Old 04-16-2009, 10:20 AM
Big "J" Big "J" is offline
Mein Auto: X5, 325I
Fan Pulley Holder
I was going to try and change my Thermostat and realized I don't have the fan pulley (over the shoulder boulder) holder. Sorry, couldn't resist.
Anyway, I looked online and bavauto wants $40 for one. I know some here have manufactured their own and think with my father-n-laws help I can make one as well.
Does anyone know the dimensions of the bolt holes (diameter and distance apart), half circle and length of the unit?
I may make several of them so us penny pinching DIY'ers can have one.
Thanks for the help!!!
Old 04-16-2009, 10:29 AM
AlboBMW's Avatar
AlboBMW AlboBMW is offline
#422323
Mein Auto: '01 325i
I don't understand the question and I am assuming you are talking about the 325i and not the X5 right? I DIY'ed my water pump recently and I used a 1 1/4'' wrench to remove the fan, and then an allen wrench to loosen the de-tensioner. The bolts around the t-stat should be 10 mm or 12 mm.
Mein Auto: X5, 325I
Never mind!!!
I searched and found exactly what I need.
Doh!
Old 04-16-2009, 10:31 AM
AlboBMW's Avatar
#422323
Mein Auto: '01 325i
good luck then
Old 04-16-2009, 10:49 AM
Mein Auto: X5, 325I
Originally Posted by AlboBMW View Post
good luck then
For the 325i auto, i have to remove the fan clutch and couldn't hold the fan pulley and need this tool. Sorry for the vagueness of my post.
Thanks!
Name:	Fan tool 1.jpg
Old 04-16-2009, 10:51 AM
AlboBMW's Avatar
#422323
Mein Auto: '01 325i
Oh ok. People have used a screwdriver between the two blots. Glad you resolved it.
Old 04-16-2009, 12:03 PM
Scott ZHP's Avatar
We want the Lion!
You dont need any special tool to hold the clutch; just whack the wrench with a dead blow hammer.
(you do need a thin wrench to get to the nut).
Old 04-16-2009, 12:09 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
+1 and if you still need leverage use a screw driver wedged between two water pump nuts. There are mucho threads on this.....(even some pics I did)
Old 04-16-2009, 12:45 PM
Mein Auto: X5, 325I
Okay..... I wasn't sure if a screw driver would damage anything. I'll search for the pics and make something happen this weekend.
I'll give it a go and let ya know.
Thanks guys!
Old 04-16-2009, 01:49 PM
Scott ZHP's Avatar
We want the Lion!
Thanks guys!
This is how most people crack/break the bakelite/plastic pulley. The get it sort of close, then chip it.
The holder/screwdriver method is just a hassle; and noobs are going to get frustrated. Just take up the slack and hit the wrench HARD with a deadblow hammer with at least 90deg of clearance.. There's no need to lock the pulley. Unless maybe you've got an ancient E46 and your POs have ignored maintenance.
Old 04-16-2009, 02:01 PM
Mein Auto: X5, 325I
I can do that.....
Old 04-16-2009, 02:17 PM
smolck's Avatar
ROLL TIDE!
Perhaps, but Big J isn't a "noob" and has a large amount of common sense so I feel confident he can figure it out. The hammer thing has worked for me on 7 out of 10 auto cars, but not all of them, only reason I mention it.
