E36 (1991 - 1999)
I was wondering if anyone knew of an online or happened to have a .pdf for a 95 318i owner's manual?
just got my first bimmer the other week and it came with a supplementary owner's manual? but not all the information i need is in there my buddy is trying to hook a sub up for me and i need the radio wire diagram, so i know what colors mean what any help would be greatly appreciated! |
1994-95 BMW 318i
Six-Speaker System FUNCTION PIN WIRE COLOR Accessory 12 Volt 5 VT/WT Constant 12 Volt 9 RD/WT Chassis Ground 15 BN Power Antenna 16 WT Remote Illumination 13 GY/RD Dimmer FUSE VALUE FUSE LABEL FUSEBOX LOCATION 15 AMP #44 DRIVER'S SIDE UNDER HOOD 20 AMP #9 DRIVER'S SIDE UNDER HOOD The front tweeters are wired in parallel with the front woofers. Left Front Spkr + 1 YW/RD Left Front Spkr - 8 YW/BN Right Front Spkr + 2 BU/RD Right Front Spkr - 11 BU/BN Left Rear Spkr + 3 YW/VT Left Rear Spkr - 12 YW/GY Right Rear Spkr + 6 BU/VT Right Rear Spkr - 14 BU/GY Cell Phone Mute 4 WT/BN Vehicle Speed Sensor 10 BK/WT Back to top -------------------------------------------------------------------------------- Ten-Speaker System FUNCTION PIN WIRE COLOR Accessory 12 Volt 5 VT/WT Constant 12 Volt 9 RD/WT Chassis Ground 15 BN Power Antenna 16 WT* Remote Illumination 13 GY/RD Dimmer FUSE VALUE FUSE LABEL FUSEBOX LOCATION 15 AMP #44 DRIVER'S SIDE UNDER HOOD 20 AMP #9 DRIVER'S SIDE UNDER HOOD *The WT wire triggers both the antenna booster and the ten-speaker amplifier. Left Front + to Amp 1 YW/RD Left Front - to Amp 8 BN/OG Right Front + to Amp 2 BU/RD Right Front - to Amp 11 BN/OG Left Rear + to Amp 3 YW/BK Left Rear - to Amp 12 BN/OG Right Rear + to Amp 6 BU/BK Right Rear - to Amp 14 BN/OG Cell Phone Mute 4 WT/BN Vehicle Speed Sensor 10 BK/WT Back to top -------------------------------------------------------------------------------- Amplifier Wiring INPUT SECTION FUNCTION WIRE COLOR Constant 12 Volt RD/WT Amp Remote WT Chassis Ground BN Left Front + Input YW/RD Left Front - Input BN/OG Right Front + Input BU/RD Right Front - Input BN/OG Left Rear + Input YW/BK Left Rear - Input BN/OG Right Rear + Input BU/BK Right Rear - Input BN/OG OUTPUT SECTION FUNCTION LOW-RANGE MID-RANGE HI-RANGE Left Front Spkr + YW/RD YW/WT YW/GN Left Front Spkr - YW/BN YW/BN YW/BN Right Front Spkr + BU/RD BU/WT BU/GN Right Front Spkr - BU/BN BU/BN BU/BN Left Rear Spkr + YW/GY YW/VT Left Rear Spkr - YW/BK YW/GY Right Rear Spkr + BU/BK BU/VT Right Rear Spkr - BU/GY BU/GY |
Ah, seek and ye shall find. This is just what I am looking for.
I picked up a new blootueth phone kit today off a mate and obviously would like it to mute the stereo when in use. Does anyone know whether the mute wire should be taken high or low to activate the function?
"The Reclinermobile" - 1995 320i Boston Green A word on our sponsors: Iridium sparks thanks to NGK. Wheels will shortly be dressed once again by Yokohama C-Drive. Road is lit by Eagle-Eye 6000K HID, supplemented by 7000K CCFL Angel eyes. HB/Fog have selected to go with Philips 4000K BlueVision. Engine parts choose to slip with Castrol's 20-50 GTX2 dinosaur slime, renewed every 10,000km. |
*bump*
Or for that matter, how to even get to the wiring? I can't see how the stock stereo comes out. If the wiring loom came out somewhere else I could access the mute wire, that would be good too.
hey welcome to the forums, first of all if no one told yo uabout this there is a search button and theres alot of DIY about taking somesort of the radio out.. ill jus tell you now, there are gunna be 2 bolts on the sides of your radio take those 2 out and all you need to do is pull it out.
http://cgi.ebay.com/ebaymotors/BMW-C...Q5fAccessories
if you scroll all the way down to the pictures, it should tell you where the bolts are at. and only use the first picture in the link. |
| Tags |
| 318i, diagram, manual, subwoofer, wire |
