#26
...yes, but the DME doesn't pass all the info down to ODB2 (vs MODIC), and a MODIC3 system is $,$$$.
#27
#29
:asshole:
Maybe I should leave...and never come back.
Exactly. So pretty much the OBDII solution is not feasible, thus bringing us back to point one with getting a sensor directly into the transmission pan.
_______________Going to Bimmerfest East AND West ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
#31
Well I think the question hasn't been verified that ODB2 doesn't give the info. I've got an ODB2 reader, but manual trannys typically don't have temp sensors like autos do.... I'd need to plug my autoenginuity into an auto to test.
#32
Very good Kris. Is it possible to run the car through a BMW diagnostic system to give such info? As compared to say a module that runs through the OBDII port? Meaning that the BMW direct system gives ALL parameters that can possibly be given as compared to the OBD tool that was on page one that can miss certain readings.
#33
The newer Autoenginuity with the enhanced protocol compatibility can see it: http://www.autoenginuity.com/BMW-All...missionEGS8602 ..but it looks like it's not included in standard ODB2. Bummer. |
#34
Hmm, must have gotten mixed up. I was sure that you had written about having a ScanGauge installed under your rear view mirror.
2006 325Ci |
#35
God please do.
Nope, not I.
#37
He does have his radar detector there though.
AHA! I was sure there would be some geeky gizmo under there...
2006 325Ci |
#39
I saw a video of him starting his car up, sounds like a spaceship start up sequence.
All this OBD2 talk is making my head hurt. Mechanical gauges have SIGNIFICANT advantages in a project like this. Mainly, it either works, or it doesn't. But also, easy install, faster, cheaper, and simple. In the time you spent to make this thread, you could have ordered the parts and been almost ready to install.
#41
To purely see temp, drilling would be the best way, but tapping into sensors that the car already uses for input can provide you more valuable information IMO. |
#44
SLIM, if you do this, send me the DIY...... |
#45
![]() E36 DIYs: Air Pump | Vent Gauge | E46 Armrest | SmarTire TPMS E46 DIYs: Hella TPMS | Aftermarket Horns | Window Regulator Notes | Trunk Wire Harness | Trunk 12V Socket |
#47
Also found these vendors while browsing...the side-by-side product comparisons on the DashDAQ site are interesting, for what they are worth.
http://www.dashdaq.com/ http://www.dashhawk.com/
![]() E36 DIYs: Air Pump | Vent Gauge | E46 Armrest | SmarTire TPMS E46 DIYs: Hella TPMS | Aftermarket Horns | Window Regulator Notes | Trunk Wire Harness | Trunk 12V Socket Last edited by G. P. Burdell; 02-28-2009 at 11:34 AM. |
#48
Nice... you're a clueless noob and you have the nerve/balls to call a mod (who knows his stuff) an a$$hole.
Grow up.
Don't care how old he is. He needs to learn to throttle his pie hole and respect authority/mods.
At 16, had I made some of these comments, my old man would have a boot up my arse. And rightly so.
