E30 (1982 - 1993)
Old 01-22-2009, 09:31 AM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
Originally Posted by Lars_5687 View Post
So my cars got some miles on her around about 500k but hey shes still stock and ran great til i hopped in and she didnt want to idle and after i revved her up to 3 grand she cleared up now its a constant miss Anyways heres a few things going on.......in 5th gear at 2500 rpms i can let out of it and see the economy gage go near 40mpg and it sounds like shes cuttin out I dunno the only thing i can figure is a vacuum leak to happen in one night
Could be a few things. Id start by checking the O2 sensor and AFM.
Old 01-22-2009, 01:39 PM
Lars_5687 Lars_5687 is offline
Send a message via Yahoo to Lars_5687
Mein Auto: E30
Well i played with the distibutor and i got a lil better timing now its not a "sputtery" but now I lose HP at 3 grand and it wont Idol..ive replaced half the vacumm lines i could see im prolly missing the key one
I will never die for I drive with the angels BMW E30
Old 01-27-2009, 08:06 PM
JohnMadd's Avatar
JohnMadd JohnMadd is offline
obsessed
Mein Auto: 1989 325is 03 330i ZHP
Here is one I found hidden in my bookmarks.
http://www.unofficialbmw.com/e30.html
Old 01-28-2009, 07:14 PM
baaaaaaa baaaaaaa is offline
Mein Auto: 1991 BMW E30 325i
I've got a manual 325i that has a problem where the engine cuts out at around 5200 rpms. I do not think the tac is off becuae it started to occur a few months ago and feels like it may also be losing a little power. It does not stall or anything but won't go past this point. It does this in just about every gear and does not do it if you slowly accelerate up past this point. It mainly just doest if if you hammer it or floor it. I have done alot of work to this car lately and really am stumped about this problem. The things I've done to it this summer include dinan chip, scorpian exhaust, k&n intake, oxygen sensor, thermometor, manifold gaskets and more. I am suspecting that it could have to do with the ignition like distributer cap and rotor.
Anybody had this problem or got any ideas whats wrong
Old 01-28-2009, 09:48 PM
E30-325's Avatar
E30-325 E30-325 is offline
Mein Auto: BMW 325is
could it be your throttle cable? needs adjusting?
Old 01-28-2009, 10:00 PM
Banned
Mein Auto:
Yeah, your engine isnt running properly. Its running out of air, fuel, and /or spark. A properly running engine should bounce off the Rev limiter if desired.
Since you bring up distributer cap, have you looked or changed it? Thats a 15,000 mile at best tune-up item. Have you checked timing? How about compression? Looked at the spark plugs? How about vaccum leaks?
Start with the basics and rule them out. Once you do that make a new thread and ask your detailed question. This is the FAQ thread which is more a place for answers, not questions.
Old 02-02-2009, 09:19 PM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Originally Posted by NJROB76 View Post
Link for timing belt replacement does not work. Anybody have instuctions?
Wow that took so little effort it is not even funny...
http://www.bmwe34.net/Wiki/tiki-index.php?page=M20+timing+belt
Old 02-11-2009, 11:32 PM
bughaus bughaus is offline
Mein Auto: 1986 325es
Question
Originally Posted by SWISS View Post
remove radiator, loosen motor mounts...
anyone know is there a way to lift the engine yourself in order to get the pan out? Maybe a video post of this? (I can vouch for 2 painful hours of bolt loosening.)
Old 03-11-2009, 11:23 PM
olde30srule olde30srule is offline
Mein Auto: e30
Bringing this over from the other thread, Categorized E30 DIY Links
www.bimmerdoityourself.com/e30_3.html
Old 04-07-2009, 11:18 AM
tantifheroz tantifheroz is offline
Mein Auto: many cars.
EDIT:
nvm, i just started a new thread about this.
Old 04-13-2009, 12:47 PM
AbqDave AbqDave is offline
Mein Auto: X3, R1200R
Bottom of dipstick tube. On my 91 325x, there's a short length of hose that connects it to the pan. Had to tighten up the bottom hose clamp.
Old 04-19-2009, 05:59 PM
s.mccall s.mccall is offline
Mein Auto: bmw
Question 87 is hard start when warm, and slight miss?
hey fella's my I.S, starts right up when its cold but when i drive, stop and restart its takes longer cranking to start her again ,plus the idle's not smooth. i read about fuel enchrichner and how it works.the resestance seems within range. i've checked for vacume leaks etc. now i'm checking the fule systems. any sugestions.?
Old 04-30-2009, 03:09 PM
wmbath wmbath is offline
Mein Auto: 1994 530it & 1994 525it
wmbath question
in my vin 11th digit is a number ( 9 ) ,instead of a letterhttp://www.bimmerfest.com/forums/images/smilies/iono.gif
Old 05-08-2009, 01:59 PM
mstr_sensei_e30 mstr_sensei_e30 is offline
Banned
Mein Auto: an old e30
i know that a major source of vacuum leaks are holes in the vacuum lines.
Old 05-11-2009, 06:45 AM
88325 88325 is offline
Send a message via Yahoo to 88325
Mein Auto: 1988 325e
I had a problem with an irregular idle so i took carb cleaner and an old tooth brush and scrubed from the throttle body to the air box inside and out and now she purrs like a kitten
Old 05-12-2009, 11:30 AM
JustinMicWilsey JustinMicWilsey is offline
325e Driver
Mein Auto: 1985 325e
Exclamation
anybody have a link for how to change the flex disc??? i really need to change mine. They gave me a quote at a shop for $176 in labor for a part i can get for $40, so i think if its not too difficult i could save myself some money.
Old 06-12-2009, 10:17 AM
facotaco facotaco is offline
Mein Auto: 1987 bmw 325
someone should post about a strokers. that seems to be common
Old 07-30-2009, 06:54 PM
533-3.8 533-3.8 is offline
Mein Auto: 1988 325ix '88 325ix
The purge valve for the charcoal canistor, if your model has this. It's located under the throttle body behind the TPS and I found the leak by squirting carb cleaner under the throttle body. The hose was toast and looked expensive, just pull it of and use regular hose and clamps.
Old 10-30-2009, 10:36 PM
JohnMadd's Avatar
obsessed
This is good stuff bump.....bump
Old 10-31-2009, 01:42 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
this is a sticky. you dont need to bump it as it chills at the top of the forum anyways haha
E30 above Sold
Last updated 2nd January 2014
Old 11-05-2009, 03:41 AM
euromech euromech is offline
Ben
Send a message via MSN to euromech Send a message via Yahoo to euromech
Mein Auto: 635,x-type, range rover,
If you think you might have a vacuum leak, just remove the oil filler cap while it is running. This will give a massive vacuum leak as the engine breather system runs under vacuum. If you notice a huge change, then you are not looking for a vacuum leak. Spraying carb cleaner around to find a leak is good, but keep a fire extinguisher handy just in case. Do not be tempted with brake cleaner, as a lot of the new brands are non-flammable and so will not give the desired result. Please don't use easy-start, you may well lose your car....and house....and wife.....
Old 11-18-2009, 11:40 PM
snookay snookay is offline
Mein Auto: E30 325is
i assumed i had a vacuum leak because i couldnt idle without giving it constant gas. I fixed a bad pipe and it idles better, slighly. could another leak create high RPMs? i ask before i replace the valve cover gaskets.
oh yeah, i should keep a fire extinguisher close by if im spraying the engine with Carb Cleaner. plz say it aint so lol
Old 11-19-2009, 02:43 AM
i keep a fire extinguisher in my car at all times. the only time that it ever moves is when im using the angle grinder whereby i take it out and keep it handy. you can never be too careful
E30 above Sold
Old 12-15-2009, 07:10 PM
E30Dallas E30Dallas is offline
I get in and rock wit it!
Mein Auto: e30 325
Me like it! great stuff dudes!/and girls IF ANY! helps alot even if u dont have to fix anythin...just helps when you get stuck out on the road with two kids and a wife that i dont have but ive been there wit my parents wheni was yound a baby back in 91' lol! ...great times on a 72' ford F150...
Old 12-19-2009, 09:03 AM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
http://members.dodo.com.au/~wawawa/e30index.htm
CAI
2.7i
MegaSquirt
iDrive
Armrest
Rev Calculator
I like the rev calc
I Timothy 2:1-2
bmw diy, bmw do it yourself, e30 diy, e30 do it yourself, m50 e30
Similar Threads
The official "alee sucks thread" sucks thread nate Off-Topic 22 06-03-2004 04:37 PM
Official Count @ Bimmerfest? manik///m3 General BMW Questions 3 04-22-2002 03:23 PM
official party hotel for bimmerfest ???? jAb General BMW Questions 5 04-18-2002 05:26 PM
It's official, Bimmerfest is no longer utopia Spiderm0n Off-Topic 32 04-17-2002 07:06 PM
