Old 03-04-2009, 08:37 PM
speedemn speedemn is offline
Mein Auto: 2003 540i 6-spd
MID backlight problem???
I have a 2003 540i ... it has the 20-character display for the CCD.
A couple of days ago I noticed that the right half of the CCD went dim as if there is a backlight that has a dead bulb. The pixels themselves are lit up and legible but the right half of the CCD looks like it is missing a back light (if one exists) and the left half of the CCD looks normal.
I snapped a couple of pics with my cell phone camera in the daytime to illustrate. Hope the pics aren't too crappy and are able to convey what I am trying to describe. One pic was taken in the day time and the other at night on my way home.
Does the MID have backlighting? Are they bulbs that can be easily replaced? From the looks of it, it looks like 2 bulbs for the 20-character display unit. Does anyone here know for sure what the problem might be?
ID:	176643   Click image for larger version
2015 M5 Competition+Ultimate Package black sapphire on champagne
2003 540i/6 black sapphire on black
BBS RG-R, CDV, Dinan Exhaust, Dinan RSB, Dinan RSTB, Dinan SSK, Dinan FSTB, Dinan CAI, Dinan TB, Dinan MAF, Dinan stage 4 software
BMW 13th gen ULF Bluetooth, BMW Sirius, Dice Silverline iPod
Dynocom numbers: 320HP, 420LB.FT TQ (crank)
Old 03-05-2009, 11:06 AM
jfmjr442 jfmjr442 is offline
Mein Auto: 1997 328 ic
yes the bulbs can be replaced. Requires removal of the cluster - which is easy. Best to replace all when you are there. I believe there are 2 - search cluster removal or dash trim rings for DIY on cluster removal. Then take the bulbs to your local dealer for replacements.
John
Old 03-05-2009, 11:30 AM
Looks like 5 bulbs... ?
http://www.realoem.com/bmw/showparts...09&hg=62&fg=05
02 BULB 12V 1,5W 5 62111391260 $2.68
Old 03-05-2009, 12:09 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Originally Posted by speedemn View Post
I have a 2003 540i ... it has the 20-character display for the MID.
Ditto what jfmjr442 said...check for burnt out bulbs.
Just for clarification...that display on your instrument cluster is NOT the MID...it's affectionately referred to as the CCD (Check Control Display) since it is the display designed specifically for the Priority 1 and 2 warnings....and that's why any other info that appears in this display gets removed IMMEDIATELY if the Check Control System requires to communicate with you.
The MID is the multi-informational display (used for cars without NAVIGATION) that is used to access the AUDIO/OBC/CLOCK/PHONE functions.
(this is what the MID is...although this is the MID from the e38...you get the gist )
Q {BMW CCA Member #191509}
(SOLD)
Old 03-05-2009, 02:14 PM
Oops! My mistake... thanks for clarifying.
Old 03-05-2009, 08:58 PM
x2nervisx x2nervisx is offline
BMW's are cool
Mein Auto: 1995 M3 & 2000 540i
I have the same problem except mind is actually in the MID not in the cluster. Do those take replaceable bulbs as well or is the MID non serviceable?
Old 03-06-2009, 01:36 PM
QSilver7's Avatar
Are you sure the issue is burnt out back lighting...or is it pixel degradation?
There's a difference...and the MID does NOT have replacable incandescent bulbs like the instrument cluster. If there are any incandescent bulbs in the MID...they are soldered in. You would have to open it up and desolder the old and replace with new (if back-lighting is the issue).
If the problem is missing pixels (pixel degradation)...it will look like the image below...and if that's the case...either a replacement MID is in order or you can try the OFT TRIED write-up...look for it in the DIY or FAQ threads...or look for a write up on www.bmwtips.com or www.e38.org/e39 :
(image below is from this website: http://www.northernautotech.co.uk/pixels.html )
(SOLD)
Old 03-06-2009, 07:17 PM
BMW's are cool
it's definitely not the pixels just yet. I can see all the pixels fine. It's just station presets 1 and 2 are dim.
Old 08-21-2009, 12:29 AM
richardm1981 richardm1981 is offline
Mein Auto: 1999 528I
Weird problem with a 1999 528i
Same problem here with the MID display where they are not dead pixel but more like dimmer then the other ones like fading away or something but call me crazy because I really can't understand this but it only does it in the day time. During night time the pixels are all normal.
Old 08-21-2009, 09:01 AM
BlueKnight1 BlueKnight1 is offline
Mein Auto: '98 528i, '08 GMC Acadia
Same here with 1 and 2
Remedy to the problem?
Old 08-21-2009, 12:43 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
I took my MID apart and swapped the backlight panel with another one from salvage unit. Had to do this to get the good LCD with the good back light together in one unit. Bulbs didn't look easily serviceable. It was an interesting task for me but if you do it, count on buying a replacement mid, then you won't be disappointed if it doesn't' go right. Getting the mid out of the car is like 30 seconds. Alert - the electrical connector has a plastic lever that swings 90 degrees to release. A nice design but be aware it's there.
Old 10-06-2009, 10:33 PM
Eurojay89's Avatar
Eurojay89 Eurojay89 is offline
Faithful to the fest
Send a message via AIM to Eurojay89
Mein Auto: 2003 530i
yea i accidentally broke mine
Old 04-17-2013, 11:28 PM
sdb48 sdb48 is offline
Mein Auto: 3 Series
Where can you get the MID bulbs?
Old 04-18-2013, 03:56 PM
Mein Auto: 3 Series
Found these for $11.95
http://bavauto.com/shop.asp
Old 04-18-2013, 06:03 PM
caryalon caryalon is offline
Mein Auto: 2002 530i, 2001 325i
I'm confused - your pictures are of the instrument cluster, yet you say that you can't see the station presets of the MID. Which was/is the problem?
Old 04-18-2013, 08:26 PM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
He posted that 4 years ago, don't think he's around anymore.
Speedo bulbs can be purchased at BMW, they are cheap.
MID bulbs can be ordered from electronic supply houses, IIRC they are CM-712.
