E90/E91/E92/E93 (2006 - 2013)
Old 04-20-2009, 02:24 PM
MattieB's Avatar
MattieB MattieB is offline
Mein Auto: 335i sedan
Glovebox USB help.
The manual is worthless on this. I have an 8 gig USB stick loaded up with music. I insert it into the port in the glovebox and the LED on the USB stick lights up so I know it has power.
On the Idrive I hit "Menu", then "CD/Multimedia", It brings you to a new page titled "Music Collection". On that page are 4 entries that are all grayed out: Music Search, Current Playback, Top 50, and No Entries. Can't select any of them.
Can anyone tell me how to play the songs of the USB? I've tried it 3 time now.
CaptainAudio should be the expert on this with his screen name right?
'09 335i 6MT Sedan: AW / Saddle / Alum / Nav / Premium / Sport / CA / Sirius / 35% / Black Kidneys / HPFP #3
Old 04-20-2009, 02:38 PM
ProfessorCook's Avatar
ProfessorCook ProfessorCook is offline
Not a real doctor.
Mein Auto: 2009 328i Coupe
Hmmm... for me, it takes a while to load the USB, so maybe you just have to be patient. Have you given it some time?
It takes mine about 15 minutes to load. I have about 40 gigs on my 60 gig stick.
'09 328i Coupe: MT, Monaco Blue, Black Dakota, Dark Burl, ZPP, ZSP, ZCW, CA, Logic7, HD Radio, IPod
Ordered: 14Jan09; Delivered: 24Feb09 from Stratham, NH BMW
Old 04-20-2009, 06:15 PM
the328's Avatar
the328 the328 is offline
Enjoying Your Money
While I do not have an idrive, isnt it suppose to give you a USB option as well? my standard "business" stereo takes a few seconds to have a "USB" displayed. So as Professor said give it a little more time.
Old 04-20-2009, 10:20 PM
MattieB's Avatar
Thanks Prof. A lot of my drives are just 10 minutes here and there, so maybe I need to take a long drive and see if it will load.
Old 04-21-2009, 05:30 AM
Not a real doctor.
Let us know what you find out.
Old 04-21-2009, 05:44 AM
Jmck Jmck is offline
Mein Auto: 325i convertible 2009
Ok, on the music collections page, you have to then press options and select import music from USB or whatever if i remember right.
then it shows a bar importing the music as well, been a little while since ive done it, but from what you said, you didnt click any import you just went into your music collections folder
try the options button and i think your problem will be solved, the car doesnt have to be running either. at least im sure mine wasnt, ill try it for you tomorrow
good luck
My 325i convertible with M3 body kit 2009
Old 04-21-2009, 07:05 AM
Flatman's Avatar
Flatman Flatman is offline
Mein Auto: 2005 325ci
I don't have to import mine, I just select the "AUX" tab in entertainment mode and it automatically comes up with my root folder showing Artists (how I have mine arranged).
2008 328i Coupe - Alpine White
2005 325ci - TiAg
Old 04-21-2009, 07:40 AM
Mineo335i Mineo335i is offline
335i N3WB
Mein Auto: 11' Audi S4 Prestige
I'm not sure if this would affect the loading time at all, but most USB drives have software that has to load every time you insert the drive(It pops up a window by the maker of the drive and a fancy menu usually). I know on my "Cruzer" drive it is called U3, you should be able to remove this and this could possibly significatnly cut down on the load time.
I hope what i said makes sense, but load the USB on a computer, if it says new device found every single time, instead of poping up the window that asks "what do you want windows to do" you probably have this software which is probably lagging the Car load time.
Currently Drive: 2011 S4 Prestige, Quartz Gray, Black Alcantara, Adv key, B&O, NAV + rear sensors, 19's, Carbon Fiber Trim, iPod...
Previously drove:2007 335i Coupe, Titanium Silver Metallic,Black Leather, Gray Poplar trim, Premium package, Cold weather package, Sports package, i-Drive, Rear sensors, iPod.
Previously drove: 1998 3000GT Vr-4 Red/Black TT AWD AWS
Old 04-22-2009, 10:25 AM
BMW_GAL's Avatar
BMW_GAL BMW_GAL is offline
Mein Auto: 2009 335i Coupe
Just curious, what music format do the song need to be in on a flash drive to connect it to the USB port in the glove box?
Old 04-22-2009, 10:40 AM
kp335i's Avatar
kp335i kp335i is offline
Mein Auto: 2008 335I Sedan
have you tried the usb port in the center console instead??? i've heard somewhere that their functions are different but dont remember where...
'08 335i Sedan - Titanium Silver - Black Leather Int - Alum trim - Premium Pack - Prm Sound pack - Sports pack - Step - Paddles - Comfort Access - Sirrius - BMW Winter Mag Kit 17" LM22 - Summer RF 18" - Tints - Clear Bra
Old 04-22-2009, 11:20 AM
Not a real doctor.
The music files work in .wav or .mp3 formats... any compression ratio.
Old 04-22-2009, 11:24 AM
DJEcLeCTiK's Avatar
DJEcLeCTiK DJEcLeCTiK is offline
Gentleman Extraordinaire
Mein Auto: 2009 E92 335i
I think it says something like that in the manual. Something along the lines of you can only import songs onto the HD from only the glovebox/center USB but not the other. As far as playback is concerned I'm sure that as long as the file types are recognizable by the car it shouldn't matter which USB port you use (unless they have different read speeds)
2009 E92 335i xDrive (Ordered 3/21/09 / Completed 5/4/09 / Delivery 6/6/09)
Space Gray Metallic / Black Dakota Leather / Gray Poplar Wood Trim / ZPP / ZCW / ZSP with 18" wheels / StepTronic / Navi+HD Radio / Logic 7 / iPod+USB / PDC / Anti-Theft
Old 04-22-2009, 03:58 PM
MattieB's Avatar
I don't have a USB port in the center console. There is a power outlet and an AUX jack. My songs are in whatever format iTunes uses (MPEG4 I believe). Still no luck getting it to work. Tomorrow I have an hour long drive, so maybe they will load then. I'm clueless. Can't believe I might have to go to the stealership just to play music.
Old 04-22-2009, 05:03 PM
hbdunn2003 hbdunn2003 is offline
Mein Auto: E91 328i
You can not play files off of the usb port in the glovebox. It is only for importing them.
Must have the ipod option to play off the flash drive.
Old 04-22-2009, 05:12 PM
armoredsaint's Avatar
armoredsaint armoredsaint is offline
Pok Gai 1.0
Mein Auto: '09 E92 335i M-Sport
is it true that i can not download my itunes into the hard drive and it has to be played directly from the iPod?
2009 E92 335i ///M-Sport / Black Sapphire Metallic / Black / 6MT / Glacier Trim / Comfort / Nav+HD Radio / iPod+USB / Cold
Mods: Pinnacle Tint 50+35 / RD Angel Eyes / Mtec Foglights / 1w LED side markers / M3 Lip Spoiler
Old 04-22-2009, 05:20 PM
Mein Auto: E91 328i
Protected AAC files have to be played through an Ipod, unprotected AAC can be stored and played on the hdd.
Old 04-22-2009, 05:30 PM
RichmannMotorSport.com RichmannMotorSport.com is offline
SUPPORTING VENDOR
Mein Auto: 07' E90 and 95' E36 M3x2
I just plugged my MP3 player directly into the headphone jack inside my armrest and I listen to all my music everyday.
Old 04-22-2009, 08:42 PM
MattieB's Avatar
How do you import them? The car doesn't even see the USB stick. But the LED on the stick is on, so I know it has power.
Old 04-22-2009, 09:19 PM
Mein Auto: E91 328i
From the manual
If they are songs purchased on itunes before they dropped the drm, they will not play.
