Old 02-03-2009, 08:48 PM
DENNESSY's Avatar
DENNESSY DENNESSY is offline
Mein Auto: 2002 525i
hey fellas a lil help with a part
whats the plastic inside the wheel well called...ive been trying to look for em cuz the ones that came with my car were already messed up which means my front bumper cant be screwed on all the way cuz there broken where u screw it on.....and if so where can i find em..?
Old 02-03-2009, 09:24 PM
BlackBMWs's Avatar
BlackBMWs BlackBMWs is offline
Check twice, fix once...
Mein Auto: 540it 533i 318ic 325i
Pictures or diagram reference from RealOEM please...
1999 540it - Jet Black/Sand Beige, style 5 rims, Zionsville Cooling kit
1984 533i - Schwarz/Schwarz, 17" style 65 reps
1997 318ti Sport - Schwartz II/Schwartz Anthratz, style 68 rims
1995 318ti Sport - Schwartz II/Schwartz Anthratz, style 27 rims
1994 325i Sedan - Bostongrau/Tan
1991 318ic - Schwarz/Anthratz Stoff
1985 635CSI - Schwartz\Sand - Sold
1984 318i - Champagne/Tan, Stock - Sold
BMWCCA# 160411
Old 02-03-2009, 10:20 PM
Waveho Waveho is offline
Mein Auto: '07 335xi 6MT 4door
Wheel well cover/splash guard. Go to www.realoem.com and search for the part number. I suspect it will be dealer-only (pricey), so better to find a junk yard and make an offer. Often folks are parting out wrecked e39s on ebay. Good luck.
'07 335xi 6-spd 4dr, Montego blue
'98 540i 6-spd Sport, Jet Black II(sold)
'92 325i 5-spd 4dr, burgundy(sold)
Old 02-04-2009, 06:27 AM
ZeroDfx's Avatar
ZeroDfx ZeroDfx is offline
Mein Auto: 2000 528iT
I've always known/described that part as the wheel well "liner". They used to run about $35 at the local dealer, but they don't always have them in stock. Be sure to order the clips to secure them to the front liner based on what you're describing.
Nick
2000 528iT sport (Sienna Red w/ Tan)
2000 540i/6spd (Sienna Red / Tan)
Old 02-04-2009, 06:33 PM
DENNESSY's Avatar
Nick
yeah i actually checked my car and one is damaged and when they re painted my front bumper i guess they tossed the other one from the drivers side which is weird heres a pic from another thread started in the past...just need to know what there called... thanks again fellas
Photobucket
Old 02-04-2009, 07:08 PM
jieg jieg is offline
Ivan
Send a message via MSN to jieg
Mein Auto: 525i 2003
you will find the parts on sections
51 vehicle trim then
75 mounting parts engine compartment then
air duct section
seems your part numbers are
LOWER RIGHT ENGINE COMPARTMENT cover with brake air channel part number 51712694832
left side 51712694899
I just had them changed
---------------Ivan
Old 02-04-2009, 07:10 PM
mosearch mosearch is offline
Mein Auto: 528i, Y2K
Just bought those 2 parts myself. They are cheap enough from the dealer; about $20.00 each, that it does not make sense to order them from Pelican...unless that's more convenient for you. For a year 2000 528i, they are part numbers 51-71-8-159-425 and 51-71-8-159-426. Your numbers for your later model 5 series might be different. They are called Fender liners; lower left and lower right.... Pelican does list them; about $15 each.
Old 02-04-2009, 07:30 PM
Ivan
Originally Posted by mosearch View Post
Just bought those 2 parts myself. They are cheap enough from the dealer; about $20.00 each, .
+1, they are cheap, I did not know and my ex (now) mechanic charged me 40 each
---------------Ivan
Old 02-04-2009, 07:55 PM
Mark@EAC Mark@EAC is offline
Past Sponsor
Send a message via AIM to Mark@EAC
Mein Auto: e39 5
my 528i ate those things up a lot when I was running 18 x 8.5 up front.
Past Sponsor
Mein Auto: e39 5
mechanics always mark up parts. That is why DIY is the cheapest way to go.
Old 02-05-2009, 05:38 AM
Good info. I hadn't realized they would be relatively cheap from the dealer, even on special order. The PO of my car apparently had an issue once and the inside trim of one wheel must have popped off and the wheel cut a swath through it; might actually get this replaced!
Old 02-05-2009, 09:00 AM
DENNESSY's Avatar
wow that is cheap yeah i was gonna take my ass to the junk yard but those are usaually out of the way here in houston....ill give the dealer a call....thanks bud ur info is really gonna save me a buck..
Old 02-05-2009, 10:00 AM
Adrian H's Avatar
Adrian H Adrian H is offline
"Wait... What's this do?"
Send a message via AIM to Adrian H
Mein Auto: 1997 528i
I replaced all the wheel wells on my car when I accideintally managed to pull off the front bumper while backing in. Yeah. Figure that one out. Was about $50 said and done for the parts and screws
05/1997 Alpine White 528i Debadged, Intake Muffler Delete [Sold, Died of the E39itis]
Current - 07 Hyundai Accent, The Family Car!
Originally Posted by taylormiles View Post
Heh. Well, you should know if its a touring. It would have a very large badonkadonk.
Old 02-06-2009, 12:10 PM
Ivan
he told me in good faith that he does not mark up parts; I said to my self, they just make the labor a little more expensive. For labor charged $50, now that I am changing the tension armīs bushings I know is a very very simple job.
I learned my lesson the hard way; so I paid 150 instead of 40 had I done it myself.
---------------Ivan
