camber - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 06-15-2009, 10:44 PM
bughaus bughaus is offline
Mein Auto: 1986 325es
Question camber
Hi
I've got an '86 325es that the previous owner dropped what looks like 3" and I'm getting a lot of inner tire wear with all the negative camber. I think I could buy new coils and make it back to stock and fix the problem, but I considered a camber kit to put the tires in alignment. the local tire shop says they can't get one made for my car.
Anyone know where to get one? Or advice for best ride, drop vs. stock?
Old 06-15-2009, 11:10 PM
88e30is's Avatar
88e30is 88e30is is offline
Yooper
Send a message via AIM to 88e30is
Mein Auto: 88 325ix
With that much of a drop I'm guessing you will always have a camber issue. There are camber correction kits out there but i'm not sure if they can fix that much. Pictures from the rear, I would like to see how much camber a 3" drop gives you. What is your suspension set up? I would go with H&R sport springs with Bilstein Sport shocks and strut inserts.
Old 06-16-2009, 02:41 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
im gunna put my slammed springs in tomorrow so ill get some pics up too if you like. mine drops more than 3" over stock though... haha
E30 above Sold
Last updated 2nd January 2014
Old 06-18-2009, 01:49 PM
Here you can see how much camber there is. And the tire wear one sustained.
ID:	190063   Click image for larger version
ID:	190064   Click image for larger version
Old 06-18-2009, 11:51 PM
nothing you can do about it on the e30 unfortunately, except raise it back up. best to just by new tyres, or keep rotating them, putting the front wheels on the back and the backs on the front periodically, say, every month or two
E30 above Sold
Old 06-19-2009, 10:11 PM
downhiller's Avatar
livin large
you can only adjust the front camber with the addition of a camber adjustment plates. the rears you have to keep swapping or get some hard compound tires.
Old 06-19-2009, 10:22 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
that camber is pretty bad, ive tucked my early model and not had that much camber. check your bushings and all supporting parts.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 06-26-2009, 11:42 PM
How did that turn out?
Old 06-27-2009, 12:13 AM
you didnt ask for me to put some up, but i have a few here from ages ago. i usually only put the springs in for special occassions because its a bitch to get in driveways and things in day to day use with only 60mm clearance or so haha
the first is a standard height E30 (my parts car before it got dismanteld) and Ethrty with the superlows in. the second is the super low springs with the hartge wheels offset 20 i think. the second one doesnt help you.. just for sh*ts and giggles
ID:	191156   Click image for larger version
E30 above Sold
Old 06-27-2009, 01:32 PM
downhiller's Avatar
livin large
/\/\/\/\ i couldnt drive with a car that low. the speed bumps in the areas i lived would high center that in mere seconds. but it looks good.
Old 06-28-2009, 12:57 AM
tell me about it! haha. i used to drive over speed bumps at 45 degrees lol go over the wrong side of the road! luckly not once did i have traffic behind me and if i did then there would be nothing comeing the opposite way. thats why i dont have those springs in there anymore
E30 above Sold
Old 07-02-2009, 10:29 AM
vartyc vartyc is offline
Mein Auto: 1993 325 i
Similar issue with mine...Im going to add front camber plates and also rotate the tires more!
--C
'93 325i, Dsylva E.A.T. Chip, Eibach Springs, Bilstein Sport Shocks, TSW Avus R rims, Ansa Exhaust
alignment, camber, tire
