Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW. Sponsored by The Tirerack. Moderated by Gary@Tirerack.com |
Zr Y Rated Meaning
What does y rated and ZR rated mean. I know its speed difference but what does each mean
Y=186mph http://www.tirerack.com/tires/tirete...eral/speed.htm
Belief cannot argue with unbelief, it can only preach to it ![]() ![]() ![]() ![]() To clasp the hands in prayer is the beginning of an uprising against the disorder of the world. |
Any compelling reason to get Y over ZR assuming that your car will never be able to hit 186mph?
2001 E46 330Ci - 42K miles, 2013 E92 M3 - 1425 miles during ED, on TURANDOT headed for PCD |
I was once told that the higher the speed rating, the better; it indicates better structural integrity at 'lower' speeds, as well. Anyone care to refute or confirm this?
"This is a revolution, dammit! We're going to have to offend SOMEbody!" |
So there's a little safety margin built in for those of use that might hit solid triple digits for a few seconds every once in awhile
There is a valid reason to buy the highest speed rating you can tolerate!
Speed rating is based on the ability of the tire carcass to sustain the centrifical force, and the compound to sustain the high temps found during high speed cruising. ...With this in mind, a tire with a high speed rating of ZR or better will be much more stable, and less likely to blow, in the event of a sudden pressure lost at normal speeds. Those first critical seconds... when the tire pressure drops to zero... and the rim is pressing a flat tire against the pavement at speed... are when the extra heat tolerance and reinforced sidewalls will mean all the difference in the world. I can't say a TR or SR tire will fail, but I will say a ZR or YR tire will fail in a much more controlled manner. I will not let my wife (or myself) drive on tires with less than an HR rating. Sure, they cost a bit more, and ride a bit harsher... but the safety margin is everything.
My new Porsche site Flat6News http://flat6news.com/ I am fortunate to have unique press cars delivered weekly, but I own: '13 Audi Q5 2.0T Quattro 8AT '86 Porsche 911 Turbo 4MT Gone, but never forgotten... E70 X5 35d, E90 335i, E46 330i, E36 328i, E70 X5 3.0si, E53 X5 3.0i. ~~~~~~~~~~~~~~~~~~~~~~~~~ Find my work on Autoblog or on my new Porsche site Flat6News! Last edited by Emission; 07-07-2003 at 10:40 PM. |
The "official" speed ratings are S, H, V, Z. Those are the ones you find actually in the tires size designation (except they don't put an S in there).
So you get a 205/50HR15, would be an H rated radial (R) tire. The highest rating is Z, which is above 149. But the tire manufacturers got worried about the speed potential for the super cars and started with additional ratings for Z tires to indicate the actual speed rating above 149. So Y or W rated tire is really a Z rated tire, with additional info. That is why the Y or W, etc. is indicated folowoing the offical tire size and rating designation. The higher the tire rating the better the construction to take the higher heat of high speed running. Typically the better handling tires end up with higher ratings.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
Guess what the Big Mac come shodded with? There are plenty of cars now capable of breaking the Y rating nowadays, and their tires come with Z rating without the upper cap as indicated by the Y and the W. Andy 02 M3 CB/Cloth SMG |
Yes, there are some Z rated tires good for 240 MPH, but you can't tell by the rating.
