7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners |
DIY - 750Li - AIB installation
Here's the promised DIY. Understand that this is E66 specific and I cannot make any statements regarding whether it is the same with the E65. I can say that this is a big job just to replace a couple of bulbs. The result is great, and really makes a difference, but this is definitely not a "plug and play" installation for the E66.
1. I ELECTED TO RAISE UP THE FRONT OF THE CAR. MAKE SURE THE CAR IS SECURELY RAISED. THIS IS NOT STRICTLY NECESSARY, BUT IT MAKES ACCESS TO ANYONE OVER 4 FEET TALL MUCH EASIER. ![]() 2. IF YOU OWN BMW'S FAMOUS "SPECIAL TOOL" USE IT FOR THIS STEP. I DON'T HAVE ONE SO I USED A PROTECTED FLAT HEAD SCREWDRIVER. THIS IS THE FIRST TRIM PIECE THAT COMES OFF. TAKE OFF THE TWO OUTER TRIM PIECES, THEN THE CENTER PIECE WHICH MAKES UP THE LICENSE PLATE HOLDER. UNDER THIS TRIM PIECE ARE TWO TORX SCREWS WHICH ARE PART OF SECURING THE BUMPER COVER AND MUST BE REMOVED (SEE PHOTO A FEW STEPS DOWN). THE PDC IS PART OF THESE TRIM PIECES. AS YOU SLOWLY PULL THEM OFF, UNPLUG THE CONNECTION. MAKE SURE TO LEAVE THE ACTUAL SENSOR ON THE TRIM PIECE. ![]() 3. PULL OFF THE LOWER PLASTIC MESH GRILLS. OUTER ONES FIRST, CENTER ONE PUSHES IN THEN COMES OUT. BEHIND THE TWO OUTER MESH COVERS ARE FOUR MORE TORX SCREWS, TWO FOR EACH SIDE AS SHOWN. THE UPPER ARROW POINTS TO ONE OF THE TWO TORX SCREWS BEHIND THE CENTER TRIM/LICENSE PLATE HOLDER. ![]() 4. THESE ARE THE TWO CENTER TORX SCREWS ![]() 5. AT THE TOP OF THE BUMPER COVER ARE TWO MORE (LARGER) TORX SCREWS ON EACH SIDE. THIS PHOTO IS POST REMOVAL. ![]() 6. THERE ARE A TOTAL OF 10 TORX SCREWS WHICH MUST BE REMOVED FROM THE FRONT AREA AS SHOWN IN THE PHOTOS TO TAKE OFF THE BUMPER COVER. THERE ARE ALSO 4 MORE SECURING POINTS: A. IN THE WHEEL WELL, REMOVE ONE SCREW IN THE AREA OF 2 O'CLOCK (IF THE WHEEL WELL WERE A FULL CIRCLE) THIS CAN BE FOUND JUST ON THE INSIDE OF THE WHEEL WELL BEHIND THE PAINTED EDGE. THIS SCREW GOES IN STRAIGHT UP (90 DEGREES)7. HERE'S WHAT IT LOOKS LIKE WITH THE BUMPER OFF ![]() 8. NEXT, UNCREW THE HATED CAR WASH KILLER, I.E. HEADLIGHT WASHER. (NOTICE THE PLASTIC PIECE RIGHT UNDER THE PAINTED FENDER AT THE FAR LEFT IN THE PHOTO. THIS IS THE FRONT END OF THE PLASTIC RAIL MENTIONED IN 6(D) ABOVE. ![]() 9. REMOVE THE LIGHT FIXTURE. FIRST UNDO THE TWO TOP SCREWS. ![]() 10. UNDO FIRST "INNER" BOTTOM SCREW. ![]() 11. UNDO SECOND "OUTER" BOTTOM SCREW ![]() 12. UNDO TOTAL OF THREE CONNECTIONS. THE ONE MARKED BY A BLUE ARROW HAS ALREADY BEEN DISCONNECTED. THE RED ARROW SHOWS THE MAIN CONNECTION. THIS ONE HAS A STANDARD BMW STYLE SECURING SHELL WHICH MUST BE PULLED UP TO RELEASE THE PLUG. ![]() 13. THE LIGHT FIXTURE PULLS STRAIGHT OUT, AND HAS A BOTTOM OUTER ALIGNMENT "TRAY" WHICH MUST BE REMOVED. AFTER THE TRAY COMES OFF, THERE IS A "ROUNDED" PLUG WHICH EASILY SCREWS OFF. UNDER THIS PLUG IS THE ANGEL EYE BULB. UNDO THE CONNECTION AND TURN IT COUNTER-CLOCKWISE. PULL IT OUT AND THIS IS THE LAME BULB BMW SEES FIT TO ILLUMINATE THE ANGEL EYES. ![]() 14. THIS IS THE AN GE L i BR IGHT. WHAT A DIFFERENCE! ![]() 15. REVERSE THE STEPS TO PUT THE BUMPER BACK ON. 16. HERE'S WHAT IT LOOKS LIKE: DAYTIME ![]() NIGHTTIME ![]() ![]() IT REALLY MAKES A DIFFERENCE. Last edited by M.Wong; 04-14-2009 at 06:04 PM. |
Looks good and instructions are clear, concise w/ great pix. Still won't do it myself. Everytime I mess with removing/reinstalling car parts, a screw gets loss, I end up w/ an extra screw. Whatever happens, the car never seems quite the same. End result is always an annoying loose rattle. I think I'll leave it to the pros. Lights look good. Probably what I do next.
![]() E66 SAPPHIRE BLACK |
Excellent write up!
Mods, please make this a sticky.
nice. pretty scary/intimidating though.
2004 BMW 745Li 2003 Mercedes Benz SL55 AMG 2001 Toyota Landcruiser 2007 Infiniti FX35 1999 BMW 323i Convertible 1966 Ford Mustang Convertible 1974 Jensen Interceptor 2000 Mercedes E320 (R.I.P.) ![]() Sittin on stock 19s now. |
wow, what a krazy procedure to do ae's lol... Can you get aes in the oem color but brighter?
Nice.. looks good.. i did mine from Umnitza through the hood w/o taking the bumper or headlights out.. so mine wouldn't have the steps showing what you did.. but it would have pics showing the bleeding knuckles and a DIY on how to put a band aid on while your hands are covered in grease! lol
I'll take some bloody knuckles over removing the bumper anytime. Unbelievable the 7designers couldn't come up with easier access for a common problem (fried bulb). Of course, if they were really "plug and play" as advertised, then BMW couldn't charge you the $200 in labor for the install. What a racquet.
Sticky this, great writeup
wow the whole bumper huh??? Your a nut but tghey def look great, maybe the e65 you dont have to remove the whole bumper???????
99 540i sport, acs type 2's chrome, acs spler pdls,Euroclrs 04 745i aw sport,21's aib's acspedals& rf splr(sold) 00 328i Prem Aw18" 335spt whls(sold) 02 Corvette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav 05 X5 3.0, pana rf,nav,xenon,cldweather, premium.ipod hookup, 20"4.6rims staggered 315rrs. 06 750I aw, sport. chrome21's,acs pdls,acs rfsplr,mtecs,8k hid fogs,Leds.oem ipod&sirius 03 VIPER, forgelinewheels,tune,exhaust,intake. |
From reading the responses, it seems like the E65 does not require a bumper shell removal. Unfortunately, the E66 does. Not only the bumper shell, but the light assembly and the alignment tray on the light assembly has to come off. finding the angel eye bulb on the E66 is akin to the script of "National Treasure", layer after layer has to come off until you get to the very well hidden "treasure".
I will say that one of the most satisfying aspects of the job was discovering the awesome engineering that makes up just this little section of the 7. It was a hard part to get to, but the fit and finish of all the parts was excellent. These BMW guys really know how to build cars! Also, I was happy to clean up all those parts you see in the photos. You can't tell after you put the car back together, but I like knowing the front end is as clean as when the car came off the factory floor. |
Great write up btw!
great info though Sticky it please
![]() 00 E46 323I current 08 Jeep Grand Cherokee Laredo current 08 E60 535I LEASE OVER 02 E66 745LI LEMON 98 E39 528I SOLD 91 E30 316I SOLD |
I would go back and edit the post but there's no longer an edit button. Thanks for the info. |
No problem bro! We are all learning new stuff here.
Diznik 007,
is your ride lowered?what springs?
Great job! Thank you!
2006 750Li--Sterling Gray/Black|Lux. Pkg|Conv. Pkg|Comfort Access|Rear Entertmnt|Sat|21" 128 OEM|Ipod Interface|Iphone 3g|iphone Cradle|V-1|30% Ceramic Tint|3M Invisi-Bra|AiB Upgraded Angeleyes 2008 Toyota Sequoia Platinum--Arctic Frost Pearl/Red Rock|Fully Loaded| Many mods coming... |
yes, dropped on H&R's.
