Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW.
Sponsored by The Tirerack. Moderated by Gary@Tirerack.com
Old 06-24-2003, 06:29 AM
KU Ned's Avatar
KU Ned KU Ned is offline
Jayhawk
Mein Auto: 330i ZHP
Question about Revs/mile
I have a 2003 330i ZHP with the following Michelin Pilot Sports:
Front - 225/40-18 Revs/mile=821
Rear - 255/35-18 Revs/mile=824
I have a set of AT Italia 17X8 wheels that I want to use for Auto X and Track events. I plan to put on 235/40-17 Kuhmo Ecsta V700's. The Revs/mile for the Kuhmo's is 855. What effect will this have on the car?
Also, I have a three 225/45-17 V700's. Two are in really good condition. I want to use two of them on the front and order two 235-40's for the rear. When the fronts wear out I will replace them with 235's. Any thoughts?
Old 06-24-2003, 06:31 AM
AF AF is offline
Here since day one
Mein Auto: 535ix, GL450, 991S
Ned,
try entering this into this tire calculator . . . it might help you out . . .
http://www.miata.net/garage/tirecalc.html
Old 06-24-2003, 06:33 AM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
It means that you will have imperceptably lower gearing.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 06-24-2003, 06:36 AM
KU Ned's Avatar
Jayhawk
Mein Auto: 330i ZHP
Originally posted by AF330i
Ned,
Great site Thank you!!!
It says my speedo will be 2.5% off when the speedo says 60 I will be doing 58.5 mph.
Gary@Tirerack's Avatar
Gary@Tirerack Gary@Tirerack is offline
Moderator
Mein Auto: 1995 BMW M3
Right, these are not large difference in 'real' feel and handling. All work fine and are popular choices for R compund tires.
Refer to 'Gary/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by ordering through the sig link.
Gary@Tirerack.com
Old 06-24-2003, 06:55 AM
·clyde·'s Avatar
·clyde· ·clyde· is offline
OMGWTFBBQ
Mein Auto:
Don't worry about it. It is well known that BMW speedos are overly optimistic to begin with.
There have been threads about this here and on other boards. Car and Driver had an article about speedos in general about a year ago.
Car and Driver Speedometer Article
Summary of Results (check out how the BMWs tested comapre to the other makes)
OH NOES!!!!!1 MY CAR HAS T3H UND3R5T33R5555!!!!!!1oneone!!!!11
Team WTF?!
What are you gonna do?
Old 06-26-2003, 09:02 PM
Ashe too's Avatar
Ashe too Ashe too is offline
Common Sense, isn't
Mein Auto: '04 330i ZHP
the actual measurements for a particular tire can be found on the tirerack website by clicking on "specs" on the page describing a particular tire or by finding the specs on the manufacturers website. for example, compare the diameter of any two same size tires on these two charts:
Bridgestone RE750
http://www.tirerack.com/tires/Spec.j...=Potenza+RE750
Yokahama AVS ES100
http://www.tirerack.com/tires/Spec.j...odel=AVS+ES100
___________________________________________
2004 330i | zhp | 6-speed manual
