Old 04-23-2009, 07:05 PM
JoeBeam7 JoeBeam7 is offline
Mein Auto: 2003 BMW 745i - Blk/Blk
"Repeat Gear Selection" Warning Light
Hello everybody, I recently had to remove my air filter compartment to replace one of the small headlight bulbs on the front passenger side. Once the bulb was put in, I re-installed the air filter compartment but now my car is showing a "Repeat Gear Selection" Warning Light almost every time my car comes to a stop.
Anybody know what the cause might be?
2003 BMW 745i (Blk/Blk)
Old 04-23-2009, 07:45 PM
gulfviewmassive's Avatar
gulfviewmassive gulfviewmassive is offline
Mein Auto: 745i
thats happened to me, but only occassionaly! if its happening as often to you, then something is really wrong.......it could be the start of transmission related problem and if ur under warranty take it to the dealer and seek some solutions quickly!
Old 04-23-2009, 08:29 PM
gridlock249's Avatar
gridlock249 gridlock249 is offline
MERK MODE
Send a message via MSN to gridlock249
Mein Auto: BMW 745i
I am about to change my microfilter myself and reset the warning sign through IDRIVE. Last thing I need is a malfunction with my transmission. If someone can elaborate on this in detail I would like to know.
J//
BMW 745i (E65) Black/Black Executive Package
Specs: Logic7 SS | Presidential tints |
2x 12" Kicker Subs w/ Kenwood 1000x amp | 22" deep dish chrome | AC Roof Spoiler |
Upgraded AIB/HID lights| HID Foglight
Development: LED Lights | IPOD audio compatible
(C) SAFEKICKS INC. ENTERTAINMENT. ::
Old 04-23-2009, 08:40 PM
mbz1 mbz1 is offline
Mein Auto: bmw e66
My 03 started that also and guess what, it started to run the battery down if it sat more then 3 days.. took to dealer they found a bad park switch in the leaver that you move to get to drive and park it also showed a falt in the SZL too.. what he told me was the car was not going to sleep because of the problem with the park switch being bad so new park leaver and SZL and a reprogram that took care of the Repeat Gear Selection problem..
Old 04-24-2009, 03:26 PM
What's an SZL?
I wasn't having this problem until removed the air filter compartment to replace a headlight bulb. My instincts are telling me that I might not have re-inserted the air filter compartment the proper way and something within that realm is causing the issue. But with that said, I have no idea where to begin with the diagnosis.
Old 10-24-2010, 12:36 PM
cosmoapt cosmoapt is offline
Mein Auto: 03 760LI V12
OMG!!! Im having the same exact problem. the battery runs down etc. Repeat gear selection is haunting me. I changed trans fluid after it took it the dealer they said it is probably low. I changed it and same problem. REPEAT GEAR SELECTION. I have 03 760LI
Did you find anything else out? I just changed fluid today.
Old 10-24-2010, 08:41 PM
Mein Auto: bmw e66
Old 10-26-2010, 07:14 PM
i bought the parking lever adn im going to replace it this weekend. I hope the SZL is good. That is a dealer only item that is expensive./
any other issues with your 03? It seems like everyday i have another issue.
Old 11-01-2010, 05:01 PM
ezebmw730 ezebmw730 is offline
Mein Auto: bmw 730si
Had same problem replaced gear selector and it fixed it no probs
Old 11-05-2010, 11:57 PM
i replaced gear lever and now the repeat gear selection is gone, (thanks all) now i have a trans fault anf air bag and restraining system warning. Any help here?
thanks
Old 03-07-2011, 03:40 PM
sr71 sr71 is offline
Mein Auto: 745I sport
how much did that gear switch lever cost??
Old 11-19-2012, 01:15 PM
Andrewadams211 Andrewadams211 is offline
Mein Auto: 2003 745i - E65
Ok, now when we say "gear switch lever" we are talking about the actual thing in the cabin? Right? Nothing in the transmission...right? I have this issue now "repeat gear selection" and I am going to try replacing the lever in the next few days.
