Old 04-23-2009, 11:35 AM
cn90 cn90 is offline
TRW-Meyle (vs Lemforder) Front Suspension
I am shopping for Front Suspension for my 98 528i:
- Thrust Arm
- Control Arm etc etc.
I know Lemforder is the OEM supplier but it is on the expensive side. Lemforder is about $130/each.
But autohausaz.com lists these items by TRW-Meyle for only $102 each:
http://www.autohausaz.com/search/pro...int%20Assembly
Any experience with TRW-Meyle brand?
Old 04-23-2009, 11:45 AM
oembimmerparts oembimmerparts is offline
Mein Auto: 2001 Z3
- Thrust Arm
I would put trw and lem in the same rating, I have seen many lemforder parts with trw stamped in the ball joint and trw makes alot of parts for bmw.
If you get sent a meyle from them at 100.00each that is to much as we sell the meyle for 85.00 and the trw for 129.00. There are plenty of people who do like meyle but I can tell you for the last 2 years that we have been selling meyle we have had 1 tie rod come back because it would not thread on to a center link and that is it.
Old 04-23-2009, 11:53 AM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Meyle seems to be second-rate, at best. My Meyle tie rod only lasted 20k, whereas the original TRW lasted 90k.
In addition, the forging near the idler arm joint was such that I could not get the puller into the joint. I had to remove the idler arm along with the tie rod, and file the metal away to get the puller to fit. When I had earlier removed the original TRW part, the puller fit properly.
Old 04-23-2009, 12:14 PM
Max,
Did TRW and Meyle get "married" recently?
I thought TRW is TRW and Meyle is Meyle.
But if you click on my link above (autohausaz), then the brand name is TRW-Meyle?
Old 04-23-2009, 12:23 PM
Mein Auto: 2001 Z3
Max,
No, By placing the 2 above brands as they did ,That means when you order that part you could get one or the other of the above brands.
Old 04-23-2009, 12:28 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: 01' 540 M-Sport, Scuderia
Which version? Appears Meyle makes oem and HD version (heavy duty), or do they only offer the "improved" versions?
This is a listing of their improved HD offerings:
http://www.meyleusa.com/improved_bmw.htm
http://www.meyle.com/html/uploads/te...9_12.04_en.pdf
Old 04-23-2009, 12:33 PM
Max,
Check with Autohausaz...they may be implying you will get either brand, depending on what is available. A few times when I have ordered, I have gotten a different (but acceptable to me) part brand than what was posted.
Old 04-23-2009, 12:39 PM
Thanks!
http://www.bavauto.com/shop.asp
sells the control arm w/o bushing and you can buy
Separate HD bushings: PN 31 12 9 068 753
EAC Tuning is doing similar thing as well:
http://eactuning.com/e39-thrust-arms...ngs-p-453.html
Anyone with experience with HD bushing?
Also when they sell control arm w/o bushing, what brand of control arm do they use?
Old 04-23-2009, 12:54 PM
There is good feedback from folks here using the EAC Tuning with the HD bushing already installed. Save yourself the labor and get the arms with the bushing and ball joint installed, ready to bolt up.
Old 04-23-2009, 12:56 PM
Mein Auto: 2001 Z3
Thanks!
Are you looking for the control arms (first post) or the thrust arms?
BlackBMWs's Avatar
BlackBMWs BlackBMWs is offline
Check twice, fix once...
Mein Auto: 540it 533i 318ic 325i
Just a note, If you get an arm without the bushing, Jared at EAC will press them in for you. I pressed my HDs bushings in my Control Arms myself and it was a b*tch... I'm glad to have Jared take care of it moving forward...
I am using the HD CA bushings and they are smooth and quiet.
1999 540it - Jet Black/Sand Beige, style 5 rims, Zionsville Cooling kit
1984 533i - Schwarz/Schwarz, 17" style 65 reps
1997 318ti Sport - Schwartz II/Schwartz Anthratz, style 68 rims
1995 318ti Sport - Schwartz II/Schwartz Anthratz, style 27 rims
1994 325i Sedan - Bostongrau/Tan
1991 318ic - Schwarz/Anthratz Stoff
1985 635CSI - Schwartz\Sand - Sold
1984 318i - Champagne/Tan, Stock - Sold
BMWCCA# 160411
Old 04-23-2009, 01:19 PM
Max,
I am doing the whole front end, so looking at both upper and lower control arms.
(BTW, BMW complicates things by calling these different names! They are basically the equivalent of an A-Arm of a Volvo or Honda, just split the A-Arm into 2 and called diff names!!!).
BlackBMWs,
Pricing is an issue!
TRW Thrust Arm is about $100
TRW Thrust Arm + HD bushing is $280 per pair!
Lemforder Thrust Arm is about $135
Lemforder Thrust Arm + HD is $320 per pair!
I need to call Jared at EAC Tuning!!!
Old 04-23-2009, 01:26 PM
BlackBMWs's Avatar
Totally understand the pricing issue.
Diff Q for you, didja find a source for nuts and bolts? You need me to get and send you some?
BMWCCA# 160411
Old 04-23-2009, 01:30 PM
Thanks!
Actually I will get them from my local BMW dealer. They are inexpensive a few dollars each.
Old 04-23-2009, 01:44 PM
Now I am even more confused.
Thrust Arm Bushing for 6-cylinder.
PN is 31129068753
Apparently it is not fluid-filled (Basically a solid piece of rubber or polyurethane or whatever, but not fluid).
Part #5:
http://www.realoem.com/bmw/showparts...17&hg=31&fg=05
Thrust Arm Bushing for 8-cylinder.
PN is 31121092609
Apparently it is fluid-filled.
Part #6:
http://www.realoem.com/bmw/showparts...64&hg=31&fg=05
Old 04-23-2009, 01:47 PM
BlackBMWs's Avatar
What's the confusion? the thrust arms are also in different positions on the two suspensions.
BTW, the HDs for the 540i's and X5's are back to solid, non-fluid.
BMWCCA# 160411
Old 04-23-2009, 01:55 PM
Does anyone here have a used thrust arm from an I6 and can cut up the bushing to see if there is fluid or not.
If it is rubber, then I will go with Lemforder and forget about the HD bushing.
Old 04-23-2009, 02:02 PM
mmm635's Avatar
mmm635 mmm635 is offline
Mein Auto: '02 525i Sp/5, 95 FJ80 LC
PN is 31129068753
Part #5:
PN is 31121092609
Part #6:
The bushing (oem) for the thrust arm is fluid filled for the I6. The lower control arm bushing (oem) is not fluid filled for the I6.
Here are the pics: I6 Control Arm Install (Thrust)
Halfway down you will see the oem bushings (new) that were removed from the metal sleeve. The fluid leaked all over my work table and you cannot see it in the pics. However, you will see the guts. My suggestion is to suck it up if you can and get the Lemfoerders.
Old 04-23-2009, 02:06 PM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
I would buy the Lemfoerder arms with the Meyle HD bushings pressed into them from Jared.
OEM bushings suck because the breaks IMO.
Old 04-23-2009, 02:16 PM
Thanks a million Michel!!!
You are the man. Wow, tons of pics!
I just left a message for Jared at EAC Tuning!
Just curious for those who leaks from the bushing, approx. how many years and miles when it leaks?
My bushing looks dry at 102K (but maybe all the fluid is gone so it is bone dry now LOL....)
Old 04-23-2009, 02:19 PM
My looks dry at 102K (but maybe all the fluid is gone so it is bone dry now LOL....)
The bushing can look dry, but after taking it out, you can see the leaks...
Old 04-23-2009, 02:26 PM
Jared@EAC Jared@EAC is offline
Past Sponsor
Mein Auto: 00 540i/6
Mike is right. I did the same thing on an arm. I pressed the rubber out of the metal sleeve and fluid spilled everywhere. OEM is still fluid filled as far as I can tell.
So far everyone has been loving the OEM arms with the HD bushings. I wouldn't be scared to run the TRWs. Max is right, TRW is OEM on a lot of BMW parts. I sell a ton of them and have had zero complaints. I only have the Lems on the site because there are a few that still want them.
Pressing the bushings is a PITA and time consuming. You also run the risk of destroying your bushing and/or arms. If I could buy arms without the OEM bushings then I'm sure they'd be cheaper. What you are basically paying for is 2 sets of bushings. The OEMs I have to press out and then the HDs I press in.
Jared
Old 04-23-2009, 02:34 PM
Jared,
Probably not something you want to do, but if you could get 4 or 5 sets of used arms, then you could offer an "exhange" program when you install new bushings and ball joints and when someone orders, you charge them an extra $150 or whatever, and refund it when you get their usable/rebuildable core back.
Old 04-23-2009, 02:36 PM
Too many variables to say. It depends on your driving habits and the road quality. Mine were replaced at around 65k and now at 122k they still look fine. They are oem.
I recently installed Bilstein PSS kit and imagine with the way I am taking corners, I will trash the thrust bushings in short order now...
Old 04-23-2009, 02:37 PM
mmm635's Avatar
No problem man.
There are a couple of pics of my controls with a view from the bottom of the bushing side. You will notice there are some black stains - that is the fluid that leaked out. This happened at 60K miles and they were shot way before that.
