Old 06-17-2009, 05:42 PM
Max_VQ Max_VQ is offline
Mein Auto: E39 with a sweet six
If this is a pic of your car, you don't have Xenons... I don't see the silver ballast for the Xenons like below:
Also, your passenger side headlight has a broken tab. See green circle:
I received my plastic adjusters yesterday and will be changing them this weekend.
ID:	189978   Click image for larger version
Old 06-18-2009, 07:14 AM
Yes, that's my 2002 E39. That's great you pointed out the "square silver ballast" as I had read about that but didn't know what it was. I seem to have a differently shaped silver ballast (if that's what it is).
It's great that we now know what it looks like (from your picture) so we can identify the type of bulbs we have based on the "ballast" thingey.
Old 06-18-2009, 07:18 AM
You are very astute. Maybe that's contributing to why I can't adjust my headlight aim!
I don't know if that broken tab is part of the headlight itself (in which case I need a new headlight) or if it's just part of the bracket that holds the headlight onto the car.
Does this broken part belong to the headlight or the bracket?
Old 06-18-2009, 08:26 AM
There are 4 tabs that attach the headlight to the car. I don't think it is a big deal if one is broken. However, it has nothing to do with your headlights not being adjustable.
Old 06-18-2009, 08:34 AM
Xenon lights require high voltage to work. The ballast increases the 12volts up to 20,000+ volts.
Halogen lights simply use 12 volts, just like any other bulb.
Old 06-18-2009, 08:43 AM
Jason5driver's Avatar
Jason5driver Jason5driver is online now
BlueBee-
Do you have OEM hella ballasts or not?
That will tell you if you have Hella Xenons or not.
The first picture you show on post#27 is an OEM Hella Xenon headlight.
I can not tell from the other pictures if your other side looks the same.
Old 06-18-2009, 09:33 PM
I have OEM Hella H7 Halogens with projectors (apparently).
Do you know whether the broken tab is part of the headlight or if it's a separate bracket.
Old 06-19-2009, 05:55 AM
540s came standard with xenon, it was an option on the I6.
Old 06-19-2009, 05:56 AM
I think it is part of the headlight. Don't worry about it, you still have 3 tabs holding the headlight.
Old 06-19-2009, 06:23 AM
RRsE39's Avatar
RRsE39 RRsE39 is offline
Mein Auto: 2001 530iA Sport
The tab is part of the headlight.
If you want to fix it, just take your headlight off and use some JB Weld to patch the crack up.
Old 06-19-2009, 08:34 AM
Roger that.
I have the same.
I thought I was the only unlucky fellow with OEM 2001 Hella Halogens...
Most 2001-2003 Hella's have xenon.
Old 06-19-2009, 08:50 AM
RobV15 RobV15 is offline
Send a message via AIM to RobV15
Mein Auto: 99 528i Sport
or some Quik Steel Plastic Repair putty migh work!
Old 06-21-2009, 09:59 AM
I would like to check if my 2002 E39 H7 Halogens are actually Hella brand. Is the word "Hella" stamped anywhere on the headlight assembly?
Old 06-21-2009, 06:00 PM
Yes it should say "Hella" at the bottom middle of the front.
Old 06-22-2009, 10:32 AM
Did you check your lights?
Old 06-22-2009, 03:26 PM
Yes. They are Hella.
I wonder, since the adjusters are so easily broken, what everyone sees in these Hella headlamps anyway? I mean, I understand from the discussion above that they are "the best" ... but what particularly makes them better than whatever is their competition? (Certainly not the adjusters.)
Old 07-08-2009, 11:21 AM
I see Jared at EAC Tuning has kindly made available the aluminum headlight adjusters! That's wonderful.
Before I go out and buy a full set of four, I still am not sure mine are broken. Of course, I know enough now how to take apart the headlights but rather than take apart the headlights twice, do we have a definitive procedure for testing if the headlight adjusters are truly broken?
My symptoms (collectively) are:
- Headlights are pointing downward too much
- I can adjust up/down but not enough up to compensate
- I can't seem to adjust side/side for some strange reason
- On each side, the one bulb in rubber wiggles a lot (but it's in rubber)
- On each side, the other bulb doesn't wiggle at all when I move it with my hand.
Of course, I 'suspect' the headlight adjusters are broken ... but is there a more definitive test I can perform?
Old 07-08-2009, 11:40 AM
idp@skypro.be idp@skypro.be is offline
Mein Auto: 540i Porsche 911 3.2
Yes they do break, but replaced they adjust the low Xenon and high QI beams at the same time. Do it with the engine running, then the auto system corrects for load. I find it difficult to understand how anyone can expect to adjust these without using beam setting equipment.
Ian
Old 07-18-2009, 04:20 PM
sanchorb sanchorb is offline
Mein Auto: 08 318i...on sale process
Clear circles
Originally Posted by fortunateson View Post
What are the clear circles at the top front of the housing for?
Hi everyone. For those of you who want to know what those circles are, maybe it is because you have U.S. versions, and you donīt need this mechanism. For european versions, instead of these clear circles we have a black cover, which has to be removed in order to access a lever. It is used when you are going into a country which has a different traffic direction than the car. For example if you travel to England with your car, you remove the cover and flick the lever, and the lights realign themselves so as not to blind incoming traffic. It is an interesting feature, which to me symbolizes how much attention to detail german car manufarcturers devote. I am including some pictures of how it looks, and another one from the manual, sorry for the quality but my cameraīs shutter decided to malfunction. I just learned that on another forum, so not only these cars are the ones who give us inconveniences, LOL.
Hope this clears the issue.
ID:	193819   Click image for larger version
ID:	193820   Click image for larger version
Old 07-18-2009, 04:39 PM
E39 Paul E39 Paul is offline
Mein Auto: e39 530i
sanchorb....you the man. i was just trying to check out what that was for. thx. as for bluebee bring your car into a garage they dont charge you if broken and cant be adjusted properly....save you lot of time
Old 07-20-2009, 01:24 PM
OMG! I love learning this kind of stuff! Thank you so very much. I've been wondering about that "thing" ever since I first started trying to adjust my lights! Thanks. Bluebee
Old 07-20-2009, 02:08 PM
ganesht's Avatar
ganesht ganesht is offline
(oOO)\(lll)°(lll)/(OOo)
Mein Auto: 98 528i 5 speed
Hot damn i was always wondering why the euro hellas had that access panel but not the nam spec ones..
Alida:
Born: Friday, 9th January 1998
Arktissilber Metallic on Schwarz 528i/5
Fs: KAC-8103D, Kicker 08ts10l52
Old 07-20-2009, 02:32 PM
willythewarrior willythewarrior is offline
Mein Auto: 2003 E39 520i
Re: what is this thing?
I don't know if you have this on US cars, but on Euro E39's there is a large plastic knob there that you can use to adjust the headlight throw, depending on whether you are driving on the left side of the road (UK, Ireland, a few other places) or on the right side of the road (rest of Europe).
So you just turn the knob to change the throw and avoid blinding other drivers, instead of putting stupid opaque stickers over the front of the lights.
Old 07-20-2009, 02:37 PM
ganesht's Avatar
^ that question was already covered on post #44
Alida:
Old 07-20-2009, 02:44 PM
Talking No problem at all...
Well, that is no problem at all, really, in fact, we should be very happy of how informative all people on this forum are. In fact this new post should know better about the use of this mechanism, since he lives in Ireland and probably should need to use it, whereas I live in Costa Rica, and will very likely never need it. Of course I might turn those levers someday to see what happens, LOL. Thank you for the replies...
