Old 04-22-2009, 12:22 PM
textking textking is offline
Mein Auto: BMW 335i Coupe
How to Remove a Tag/Spray Paint
Some hater out there decided to Tag my car.
Luckily, it doesn't seem permanent and I was able to remove it with my fingernail, but it's taking a long time and I don't want to scratch the bumper.
Does anybody know of a product that can remove this without ruining the clear coat or scratching the bumper?
Old 04-22-2009, 12:25 PM
the328's Avatar
the328 the328 is offline
Enjoying Your Money
Mein Auto: 2009 328i
did you try alcohol?
Old 04-22-2009, 12:27 PM
I only tried water. I'm afraid alcohol will remove the clear coat.
Old 04-22-2009, 12:31 PM
Strongmad Strongmad is offline
Mein Auto: 335
Kerosene works, but only if the paint is still wet. Unfortunately, anything strong enough to remove paint isn't going to be friendly to your car's paint. You can try wet sanding, or have a detail/body shop wet sand it. If worse comes to worse, you can have the bumper cover painted for a few hundred bucks.
Old 04-22-2009, 12:42 PM
Kief's Avatar
Kief Kief is offline
Mein Auto: 2017 F80 ///M3 ZCP
Try to clay it
I know it takes off overspray. Just might take longer to remove that crap
2017--F80 ///M3 ZCP
2016--F-Type Coupe R*
2015--F15 X535i
2015--F82 ///M4 [ED 6/26/14]*
2015--V60 Polestar (#62:80)*
2012--E92 335is*
2011--E70 X5d*
2011--E89 Z435is*
2009--E89 Z435i*
2008--E92 335i [ED 2/23/08]*
2007--MkV GTI*
2006--R53 Cooper S (JCW) 6MT*
2006--E90 330i*
2005--E83 X3*
2004--E83 X3*
2003--E46 325Ci*
*retired
Bartman619 Bartman619 is offline
Mein Auto: '07 328i
Same thing happened to me 2 years ago. I went to Home Depot and got some Goof Off. Put some on a piece of cloth and rub it in well, or let it soak for a minture on the spray paint then wipe off. If the paint is dried up it will take some elbow grease. After you're done, wash the car well.
Old 04-22-2009, 12:44 PM
Kief, What is Clay it? Excuse my ignorance.
Old 04-22-2009, 12:57 PM
ProfessorCook's Avatar
ProfessorCook ProfessorCook is offline
Not a real doctor.
Mein Auto: 2009 328i Coupe
I'd try the clay first. Chemicals might work, but I'd be extremely careful not to damage the underlying paint.
You'll risk some scratches, of couse, but you might try a kitchen sponge with a 3M scrubber side on it. I think that's about the same as using a fingernail.
Another option would be a regular sponge and some Comet or Ajax. Of course, you'll need to polish, buff, and restore afterwards.
'09 328i Coupe: MT, Monaco Blue, Black Dakota, Dark Burl, ZPP, ZSP, ZCW, CA, Logic7, HD Radio, IPod
Ordered: 14Jan09; Delivered: 24Feb09 from Stratham, NH BMW
Not a real doctor.
You can buy a clay bar and you rub the clay over the surface of your car using soapy water as a lubricant.
You can get detailing clay at good auto supply places or over the 'net.
Old 04-22-2009, 01:20 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
My car got tagged about 3 years ago. Lots of mineral spirits, gently blotted on and off, did no damage to the underlying paint and removed all of the vandalism.
Three caveats - I had waxed my car about 1 week prior, it was below freezing when the spray paint was used, and the spray paint had not fully cured when I found it.
Good luck,
George
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 04-22-2009, 02:33 PM
fasttimes fasttimes is offline
Mein Auto: 99 Maxima GLE
I 3rd clay
Old 04-22-2009, 04:28 PM
Emission's Avatar
Emission Emission is offline
Automotive Monomaniac
Mein Auto: Schnelle Autos
Clay, then wax or polish. And, elbow grease.
- Mike
I am fortunate to have unique press cars delivered weekly, but I own:
'16 BMW X5 xDrive35i M Sport 8AT
'15 Volkswagen Golf TDI 6MT
'86 Porsche 911 Turbo 4MT
Gone, but never forgotten... my E70 X5 35d, E90 335i, E46 330i, E36 328i, E70 X5 3.0si, E53 X5 3.0i.
Read my work as Editor-in-Chief for Autoweb and Autobytel!
Old 04-22-2009, 07:09 PM
Boondoggler Boondoggler is offline
Mein Auto: 2006 330i
http://www.autogeek.net/detailing-clay-bar.html
The above is a good description of what auto detailing clay is and how to use it for the initiated. You can get detailing clay at most stores that have a wide variety of auto detailing products, or of course, the online retailer that hosts the above link. You're going to want to get to work on it ASAP as the longer you wait, the more the spray paint will cure and be harder to remove.
2006 330i 6MT
Monaco Blue | Beige Leather | Burl Walnut
Sport Package | Premium Package | Parking Distance Control | Sirius | OEM Trunk Spoiler
Blacklines | M-Sport Wheel, Shifter & E-brake | HO 50 Tint | Rogue Engineering SSK | CDV Removal
Old 04-22-2009, 07:19 PM
tturedraider's Avatar
Freedom isn't free!!
Ignore all these rubes! (j/k)
I had this happen a few months ago. Here's the fix - Motsenbocker's Lift Off #4 for spray paint, Graffiti Remover.
Picked it up for about $5 at Home Depot or Lowe's. It worked GREAT! It's water based and biodegradable.
http://www.liftoffinc.com/product-graffiti-remover.php
www.bmwcca.org
Old 04-22-2009, 08:12 PM
the328's Avatar
Enjoying Your Money
alcohol will not remove any clear coat, I've done it many times. Your clear coat is designed to withstand such chemical as alcohol, benzine (gasoline), kerosine. DO NOT use acetone as it will damage your paint.
spray paint vandalism
