(Z4MC) Inspection I & II
Just had I-1 done today at 24.5k miles. When I informed the SA that my brake fluid was also due to be replaced (actually 7 months past by now, car was built 11/06), he countered that I was actually 2 months away from being due.. because he was going by the date the car was sold, not the manufacture date, as is proper. They did it anyway though they seemed baffled at this bit of info.
I'm realizing now that I-2 is going to be past 50k miles, and as such not a freebie. Wonderful. My local stealership charges $759.95 for an I-1 on a Z4M, and a whopping $1449.95 for I-2.. which is absolutely outrageous considering that the latter only adds tranny and diff fluid replacements, an air filter, and spark plugs. Are they on crack??? I'll find a good indy shop by the time I-2 rolls around. |
You can always consider buying the extended warranty/maintenance. Should run you a few Benjamins on top of the Inp.II.
2008 M Coupe - Current Whip 2006 M3 - ZCP - Gift to my little brother ![]() 2004 330i - ZHP - SOLD
Hmm ... I thought I-1 was free? Why did your dealer charge you ...
If you find an indy shop doing it for less then a grand they are probably not doing what they are supposed to be. Also if they do not tell you to leave your car overnight and pick it up the next day LATE in the day they are not doing it right. To properly shim the valves it's best to leave the car overnight ready to pull the cover off and check/shim clearances then.
http://www.youtube.com/watch?v=OqX7IIaXtkg Is it on a dyno? No. ![]() TCK d/a coilovers, Stoptech 6/4 piston BBK, OEM CSL headers Last edited by blau335; 07-01-2009 at 09:06 AM. |
I didn't leave them out.. that huge price delta between I & II is only for the mentioned additional items. Oil, cabin filter, valve adjustment, etc., is part of the I price. No way that adding the few additional items should almost DOUBLE the price of I.
Any comments from BMW techs on whether their shop keeps cars overnight when doing a valve adjustment? Your comment makes perfect sense, I'm curious if dealership shops are actually adhering to this advice or not. Mine obviously didn't. ![]() Does anyone possibly have an internal document instructing a cooldown period before valve adjustment? If one exists, I want to bring it to the service manager's attention. |
http://www.youtube.com/watch?v=OqX7IIaXtkg Is it on a dyno? No. ![]() TCK d/a coilovers, Stoptech 6/4 piston BBK, OEM CSL headers |
35 degrees C
I prefer to do valve check/adjust when engine is over-night cold.
Jim Millet 2007 Imola Red Z4 M Coupe' Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates. |
Dammit, I was just reading through the TIS to double check the clearance values and figured I'd post the coolant temp, but you beat me.
I wish I had a .28 feeler, but bmw doesn't even sell feelers even close to the min and max of the clearances, it's got to be a PITA. Inlet min is .18-.23, bmw techs are sold .15 .20 and .25 What if the valve is at .16 or .17? the .20 and .25 wont fit, but the .15 will, the tech would have to assume it's in spec, even though it would be tight. BMW does some dumb stuff sometimes.
http://www.sears.com/shc/s/p_10153_1...?keyword=40802 |
I think you guys missed the point, BMW only sells their techs feelers in .05mm increments I have feeler gauges that are appropriate (I have the same set as you actually), I'm talking about the monkies at the dealer. If they just used bmw tools customers would be boned.
