E30 (1982 - 1993)
Old 03-30-2008, 12:42 PM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
Originally Posted by Mike_Check View Post
I thought this was a sticky...not a q/a forum...
Shouldnt you be chasing genetic throwbacks? Or something?
Old 03-30-2008, 08:48 PM
Mike_Check Mike_Check is offline
Account close at users request
Mein Auto: .
Old 04-06-2008, 10:44 AM
CAGRacing CAGRacing is offline
Mein Auto: 86' 325e 348,729 miles
I've got a helpful one on windows
none of mine worked when I got it
remove the handle trim (slides towards back of car) remove lock button.roll down window manually. Unscrew armrests slowly remove door panel.
now slowly peel back inside plastic and if its already torn someone else already jacked with your car. Watch for black mold here to.
now wd-40 window lifting mechanism and roll window up. Wd-40 mechanism again. Roll window down. Repeat 5 times then try the switch. In the back the door switch has to be plugged in to complete the circuit.
if no luck from switch then disassemble switch and scrape off corrosion with flat head screw driver. Wd-40 reassemble reinstall
I saved my self $125 per assmebly plus $25 switch per window. That's $600!!!This is a good time to move around the snaps on the door panel and move some from the back or less used door to the driver side as to help it stick on better
Old 04-06-2008, 10:49 AM
Another relatively easy fix is the electric antenna
if it does not extend/retract fully then undo the bolt outside the car holding down the antenna
Pull apart antenna and wd-40 everything very well and work antenna back and forth until it will collapse and open under its own pressure
now to the "collar" this needs to be wd-40 also and bend back the tabs jus barely enough to let the antenna drop down under its own weight
reinstall
Old 04-06-2008, 10:55 AM
Loose E-brake fix
Remove e brake boot. Remove surrounding console (bolt under ashtray) there are 2 bolt that secure the e brake line. One for each side.
release e brake and see how much the bolts move forward with slack
now tighten bolt til there is a tiny amount of tension then back off til there's 1mm of slack. Reinstall everything. Then end
If you cannot sufficiently tighten fromthis point the you need to life the rear of the car on jacks. Remove one lugnut from each side. Rotate rim until empty hole aligns with star opening behind hole. You will need to insert a screwdriver and twist til there is tension and the brake is partially engaged. Then back off quarter to half a turn
all done
The e brake should be fully engaged at 6 clicks and should not be lifted past 8 clicks
mine went to 14 and some and I was able to cure mine with just the adjuster bolts under the boot
Old 04-13-2008, 08:24 PM
Heineiken Heineiken is offline
HEINEIKEN
Mein Auto: 1987 325
Radio Swap
I saw the thread, but the link wasn't available any longer. Any where else to look?
The only "smokin" I like
Old 04-16-2008, 11:07 AM
Gurra Gurra is offline
Mein Auto: E30 M3
E30 Specifications:
Model, HP, 0-100 (Km/h), Topspeed (Km/h)
1983
318i - 102hp 11,2s 183km/h
320i - 125hp 10,4s 196km/h
323i - 139hp 9,2s 202km/h
1984
318i - 102hp 11,2s 184Km/h
323i - 139hp 9,2 202km/h
1985
318i - 105hp 11,2s 184km/h
323i - 143hp 9,1s 202km/h
1986
Alpina B6 - 210hp 7,0s 230Km/h
1987
318i - 105hp 11,8s 184km/h
320i - 129hp 10,2s 195km/h
325i - 170hp 8,3s 215km/h
325iX - 170hp 9,2s 210km/h
325iC - 170hp 8,7s 214km/h
M3 - 195 6,9s 230km/h
1988
318i - 105hp 12,1s 182km/h
318iS - 113hp 10,8s 188km/h
320i - 129hp 10,6s 197km/h
325i - 170hp 8,3s 218km/h
325iX - 170hp 9,2s 212km/h
325iC - 170hp 8,7s 216km/h
M3 - 195hp 6,9s 230km/h
1989
316i - 100hp 12,1s 182km/h
318i - 113hp 10,8s 188km/h
320iC - 129hp 11,5s 195km/h
320iT - 129hp 11,5s 196km/h
325iT - 170hp 8,8s 214km/h
325iXT - 170hp 9,7s 208km/h
Alpina B6 - 254hp 6,6s 246km/h
1990
318iT - 113hp 11,7s 188km/h
318is 16V - 136hp 9,9s 202km/h
320iC - 129hp 11,0s 195Km/h
M3 - 215hp 6,7s 241km/h
M3 SE - 254hp 6,7s 248km/h
1991
1992
316iT - 100hp 13,9s 179km/h
318iC - 113hp 12,0s 187km/h
1993
Hope thats readable =)
Old 05-30-2008, 09:42 AM
MasMore MasMore is offline
Mein Auto: 1985 325e 5 Speed Rwd
how about a walk trough on oil pan replacement?
The more you give it! The more you become it!
Photobucket
Old 07-08-2008, 11:35 AM
bgavares bgavares is offline
My wife hates BMW's
Mein Auto: 1987 325 IS
Maybe how to get the shift knob off in the first place?
Old 07-08-2008, 11:36 AM
Banned
Mein Auto:
Pull on it directly up.
Seriously.
Old 07-17-2008, 05:41 AM
Qbrozen Qbrozen is offline
Mein Auto: '00 540i 6-speed
hmmm... service light reset?
I know there was a DIY writeup around here somewhere.
Edit: found it:
http://www.unofficialbmw.com/repair_faqs/sil.html#reset
Old 08-10-2008, 06:27 PM
cmac2012's Avatar
cmac2012 cmac2012 is offline
Renaissance Dude
Mein Auto: Two 1987 325i, 430K, 211K
Good thread. I hate to admit that a few years ago when I was sorta green on vacuum leaks, I was looking all over for one with no luck. Later a fellow came by to buy something I had on Craigslist, he was there before me and he heard my engine on the way up. Turns out he and his dad are E-30 o'philes, we got to talking and he said "why-oncha pop that hood and start it up again." I got out the carb cleaner and it was the biggest possible source of vacuum leak -- the intake manifold gasket!
Oopsie.
Idles just fine now.
Old 08-17-2008, 07:30 PM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
remove radiator, loosen motor mounts, buy 10mm ratcheting wrench with flex head, spend 1.5-2 hours taking out tons of 10mm bolts. If you have an auto there is a plate to remove on the trans bellhousing to get the last few bolts. those are T7 torx bolts but a 7 or 8mm socket will get them off. Reinstallation is reverse of removal.
Old 09-28-2008, 12:01 AM
Edev's Avatar
Edev Edev is offline
BMW Genius @ BMW Portland
Mein Auto: M Coupe
Seriously.
ahhhhhhh hahahahahahahahah.
eh hem...
hahaha.
BMW Genius @BMWPortland.
2000 Z3 M Coupe
Old 10-20-2008, 08:48 AM
jeffie8696 jeffie8696 is offline
Mein Auto: Bmw 325i
Leaks in the vaccum lines under the intake are very common. Mine were just plain falling apart. Also the vaccum hose from the valve cover is prone to cracks from old age and valve adjustments. Hope this helps.
Old 10-23-2008, 09:12 AM
NJROB76 NJROB76 is offline
Mein Auto: 1991 325 i convertible
Link for timing belt replacement does not work. Anybody have instuctions?
Old 10-23-2008, 09:15 AM
Banned
Mein Auto:
There is a sticky that is the E30 maintenance manual. Id start there.
Also, a Bently manual is invaluable and pretty cheap nowadays.
Old 10-23-2008, 09:18 AM
Thanks for the help
Old 11-17-2008, 09:35 AM
cornercarver cornercarver is offline
Mein Auto: 1999 M3
I've got an '83 UK 323i here in the states. The 6 cylinder.
Where can I find information on the fuel pump, fuel relay, or fuel injection system for that model?
Or do you know how to troubleshoot those so I can figure out how to get it running again?
Old 12-30-2008, 12:47 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
E30 DIY Links
Everything from dashboard swaps to timing belt replacement
A big THANK YOU to the folks who documented the processes and procedures necessary to keep our E30's on the road and looking good
Pelican Parts Technical Articles
Bimmer DIY
E30 BMW DIY
BMW Tech Tips
Please add links and grow this thread into a comprehensive E30 DIY source
I Timothy 2:1-2
Old 12-30-2008, 06:51 PM
JohnMadd's Avatar
JohnMadd JohnMadd is offline
obsessed
Mein Auto: 1989 325is 03 330i ZHP
I just paid to have mine done, but here is a good link on rear subframe bushings.
http://www.unofficialbmw.com/repair_faqs/subframe.html
Even tells you how to make a homemade tool for the job.
Old 01-03-2009, 04:33 PM
JohnMadd's Avatar
obsessed
Here's another.
http://e30world.com/
Old 01-03-2009, 05:16 PM
an audience of One
Originally Posted by JohnMadd View Post
Here's another.
Good stuff, John Thank you.
I Timothy 2:1-2
Old 01-11-2009, 10:38 PM
Edev's Avatar
Mein Auto: M Coupe
http://www.e30clubsa.co.za/forum/ind...showtopic=4594
Here's one to remove your cluster. I'll probably do this sometime in the very near future.
2000 Z3 M Coupe
Old 01-22-2009, 08:02 AM
Lars_5687 Lars_5687 is offline
Send a message via Yahoo to Lars_5687
Mein Auto: E30
Cool Vacuum leaks :-/
So my cars got some miles on her around about 500k but hey shes still stock and ran great til i hopped in and she didnt want to idle and after i revved her up to 3 grand she cleared up now its a constant miss Anyways heres a few things going on.......in 5th gear at 2500 rpms i can let out of it and see the economy gage go near 40mpg and it sounds like shes cuttin out I dunno the only thing i can figure is a vacuum leak to happen in one night
bmw diy, bmw do it yourself, e30 diy, e30 do it yourself, m50 e30
Similar Threads
The official "alee sucks thread" sucks thread nate Off-Topic 22 06-03-2004 03:37 PM
Official Count @ Bimmerfest? manik///m3 General BMW Questions 3 04-22-2002 02:23 PM
official party hotel for bimmerfest ???? jAb General BMW Questions 5 04-18-2002 04:26 PM
It's official, Bimmerfest is no longer utopia Spiderm0n Off-Topic 32 04-17-2002 06:06 PM
