#26
I guess I wasn't sure how easy it would be to route a cable there and was hoping someone already did and could comment... Thanks though.
#27
I have the DICE and I love it!
I just picked up this aux cable for bavauto and am wondering how easy the install is. Do I remove the stereo and hook it up to the back? What should I be looking for on the back of the radio? How do I even remove teh radio? I have some technical skill so i'm sure I can do this myself. Any info would be appreciated.
#29
http://my330i.com/mod26.php
2006 325Ci |
#30
out of all the opt i looked at, changing the HU was the best choice for me, i see the playlist on my new HU it charges the ipod and controls everything, the ipod stays in the glove box,.. am not anal about the stock look.. plus the apine looks good IMO, plus with the new HU everything sounds better..
thanks
Cheap and works
I have the AUX cable in my car with nav. Cable goes to glove box and I have a mic cable that stretches to the drivers side. Works fine, but until I get the iPhone with Pandora, I don't listen to the iPod much. Unlocking the Touch while driving to advance songs is annoying.
2003 330i ZSP 6MT 1995 M3 |
#32
#33
Not really a huge issue with me if it dosnt work but I'd love to be able to get some iphone connectivity with my 99 328i |
#34
The aux input wiring may be cheap but that doesn't charge your ipod at the same time to :-\. daaaaaamnit.
http://www.luxury4play.com 2004 Maserati M128 GT 2000 3-series BMW supercharged Because race car.
#37
I keep thinking about picking up a DICE, but since I have a 2005 car that will play MP3 discs, I'll probably just save my money.
One of the better stock audio system setups I've seen in a car of this class is in my brother's 2007 A4 (B7), which has an in-dash six disc CD changer that will play MP3s right off the disc. Not only this, but it has a large display screen that will read out the name of the song and allow you to cycle through album name, artist name etc, and a full featured menu system that will let you browse the disc as such. The BMW headunit, for the sake of comparison, will still allow you to select songs by folder/album (it works the same way the CD changer does, where the first number is the folder/album instead of the disc and the second is the track number), but it won't show the name of the folder or the tracks that it's playing.
No significant quantities of judgment-impairing narcotics were consumed during or before the creation of this message. |
#38
You have to burn the CD properly with the tags edited etc... And make sure that there compatible with the CD player
#39
You can always lengthen the cables that come in the kit, which is made to go from the back of the in-dash radio to the left side of the glove box. If the jack is mounted where the DSC etc buttons are, then the cord gets in the way of the shifter. One guy mounted it in the front of the little rectangular (toll token?) box behind the cupholders, but said the clearances to the cupholders were very tight but do-able.
If you have the Nav system, they also have a kit for that with a different jack. If it wasn't for the special jacks, you could do it yourself for about $4. $1.69 for the Mini in-panel stereo jack, 3 wires about 2' long, some solder, shrink tubing, and the connectors. |
#42
Good morning and sorry for the question. I just purchased an 04 325i and am looking to put the Aux Input switch into the vehicle. Based on the recommendation of this forum I am going to purchase the Aux cable from Bavauto. I was thinking of mounting it in the cubby hole underneath radio. Are their any better suggestions on where to place it? Or will I encounter any issues doing it there? Also if you've installed this already does anyone have any pictures they can post? Thanks again.
#43
Thanks you guys. I bought the :eBay, eLuka, $36.99+shipping, pics below (inc. in-glovebox installation):
http://cgi.ebay.com/ebaymotors/BMW-E...fAudioQ5fVideo I'll receive next week. I'll let you know how it goes. Anyone know how to remove the stereo? |
#44
http://my330i.com/mod26.php Note that he did it on a car with standard transmission, so there's more room to maneouver the console pieces. If you have a Steptronic, you have to disconnect three cables that energize the shift indicator LEDs, before you can move the shift boot out of the way. That is, of course, if you want to put the jack next to the DSC button up front. If you put it in the glovebox it will be way easier. After you plug the radio head unit back in, you may have to reset the AREA setting in service mode. Mine reset to EUROPE. More info, see here.
2006 325Ci |
#45
My son and I installed the eLuka aux input last week (he did most of the work). The most difficult part was removing the interior trim pieces to get at the radio. The stock eLuka cable connecting the radio to the aux jack is fairly short, would be a stretch to put the jack behind the cup holders, though as the poster noted above, you could extend the cable. We installed it on the panel w/ the DSC button, etc. TRICK - don't use the square panel that says "Auxiliary Input" that fits around the jack. It is shiny black and sticks out on the dash. It is not needed. Just install the jack, very clean look. Yes, you have to drill a hole in your panel. Sound is good!
#46
on ebay for 100 buck these is a ipod connector where you can connect it in the truck by the cd player if you have one and bam! it works like a charm!
#47
I still use cd's. I'm ghetto.
+1 same for Chicago. In the big cities, there are no open spots in the FM band, so the transmitter is always fighting one station or other. I only use mine now on road trips when away from home.
Going the DICE route once I get motivated.
The DICE system rocks, and it's so easy that even I can install it (read: very, very simple).
- Dan |
#50
Any tutorial you followed to install this? I already have a Dension Icelink+ hooked up to the cd changer spot even though I only have a single cd disc. Will installing this mess up the iPod integration? Do I have to choose one or the other? Thanks.
| Tags |
| auxillary, ipod |
