Old 07-12-2008, 06:24 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
S54 coil bulletin
Old 11-16-2008, 02:54 PM
Finaidoc Finaidoc is offline
Mein Auto: 1996 Z3 Roadster
Question 1996 Z3 seat rail bushings
Does any one have installation instructions ?
Old 11-28-2008, 09:05 AM
Ron Stygar's Avatar
19,585 Miles
Hose Job: Z3 non M hose
Old 01-16-2009, 08:32 PM
Ron Stygar's Avatar
19,585 Miles
Lets remove the Z3 door panel (part one)
Old 01-16-2009, 08:33 PM
Ron Stygar's Avatar
19,585 Miles
Lets remove the Z3 door panel (part two)
>>>> SEE ABOVE POST #58 <<<<
Screws are one use.
Pin tool is now $76.74r
Hook tool is now $34.51r
Removing outside handle:
Lock Cylinder removal:
Old 02-16-2009, 09:19 PM
Ron Stygar's Avatar
19,585 Miles
Replacing Flexible disk
Old 02-17-2009, 07:46 AM
Ron Stygar's Avatar
19,585 Miles
Operating Fluids Group 11
Old 04-23-2009, 07:44 PM
FredR FredR is offline
Mein Auto: 96 BMW Z3, 97 BMW M3
Upgrading 1.9 non-.vented brakes to vented rotors.
http://www.houston-bmwcca.com/z3/Tech-Tips/Index.htm
96 Z3 1.9 Black/tan/black
97 M3/4 Estoril/dove gray
08 3400HST Kubota Orange/gray
08 GMC Sierra CrewCab
Old 08-22-2009, 08:59 PM
Ron Stygar's Avatar
19,585 Miles
Bulletin sib 12 01 03
Old 10-25-2009, 11:38 AM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
The Z3 FAQ post is for how to content. Please do not post in this thread asking for specific information not listed in this post. Please create a new thread in the general Z3/Z4 forum with your questions–you will get better responses this way!
Old 01-03-2010, 11:30 AM
Ron Stygar's Avatar
19,585 Miles
Z3-M coupe (S52) Data
I knew the sunroof headroom was more.
Never noticed the head room data without or with sunroof.
Old 01-23-2010, 11:27 PM
Ron Stygar's Avatar
19,585 Miles
Z3/318ti HVAC
See this too.
http://www.bimmerfest.com/forums/showthread.php?t=17021
Old 05-06-2010, 09:44 AM
wbbaz wbbaz is offline
Mein Auto: 97 328ic
Went to your highlighted "Skins seat bushing lineup" but I was taken to an unrelated site. I have an 98 Roadster with about 52K and the seats are loose. Will the bushing kit from BMW fix this problem?
Thanks.
BB
Old 05-06-2010, 10:43 AM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
wrong place to post - but Order bushing from http://www.whalenshiftmachine.com/
and check out the You tube video
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 06-21-2010, 04:53 AM
z3power's Avatar
z3power z3power is offline
Dragon Master of TEXAS!
Mein Auto: '00 Z3-2.8L, '07 335i
My website....http://www.z3power.net
Ciao! - - Nathan
2000-2.8L Z3 StahlGrau Roadster (some mods) ~ 2001-335i (BONE STOCK!)
BMWCCA Tejas Chapter & iZ3 Project Coordinator for the San Antonio area
FEAR MY TWO SEATER!!!!!!!
Hello, I'm a MOD-A-HOLIC, check out my site to see my addictions! www.Z3POWER.net
Member Since May 17, 2002
Old 07-30-2010, 01:41 PM
Mike Clark Mike Clark is offline
Mike
Send a message via ICQ to Mike Clark Send a message via AIM to Mike Clark Send a message via Yahoo to Mike Clark
Mein Auto: 2006 BMW M Roadster
Recently inspected a 2000 M Roadster for sale for a fellow board member. As part of the inspection noted a problem with the temperature control which I think is becoming fairly common on the older cars that spend lots of time outside. Accordingly, I think this link is appropriate.
http://www.bimmerfest.com/forums/sho...+control+issue
Mike
2006 M Roadster Imola Red
2000 M Roadster Imola Red (gone but not forgotten)
1997 Z3 2.8 Roadster Red (gone but not forgotten)
2008 328i Sedan Gold
Old 07-30-2010, 02:04 PM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
I have invested in metal balls, taps, etc to fix this. I even bought a drill press to make sure the hole was straight.
If anyone wants me to fix their lever arm, they can mail it to me and I will repair and return it for $15.
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
Old 08-30-2010, 11:10 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
slk32 hasn't been around in a while, but this post from him should be in the FAQ since all of the Z3's suffer from the blend flap getting stuck and it's getting more expensive to deal with the consequences (broken flap control arm). What I mean is that instead of linking to it, it'd be nice to have it copied into the FAQ.
http://www.bimmerfest.com/forums/sho...5&postcount=11
Daniel
2002 M roadster
Old 10-01-2010, 07:59 PM
Z3PO Z3PO is offline
Mein Auto: 2001 BMW Z3 3.0i
Exclamation Everything TIS for Z3!!!!
Behold! The holy grail of repair documents for Z3! The BMW TIS Sheets!
CLICK HERE!!!!
2001 BMW Z3 - 3.0i - Hellrot II - 100% OEM; Down to the Tires (Dunlop 8080E)
Old 07-01-2011, 08:05 PM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
How to Install a Speedometer Calibrator
How to install a SpeedoDRD speedometer calibrator to fix a speedometer that reads too low or too high:
http://www.bimmerfest.com/forums/sho...d.php?t=551995
Old 08-21-2011, 07:26 AM
Zedfor's Avatar
Zedfor Zedfor is offline
Meinkugelschmerzen
Mein Auto: 2003 Z4, 2007 X3
From the Owner's Manual:
Emergency actuator
If the electrics or hydraulics fail, the soft-top can be raised/lowered by means of the emergency
actuator.
To raise the soft-top using the emergency actuator, the following procedure must be followed:
- Open bypass circuit on hydraulic pump unit by pulling cable.
- Release soft-top stowage compartment catch by pulling cable.
- Raise soft-top to windscreen top rail by hand.
- Engage windscreen top rail lock using Allen key.
For lowering the soft-top with the emergency actuator, the procedure is reversed.
Opening bypass circuit on hydraulic pump unit:
In the boot on the left-hand side below the soft-top stowage compartment base there is a
release cable with a plastic pull handle. The plastic pull handle is pulled out as far as it will
go and then locked in that position by turning it through 90º. This opens a bypass circuit
in the hydraulic pump unit. The soft-top can then be moved by hand.
(Note: If your hydraulic top motor is very corroded it is likely the bypass release handle will not release the bypass valve).
Emergency stowage compartment catch release
The soft-top stowage compartment catch must then be released. This involves pulling the
release cable on the rear boot trim panel. The soft-top stowage compartment catch then
disengages. The release cable is on the boot bulkhead. Pulling the release cable handle
from inside the boot releases the soft-top stowage compartment catch. The soft-top can
then be raised up to the windscreen top rail by hand.
Operating the windscreen top rail lock manually:
To lock the soft-top to the windscreen top rail, the plastic trim on the front roof bow must
be removed. Below the plastic trim panel is a socket-head bolt. Using the Allen key supplied
in the vehicle
If you don't know where you are going, any road will take you there.
ZSCCA
Old 11-28-2011, 09:39 AM
PerfectZ3 PerfectZ3 is offline
The Perfect 1996 BMW Z3
Mein Auto: 1996 BMW Z3
Changing a Slave Cylinder (OR BMW won't go into gear)
Ok I used this forum to help troubleshoot my 1996 BMW Z3 won't go into gear. I used my Blog to track troubleshooting the issue and then ultimately changing out the Slave Cylinder. Hope it helps someone.
BLOG is here. http://z3-bmw.blogspot.com/ and my Slave Cylinder Changout starts here
Thanks bimmerfest forums for helping me save a ton of money.
Old 11-28-2011, 10:18 AM
Mpire's Avatar
The Anti-Rice
Originally Posted by salvy66 View Post
I am looking at a 2002 M Roadster.
It ran fine and nothing was heard while driving the car.
While standing on the curb, as the car was driven away a tinney sound was heard as it
was wound up through the gears.
Any clue as to what that sound was or what caused it?
Thanks,
Al
Its probably the rasp caused by putting the cats inside the engine bay instead of under the car where they belong.
Also, a contributing factor is that we don't get the resonator they install on the euro cars.
Its normal for the S54.
If you heard a banging or a stumbling then that's a different story.
Old 01-31-2012, 12:39 AM
turbo10325 turbo10325 is offline
Mein Auto: Z3M
1998 Z3M S52 Water Pump, Thermostat, Belts, and Hoses Replacement
Recently replaced the water pump, thermostat, belts, and hoses on my Z3M. Documented the procedure and some helpful links.
https://sites.google.com/site/turbo10325/home/waterpump
Old 01-31-2012, 12:50 AM
Mein Auto: Z3M
Door Panel Removal (Slow Power Windows Fix) 1998 Z3M
Removed the door panels on my Z3M to fix the power windows. Documented the procedure.
https://sites.google.com/site/turbo10325/home/doorpanel
