Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Classic Bimmers
Classic Bimmers
Discussions pertaining to vintage and classic BMW models here...
Old 06-07-2009, 12:51 PM
bmw3.0cs bmw3.0cs is offline
Mein Auto: 1972 bmw 3.0 cs
1972 bmw 3.0 cs help!
Just bough one yesterday. Gorgeous car. Need all the help, tips, and advice I can get:
When running and / or driving, there is terible and very strong smell of gas and fume, to the point that it makes driving impossible. Any ideas as to why?
Also, need the owners manual for this car. Where can I get one?
Also, what type of oil do you reccommend?
Thank you all.
Old 06-08-2009, 09:25 AM
mgthompson's Avatar
mgthompson mgthompson is offline
Mein Auto: M-Sport128i 328xiT 3.0CS
Just filled the gas tank?
The o-ring for the gas-gauge sending unit on the top of your fuel tank is probably leaking.
Lots of detailed Coupe information here: http://www.e9coupe.com
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon Headlights\iPod\Smartphone
Old 06-08-2009, 10:04 AM
Thanks a lot for the tip. I am going to try and see the mechanic today; hopefully it can be fixed quickly.
Old 06-08-2009, 12:54 PM
HB Chris HB Chris is offline
Mein Auto: 1973 3.0CS, 1969 2002
e9
Gas smell in the cabin is a classic e9 problem, have you done any research on these cars prior to purchase? The gas sender as mentioned can be a cause, how is the trunk seal, does it have the rubber boot around the gas filler, is the gas evaporation tank on the passenger side of the trunk hooked up and is the line at the other end hooked up to the charcoal canister near the battery (it draws a vacuum from the intake manifold)?
The expert in LA is Peter S. (www.coupeking.com), he does restorations and has the manual reprint. Use Castrol GTX 20/50W, that is what BMW specified back in the day. Good luck.
Chris
Old 06-08-2009, 02:50 PM
Thanks!
Old 06-11-2009, 03:20 PM
It turned out to be a bad seal on top of the gas tank, causing some gas to leak. The carbs may also need some adjustment, as they seem to be running too rich.
Thanks for your help...
1972, 3.0, 3.0cs, 72
