#26
If this is a pic of your car, you don't have Xenons... I don't see the silver ballast for the Xenons like below:
Also, your passenger side headlight has a broken tab. See green circle: I received my plastic adjusters yesterday and will be changing them this weekend. Last edited by Max_VQ; 06-17-2009 at 05:45 PM. |
#27
It's great that we now know what it looks like (from your picture) so we can identify the type of bulbs we have based on the "ballast" thingey. |
#28
You are very astute. Maybe that's contributing to why I can't adjust my headlight aim!
I don't know if that broken tab is part of the headlight itself (in which case I need a new headlight) or if it's just part of the bracket that holds the headlight onto the car. Does this broken part belong to the headlight or the bracket? Last edited by bluebee; 06-18-2009 at 07:25 AM. |
#29
Halogen lights simply use 12 volts, just like any other bulb. |
#31
BlueBee-
Do you have OEM hella ballasts or not? That will tell you if you have Hella Xenons or not. The first picture you show on post#27 is an OEM Hella Xenon headlight. I can not tell from the other pictures if your other side looks the same.
I have OEM Hella H7 Halogens with projectors (apparently).
Do you know whether the broken tab is part of the headlight or if it's a separate bracket. |
#33
540s came standard with xenon, it was an option on the I6.
#34
I think it is part of the headlight. Don't worry about it, you still have 3 tabs holding the headlight.
#35
The tab is part of the headlight. If you want to fix it, just take your headlight off and use some JB Weld to patch the crack up. |
#36
I have the same. I thought I was the only unlucky fellow with OEM 2001 Hella Halogens... Most 2001-2003 Hella's have xenon.
I would like to check if my 2002 E39 H7 Halogens are actually Hella brand. Is the word "Hella" stamped anywhere on the headlight assembly?
#39
Yes it should say "Hella" at the bottom middle of the front.
#40
Did you check your lights?
Yes. They are Hella.
I wonder, since the adjusters are so easily broken, what everyone sees in these Hella headlamps anyway? I mean, I understand from the discussion above that they are "the best" ... but what particularly makes them better than whatever is their competition? (Certainly not the adjusters.) |
#42
I see Jared at EAC Tuning has kindly made available the aluminum headlight adjusters! That's wonderful.
Before I go out and buy a full set of four, I still am not sure mine are broken. Of course, I know enough now how to take apart the headlights but rather than take apart the headlights twice, do we have a definitive procedure for testing if the headlight adjusters are truly broken? My symptoms (collectively) are: - Headlights are pointing downward too much - I can adjust up/down but not enough up to compensate - I can't seem to adjust side/side for some strange reason - On each side, the one bulb in rubber wiggles a lot (but it's in rubber) - On each side, the other bulb doesn't wiggle at all when I move it with my hand. Of course, I 'suspect' the headlight adjusters are broken ... but is there a more definitive test I can perform? |
#43
Yes they do break, but replaced they adjust the low Xenon and high QI beams at the same time. Do it with the engine running, then the auto system corrects for load. I find it difficult to understand how anyone can expect to adjust these without using beam setting equipment.
Ian |
#44
Clear circles
Hope this clears the issue. Last edited by sanchorb; 07-18-2009 at 04:25 PM. |
#45
sanchorb....you the man. i was just trying to check out what that was for. thx. as for bluebee bring your car into a garage they dont charge you if broken and cant be adjusted properly....save you lot of time
#46
OMG! I love learning this kind of stuff! Thank you so very much. I've been wondering about that "thing" ever since I first started trying to adjust my lights! Thanks. Bluebee
#47
Alida: Born: Friday, 9th January 1998 Arktissilber Metallic on Schwarz 528i/5 ![]() Fs: KAC-8103D, Kicker 08ts10l52 |
#48
I don't know if you have this on US cars, but on Euro E39's there is a large plastic knob there that you can use to adjust the headlight throw, depending on whether you are driving on the left side of the road (UK, Ireland, a few other places) or on the right side of the road (rest of Europe). So you just turn the knob to change the throw and avoid blinding other drivers, instead of putting stupid opaque stickers over the front of the lights. |
#49
^ that question was already covered on post #44
#50
Well, that is no problem at all, really, in fact, we should be very happy of how informative all people on this forum are. In fact this new post should know better about the use of this mechanism, since he lives in Ireland and probably should need to use it, whereas I live in Costa Rica, and will very likely never need it. Of course I might turn those levers someday to see what happens, LOL. Thank you for the replies...
