5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
M5 front swaybars - impressions and instructions
Last weekend, I installed M5 front swaybars on my 2001 540i/6 and on my neighbor's 1999 540i/6. The first install took 2.5 hours and the second install would have been under 2 hours, had the power not failed!
After finishing my car, we drove to Panevino for lunch, along a wonderful twisty road. However, the rain was torrential, so I didn't get to push the car. Even so, I could still tell that something had changed significantly. A few days later, I finally had a chance to go throguh the twisties again in the dry and the car has been transformed. What a huge difference! The body roll is ever so slight and the car feels 500 pounds lighter. For $120 in parts, this is a bargain modification. Now that I've got the M5 front bar, however, I plan to remove the M5 rear bar and replace it with a Dinan rear bar, in order to keep the understeer to a minimum. In case you wondered what it would take to swap out your 540i front swaybar, here's the step-by-step instructions: http://www.zeckhausen.com/howto/bmwe...eplacement.htm
Dave Zeckhausen Owner, Zeckhausen Racing ![]() ------ 2012 BMW F30 328i Luxury Line 8-Speed StopTech 4-wheel big brake upgrade 2001 BMW E39 540i 6-Speed (Traded-in for F30) StopTech 4-wheel big brake upgrade M5 Limited Slip Differential, Front Swaybar Dinan Stage 3 Suspension, Strut Tower Brace Rogue Short Shifter, Transmission Mounts European Dash Conversion CDV deleted |
2 hours???? Are you joking? You have to remove half the front-end just to get going!!
I wonder, how closely will these instructions apply to I6 engines? I am not sure I have a weekend to kill figuring it out but I bet it follows the same basic plan. Nice write-up, Dave, but two hours??? I can buy a stubby wrench set but the "grind the 16 mm" wrench stopped me cold. However, with the Craftsman 500-piece tool set I got for X-mas last year, I got a set of SAE thin wrenches. Shoot, now I guess I gotta spring for some Metric thin wrenches! ![]() Thanks for sharing! |
I Also own a 2001 540i/6 are the m5 sways the same as RD sways or any other aftermarket sways or are they all the same thanks.
The Dinan rear bar is 17mm and is adjustable, with three holes at each end. You can vary the stiffness from just slightly stiffer than stock M5 bar at the outer holes, to MUCH stiffer at the inner holes. The front bar is not adjustable and is the same thickness, at 27mm, as the M5 factory bar. I believe the Eibach front bar is 28mm and is adjustable, but their rear bar is not adjustable. AC Schnitzer has a 27mm/18mm adjustable setup. I have no first hand experience with it or with the RD Sport setup.
![]() Besides, the front end of the 530i is so little, removing half of it would be a 10 minute job.
Zing!
![]() The 530i floats like a butterfly and out twists that hog front end you have! ![]() Zing my A$$!!!!! |
I knew it, this what I was waiting for, that it! I'm ordering the M5 sway's.. I just was lurking to see if anyone tried them, this is the ONLY problem with my 528 handling
of course the engine's still lame but it's alllll good gotta start somewhere!I have the ultimate road to my house twisty,man am I ready to test the swaybar's |
When comparing the M5 bars to the 540i 6sp and 540ia sport stock bars...
Anybody check to see if the 2003 540i 6sp, 540ia sport stock bars changed from the 2002 and earlier model years? |
I know the 540 bar's will work people on this site have completed it.Are there major differences?
what's availible in the aftermarket also isn't that great.
You guy's are right I'll approach this cautiously and that's it.V8 I6 big difference,yeah,now I don't know what to do
Of course, that wouldn't be the first time someone posted something there that wasn't true.
Dave I'll take you word for it,I'm not going to believe anyone,like you said people can make thing's up.At this point not sure what to do.
