Discussion pertaining to the flagship BMW here. |
Hey all, I washed under the hood of my 02 745i today with regular degreaser soap and water, now my Hood Open Warning keeps coming on via the instrument cluster AND idrive. I've closed it and opened and closed it but still nothing. I even held down both spring release sensors and had my sister pull the release to try to reset it, not sure what's happening. Also, my alarm went off a few times today, each time about 2 or 3 minutes after locking all the doors. Could this all be related? Thanks for any help!
-Frank
sounds like a 2002 745
but u could have shorted something out when u were cleaning under the hood and concerning the alarm issue, i am pretty sure its related to the hood not being locked
'03 745i - modded - GONE - |
wow good luck
BMW ANGEL EYES ALL MODELS MTEC H8 V3'S/CITY VISION/DTEC/WEISSLICHT/LUX H8 WHITE BMW EXTERIOR PARTS + BMW PAINTED TRUNK/ROOF SPOILERS/SPLITTERS MTEC HALOGEN BULBS MTEC PHILIPS D1S/D2S/D3S/D4S HOT BMW LED INTERIOR KITS E9X/E60/F10 info@e92-lighting.com AIM:electronicwoot PAYPAL:electronicwoot@gmail.com PH: 714)270-7333 |
measure with a multimeter on the hood open sensor and see what happens when you open/close it
+1 on the shorted scenario!! Under no sircumstances wash the engine bay, its better to just dust it off simply becouse of electronic issues in the future caused by to much water on the connector plugs. Make shure the plug connectors are not rusted out causing errors on your idrive.
Issue resolved! Thanks for everyone's help!!
-fwd |
well what was it??????????
2004 745i 2001 X5 2006 FXSTBi Night Train FOR SALE $15,850.00 over 30k Invested 4k miles 2001 Modified Triumph Daytona 955i SOLD 2005 SRT10 Ram |
Does anyone know where the sensor is located. Having the same problem on my 03 745Li
2003 745 Li 2007 ZX-14 2007 VN2000LT 2007 GV650 2000 Beetle GLX 1.8T |
The sensor is located on the drivers side up by the windshield. It is a button that pops up and down with the hood. Had the same problem on my 2002 and I just ordered one and replaced it. The problem arose after I decided to wipe the engine bay down with armorall.
2012 535xi|Dark Graphite|Black Interior|M-Sport| Prior BMW's: 1987 325e|1993 740i|1998 740il|2002 745li|2007 750li|2006 750li |
I'm having the same problem and trying to figure this out. |
I am having this same issue. To the OP how did you get it fixed.
My Rides Nick Named: 1 BAD 5 & BAD 3 When in doubt flat out. ![]() Cobb Tune, Rennart Catback non-resonated exhaust |
Under the hood. When standing in front of the car with the hood open, the pop up/down button will be up towards the right front edge of where the hood will be when closed.
I just unpluged the switch on my car problem fixed!
Interesting, I did not know about the sensor, but I was told by the dealer to try to turn in the rubber stoppers just a little, and that cured my problem. I would try it.
You can use a multimeter to make sure the switch actually works; if it does, just adjust it like badgerbob mentioned.
White 2007 Alpina B7 Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts Black 2002 BMW E66 / 745Li (sold) KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights... |
check the wiring from the nhood relase senors i had the same problem like u kinda and the wire was loose so it was trowing the code
CLOSED.
M.Wong E38 2000 740iL Orient Blue E91 2012 328xiT Alpine White Passed on to new families: E30 1987 325i Royal Blue E39 2003 540i/6 Sterling Gray R56 2010 Mini Cooper S British Racing Green
| Tags |
| 745, hood, warning |
