were able to do that are magicians. I had to change the bulbs while the panel was loose, but still behind the dash. Still a fairly easy job, but it just took a while to figure out how to fit both hands in there at the same time.
Old 06-05-2008, 10:11 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
I don't think anyone has pulled the panel out through the radio opening. It's just a place to put your hand in to get to the back of the HVAC controls.
Daniel
2002 M roadster
Old 06-05-2008, 10:26 PM
greyish's Avatar
greyish greyish is offline
tire consumer
Mein Auto: 99 z3c
^^ ..what he said.
Old 06-06-2008, 08:39 PM
Mein Auto: R6
Ya, sorry...misunderstood that. Shame on me
Old 11-08-2008, 03:08 PM
robrez robrez is offline
Mein Auto: Topaz Blue 3.0i Z3 Coupe
Originally Posted by Randy Forbes View Post
You knocked the bulb holder off the outside of the lighter while you were in there.
You'll want to correct that before the hot bulb lays against something it shouldn't.
Might be able to reach up the side of the console, depending on the size of your paws.
Back from the dead. Does anyone have a pic showing where the cigarette lighter bulb holder is located. My bulb is dangling. Thanks
Old 11-08-2008, 04:23 PM
postalZ3 postalZ3 is offline
Mein Auto: 2000 Z3 2.8
If I remember correctly, the bulb just snaps on the side of the lighter socket
<img src=http://i.imgur.com/JMjPR.jpg border=0 alt= />
Old 11-08-2008, 04:43 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Mein Auto: 98 Z3 // 06 X5
there's a hole for it along the side
Old 11-08-2008, 07:13 PM
dwm's Avatar
dwm dwm is offline
As Randy said, unless you have tiny paws, the best way to get it back in place is to go at it from the driver side footwell. Remove the panel that's over the pedals, remove the two screws that hold the center console to the underdash panel, lay in the footwell and reach in there with your left hand. You can get it back in place by feel without seeing it. Pay attention to the door chime, it's all too easy to knock it off.
Daniel
2002 M roadster
Old 11-09-2008, 12:05 PM
Thanks for the info. One more tip for that pesky left side HVAC bulb, on M models, if you remove your middle gauge, you'll be able to see the left side bulb holder through the hole in the 10 o'clock position. You can reach through the hole and pull it if you have super strong fingertips or you can use a needle nose pliers. This is assuming, you can reach through the stereo opening to turn the collar behind the gauge in order to first remove the gauge.
Old 11-10-2008, 10:23 PM
summereskimo's Avatar
summereskimo summereskimo is offline
Mein Auto: Modded E36/7&Stock E36/8M
My pain is your gain.
After a failed attempt without removing the HVAC assembly, I decided to go for it one more time.
I don't remember replacing a pair of bulbs being this gory. Please be carefull when pulling on the plastic lock for the radio wires:
Tools used for this operation:
The mirror helped orient me with the back layout.
Removing the E106 bulb was a lot easier with the HVAC assembly still attached. I didn't want to twist and move it around to much just to get to the bulb later.
I decided not to remove the bulb from the wire to prevent the occasional opsies and dropping the bulb disappearing in the web of wires forever. Just be careful with the needle nose when pulling. Make sure you have a firm grip on the plastic body; you don't want your pliers to slide when yanking and accidentally pulling the wires instead.
Hidden behind cables and plastic arms is the second E105 bulb...what great placement:
This is the part were the HVAC assembly needs to come off:
Just support the assembly with one hand and remove the bulb with the other. The less you disturb the cables of the HVAC the easier it is to install back IMHO.
Check if the lights work before plopping the assembly back.
Putting back the HVAC assy. wasn't as hard as others described, it's just a matter of taking your time & familiarizing yourself with the layout. Check if all the chrome rings are in place. line up the bottom of the HVAC assembly first with the center console, then snap the top in place.
Finally, do not forget the ziploc on the self dimming rearview mirrors before tucking your Z away for the week
-Ian
About me-For Sale
Old 01-13-2009, 06:53 AM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
I just replaced both those in the black car last month.
Able to access them through the radio opening (less trouble than removing the console, but still a pain).
12/8/02. Those bulbs lasted a lot longer than the originals...
Now, six (6) years later, since this thread is still used for reference, I'll update it with some new pictures.
Note that while not shown, the head unit has to be removed first, so be sure to have the security code if it's the factory unit. The CD head unit requires a 2.5mm Allen wrench to remove, the cassette player takes a special five (5) sided tool available from the dealer.
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
Old 01-13-2009, 08:40 AM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
My 318ti is similar and uses just one of the same bulbs. Going on twelve years.
Old 01-13-2009, 11:13 AM
rjcoston's Avatar
rjcoston rjcoston is offline
///M Practical
Mein Auto: 00 M Roadster
Great pictures Randy and btotoro! Thanks.
Old 05-07-2009, 06:56 PM
n1cK! n1cK! is offline
Infiltrator!
Send a message via AIM to n1cK!
Mein Auto: '97 Z3 1.9L
subscribing for some great info!
U-R-not-E
Old 06-19-2009, 08:04 PM
00MR 00MR is offline
Mein Auto: 2000 M Roadster
My fan speed light, the temp gauge under it and the clock all have lights that go off for a while and then come back after going over a bump or smacking the console. So something must be loose right? Any ideas what to look for since the lights aren't actually out? Aftermarket stereo wiring might be pressing against something or loosened eventually after installation?
Old 06-20-2009, 02:14 AM
Sounds like your bulb is on it's way out already. I had the same symptoms. Do they all go on and off at the same time when you hit a bump?
-Ian
About me-For Sale
Old 06-21-2009, 08:29 AM
TR6's Avatar
TR6 TR6 is offline
Mein Auto: 1999 M coupe
I did mine the easy way. I recently had to have the a/c evaporator and expansion valve in the dash replaced to the tune of $1200+ and asked them to replace the bulbs while they had the entire dash apart!
Greg H
1999 M Coupe (daily driver)
2002 Spec Miata race car
1993 Porsche 911 RS America
1976 Triumph TR6
2001 Ford F250 crew cab 4x4 diesel (track support/tow vehicle)
Old 06-23-2009, 12:15 AM
The clock is independent, but the right side gages go at the same time. Doesn't a bulb just burn out and not come back on though? And the two rows should be different bulbs it looks like.
Do the sides of the console in the footwell come off?
Old 06-23-2009, 03:59 PM
No, sometimes the bulb will flicker, sometimes it starts to work when you tap it, sometimes it just flats out die. The HVAC assembly has two bulbs. The gauges below it has it's own separate bulbs. I think removing the radio is about the easiest, most straightforward approach to changing the bulbs and checking connections behind the center console. Unless you want to do it this way :
-Ian
About me-For Sale
Old 06-23-2009, 11:36 PM
So if I need to do the lower row as well, are they the same bulbs and how many? Randy's pics of bottom row above magically got fixed. Any trick to doing bottom row?
Old 06-24-2009, 05:57 AM
Ron Stygar's Avatar
19,585 Miles
Bulbs are back of the gauges.
Old 09-04-2009, 10:26 PM
98FLSTC 98FLSTC is offline
Jet Tech 604
Mein Auto: 2000 Z3 98Harley
Thumbs up Broken hot/cold control arm
I had a broken hot/cold control arm on my 2000 Z3 where it engages the serpentine groove which is just a plastic tit at the fulcrum of the arm. Well the tit broke off when the blend door was binding up a bit. I removed the arm and drilled a hole in it where the tit was and threaded in a ball link from a remote control airplane servo. You can get them at most hobby stores. It worked perfect and is much stronger than factory. Added weight is negligible!
ID:	200043   Click image for larger version
Old 10-08-2009, 06:50 PM
Thank you everyone for the great info. Even though my lights would sometimes come on for a little while with a good dash smack or road bump, they were obviously bad when I pulled them out and examined them. One extra note - keep checking as you reassemble to make sure the lights don't pull out. Mine didn't stay in very well.
Old 07-02-2010, 08:27 PM
funsize funsize is offline
Mein Auto: 2001 M Roadster
Bulb For Power Jack
I thought that I would add my 2 cents on the various bulb replacements for a 2001 M Roadster. I was able to gain pretty easy access to the bulb that can fall out of the power jack by removing the leather boot around the gear shift and pulling the rubber foam spacer out of the way. It opened up the area to get to the bulb. If you ever notice that the power jack is no longer lit up at night, get into the center consol fast because that little bulb gets really hot and will start to melt something if left unattended.
Old 09-29-2010, 12:16 PM
FeeZ3 FeeZ3 is offline
Mein Auto: 2002 Z3 3.0i
Z3 Heater Control Repair
Hi All,
This is my first first post. I have to thank all of you for the tremendous info and great pics. I used your experience to repair the "notorious" broken plastic pin issue on the temperature control.
Following your radio and control panel removal/release instructions, I was able to rotate the panel within the radio opening to expose the rear side. Yep, the plastic pin broke off and was still sitting in the track. Using it to determine what would be a proper substitute, I happened on the idea of using a 1/8" diameter x 1/2" long aluminum pop rivet.
After protecting the center circular dashboard opening (where the temp control lives), I drilled through the control arm at the exact location of the old plastic pin. In order to expose as much of the rivet as possible on the "track" side, it was important to ensure a tight fit for the rivet so the riveting tool could release it with only 1-2 squeezes.
Voila. Works really well. I suspect that other parts of the car will break before this does.
I hope that helps someone out there. You folks saved me a lot of dough.
