Are the xenon headlights height adjustable?? - Bimmerfest - BMW Forums
Old 05-19-2009, 03:28 PM
gunship911 gunship911 is offline
Mein Auto: 2003 530i 2011 550xi
It seems like my headlights only shine approx 15 feet down the road. Is there a way to adjust the beam to make it a bit higher? Thanks.
Old 05-19-2009, 03:51 PM
Edgy36-39's Avatar
Edgy36-39 Edgy36-39 is offline
Constantly Learning
Mein Auto: 2006 M3, 2002 M5
Yes, you can adjust. Is the drivers side a lot lower? That bugged me.
You need to turn the yellow allen nut shown in the upder middle area of pic below. Good luck.
BLUE HEAVEN:
Interlagos Blue 06 M3, Autologic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here.
LeMans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Euro rotors, iPod integration. MRegistry listing here.
Old 05-19-2009, 04:10 PM
Thanks. Edgy.
Old 05-19-2009, 04:27 PM
Cool 530i Cool 530i is offline
Mein Auto: 2001 530i
Can auto-leveling xenon headlights be manually adjusted? I heard it cannot be adjusted manually. I'm having the same problem, the auto-leveling operation doesn't work any more and both headlight are pointing downwards. Someone said the adjuster could be broken or bad leveling sensors.
Let's see.
Old 05-19-2009, 04:54 PM
abanjableu's Avatar
abanjableu abanjableu is offline
Mein Auto: 02 540/74 911/01 Z3(hers)
Guys, you have broken headlight adjusters among most who have hellas. Sorry, it sucks. You may be able to bake your lenses off and put in a quick fix, but thats only one option. Use the search option on the site as broken headlight adjusters are quite common. You can always do hid fogs
-Steve
Old 05-20-2009, 07:33 PM
Edgy36-39's Avatar
Constantly Learning
Adjusting the height is one thing, broken adjusters are another entirely.
There are threads on that subject, there are after market fixes, search here and on bimmerforums.
BLUE HEAVEN:
Old 05-21-2009, 01:12 PM
Kudos for this thread for posting an excellent picture that enabled me to locate the yellowish adjuster knobs on the ends of the adjusters inside the headlight assembly.
I've taken the liberty to circle the two adjuster knobs and to give credit where credit is due, thanks ... I re-used your picture in this thread asking for the locations.
Bear in mind, confusingly, people here talk about 'you can't see the adjusters' which are actually INSIDE the headlight assembly; these knobs you can see aren't the adjusters themselves ... they're just the thing you twist to adjust the adjusters. Make sense?
Old 05-21-2009, 07:11 PM
Hey bluebee, how do you make your quotes and notations on the pictures. I would like to learn how. Thanks.
Old 05-22-2009, 07:41 AM
Edgy36-39's Avatar
Constantly Learning
Happy to help! Good luck on the adjustment.
BLUE HEAVEN:
Old 05-22-2009, 12:03 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
The HID lamps are auto-adjusted, depending on the load in the car. There is a deflection sensor above the right side of the rear axle, connected to the suspension arm via a link. This link may be broken
Befor you futz with the adjustment, check this link.
Old 05-22-2009, 02:59 PM
Anyone know if this crack will cause a headlight alignment problem?
Thanks Edgy. When I get time this long weekend, I'll do the adjustment and let folks know the results ... now that I've got most of the locations and procedures figured out from you guys.
One problem is (see picture), my headlight assembly seems to have broken attachment tabs. I will need to dig into realoem if they cause a problem to see which parts they are (hopefully not expensive).
Originally Posted by gunship911 View Post
how do you make your notations on the pictures.
Paint.NET freeware on Windows XP does most of the editing. I just point the mouse.
