Homemade aux input question...i'm stumped! - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Car Navigation, Audio & Electronics by BAVSOUND
BMW navigation, audio upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here!
Sponsored by BAVSOUND
Old 06-24-2009, 02:44 PM
m5james's Avatar
m5james m5james is offline
Send a message via AIM to m5james Send a message via MSN to m5james Send a message via Yahoo to m5james
Mein Auto: 98 740iL - Tweaked a bit
I'm having issues getting my stereo to goto AUX mode in my 01 X5 4.4. I've found various little threads there and there about being able to install an aux input into my cd53 e39/e53 cd player so I can run my Treo through it. At this point i've got about 22 windows open, all pointing in different directions as to if I can install an aux input. I've looked on EAS's site, and it says that I need an 02 or newer E53. I've also found threads that say as long as my SW version on the cd player is 50 or more, I can do it. Then i've found E39 and E46 pictures where either the information changes, the main harness pins (larger pins in the pic below) are round instead of flat like mine, and they've got 10 pins for the aux input where i've got 12 pins.
I've already got resistors, capacitors, and random wiring harnesses to connect directly to the pins....I just need to know if my stereo is capable and which pins to use.
640hp 10 X5///M, Alpine White/Sakhir Orange - Gutted cats, muffler delete, Eurocharged tune
325hp 98 740iL, black/black - Eatin 540's & $hittin 318's
PERFORMANCE:///M5 6spd swap, Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd
INTERIOR:
Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint
EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads
Old 06-24-2009, 06:57 PM
sna77's Avatar
sna77 sna77 is offline
Mein Auto: 2014 F10
This guy made one: http://forum.e46fanatics.com/showthr...hlight=diy+aux
Although thats a lot of work for a $35 part
___________________________________
2014 535i M Sport - Dinan (current)
2011 X5 - Sport Activity Package (current)
2011 e90 (gone)
2004 ZHP (gone)
2001 e46 (gone)
Old 06-26-2009, 11:19 AM
m5james's Avatar
That's one of the same 3-4 writeups i've found, but the back of that radio is different than mine. The larger harness has round pins in a staggered pattern. Mine has flat pins that are all in a straight rows. The stereo is the writeups has 10 pins for the cd player, and 10 pins for the "sound system"...mine has 12 for the cd player, and 12 pins for the sound system.
I'd love to know where you've seen aux connectors for $35. The cheapest i've found is for $39, and it says clearly that it doesn't work on vehicles prior to 9/2002
http://www.autotoys.com/x/product.php?productid=167 - $69.95
http://www.bimmernav.com/store/catal...-item-156.html - $75
http://indashpc.org/new/aux_adapters/car2aux-bmw.html - $55
http://www.europeanautosource.com/pr...roducts_id=297 - $39
All of these are pretty similar, and still 7x what it costs in parts to make it....if I can figure out how.
INTERIOR:
Old 06-29-2009, 08:31 AM
PeteC PeteC is offline
Mein Auto: X3-330XI
Its the radio tuner model that will provide the ability to get AUX. I didn't have the right tuner with my 2001 E46 so I upgraded the radio and connected an AUX cable. None the less I still needed to put a "patch" cable into my tuner to be able to tap into the AUX pins. The car side of the connector still had the round pins. The "patch" cable converted the round pins to flat pins. I went to a version 53 like you have I believe (its been a while) and connected to the following pins. As soon as you utilize the pins you will see the AUX function come up. Attached is the installation for my E83 (which shows E39 and E53 and 12 pin connector). I'm into soldering and computer HW stuff but wanted OEM with the AUX cable. It was worth buying for me. In the E83 I brought the AUX cable to the rear of the vehicle for my CarPC. Did notice an alternator whine now with AUX so have to add a filter.
Attached too is a schematic for making your own.
ID:	191391   Click image for larger version
ID:	191392   Click image for larger version
File Type: pdf E39_E53_E83AuxPortInstallInst - part1.pdf (487.2 KB, 708 views)
File Type: pdf E39_E53_E83AuxPortInstallInst - part2.pdf (232.0 KB, 514 views)
E83 2006 Mods installed: Homelink mirror. CIS-IBUS Nav video module, AUX, Rear DR release, NAV SoftW-Mods, Mud Flaps, sun room Visor, Atom based CarPC. Purchased & pending - BMW CD Changer (NOT Installed). Pending: remote start & LED Angel eyes.
E46 2001 - 18.5 wheels/tires (summer), 17 stock (winter), Homelink, NAV software upgrade, 16:9 display, BMW video module, Radio to V53, AUX, USB IBUS interface,OEM alarm install, Mini ITX computer, tank battery(removed) & remote starter.
Old 06-29-2009, 02:12 PM
m5james's Avatar
I'm surprised that the +/- for each channel don't have their own ground, but per all of the diagrams i've seen, they share a common ground. I don't know which of those three diagrams apply to me, but the pins are numbered on the back of the radio, so i'll if any of them give me any luck.
Per one of these threads below, one of the guys figured it out by putting the + and - together to get the aux mode to come on, then from there it turned into adding resistors and capacitors in final revisions. When I played w/ the back of my stereo, I twisted the wires together also, then just kept trying different combinations of plugs to see if any of them would turn it on.....but no luck. I haven't made my harness as of yet, so maybe I should do that...only problem is I can't find 300k ohms resistors, the closest i've found is 220k and their 1/2 watt, which i'm not certain is correct either.
http://forum.e46fanatics.com/showthread.php?t=422239
http://forum.e46fanatics.com/showthread.php?t=427248 - this is your thread Pete
http://www.bimmerfest.com/forums/showthread.php?t=76934 - this guy Nitraum is the first thread I ever found about this, which is where I started most of my parts purchasing.
INTERIOR:
Old 07-15-2009, 07:09 AM
m5james's Avatar
Bump for alternatives, besides deck replacement...
INTERIOR:
Old 07-26-2009, 01:51 PM
everybest everybest is offline
Mein Auto: 325xi
I think the round pins are for cars pre-1998?
Anyways I have an extra deck here with me 2 years later than yours but with a lesser software number. For that reason, I don't think the software number is chronological, but i could be wrong.
Old 07-26-2009, 02:49 PM
m5james's Avatar
So does yours work w/ aux inputs then? I still wanna do this, I just haven't gotten around to having my ass reamed on ebay for something that I don't wanna spend more than $10 doing. If I have to buy a deck from someone, I guess that's an option
INTERIOR:
Old 07-26-2009, 03:33 PM
Mein Auto: 325xi
I haven't tested it with the aux input at all, but there might be something wrong with it (http://www.bimmerfest.com/forums/sho...d.php?t=386200). If there isn't though, maybe we can work out a trade.
Old 07-26-2009, 03:55 PM
m5james's Avatar
Yeah, if you could test it to make sure the aux portion comes on, I'd be ok w/ that. Personally I don't see how a cd player could scratch cd's, ya never know. I'd think its more along the lines of she's storing the cd's in one of those visor holders that's probably slight rounding the cd's to the shape of the visor, flexing ever so slightly in the CA heat.
INTERIOR:
Old 07-28-2009, 09:04 PM
m5james's Avatar
Bump
INTERIOR:
