E28 (1982 - 1988)
Old 01-18-2009, 09:14 AM
jvaughn21 jvaughn21 is offline
Mein Auto: 1988 E28
Go Fast Parts?
So, i'm anticipating a fairly decent tax return this year, and i was wondering if anyone had any advice on the best way to spend about 500-800 dollars performance wise. I have a 88 ETA.
Old 01-19-2009, 07:20 AM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
There is nothing that you can do to your car "perfomance wise" except turbocharging it and it will take much more than that. The other non-turbo option is to do an e-to-i conversion and since you already have a 'super' eta it should be a little bit easier. It will also consume a little bit more money though! Do a search on it on other sites (mye28.com)
Good Luck!
Jimmy Moreno
1995 530i
1986 535i
Old 01-19-2009, 01:51 PM
Mein Auto: 1988 E28
Gotcha, so i need a 3.4 short block?
And do you have any figures on how much power i can get from an upgraded exhaust, including replacing the header?
Old 01-21-2009, 08:33 AM
Mein Auto: 2006 X3
Nope. The "e-to-i" conversion uses parts from the 325i engine since the 325e/528e use a lower revving version of the engine which has more displacement (2.7 vs. 2.5) but lower power (but higher torque!) It involves using the intake manifold, cam, valves springs and some other parts to come up with a stronger, torquier engine. You will also need a special ECU chip for this. Checkout this page for detailed information.
Jimmy Moreno
1995 530i
1986 535i
Old 01-21-2009, 08:40 AM
willysully's Avatar
willysully willysully is offline
Mein Auto: 1995 325i
If you are building a high reving motor better get solid rocker retainers or you'll brake a rocker arm.
Keep the shiney side up!
