Mityvac Oil Change - Bimmerfest - BMW Forums
Old 07-15-2009, 06:49 PM
conzbmw's Avatar
conzbmw conzbmw is offline
Mein Auto: 2000 BMW 328ci
Thumbs up Mityvac Oil Change
The marine mechanics shop next to my work gave me a huuuuge mityvac that holds about 15 litres. So excited to have this addition for free!
Does anyone have an suggestions for this process. Im under the understanding that you just put the tube down the dip stick and start pumpin' (obv with removal of the oil filter etc). Is there anything else that I should be aware of seeing as I have never done an oil change on my e46 before.
Thanks.
BMW 328i 250
Old 07-15-2009, 06:51 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Thanks.
Nope. Straightforward. You won't even need to get under the car or get dirty! Great score!
Old 07-15-2009, 07:17 PM
djstrachan's Avatar
djstrachan djstrachan is offline
Mein Auto: 2004 325i ZSP
Thanks.
Use the largest tube that will fit in the oil dipstick tube as that will speed up the process.
Make sure you use some rags around the oil filter assembly when you take out the oil filter 'cause oil tends to drip.
That's it!! No fuss no muss and no jacking!!!
"It is little use listening to other people as they will either be agreeing with you or saying stupid stuff" - Dogbert
I'm not a pessimist. At some point the world sh!ts on everybody. Pretending it ain't sh!t makes you an idiot, not an optimist.
2004 325i - Sport package - 5MT- clears - CDV mod - M3 gauge faces w/silver gauge rings & red needles - SS exhaust tips - strut tower brace - Hotchkis anti-sway bars -50% tint - shadow grills - roof spoiler - silver CF trim
Old 07-15-2009, 07:21 PM
conzbmw's Avatar
awesome thanks you guys! Yeah its a great score! Im looking forward to doing it this weekend..ive put 4500 miles on it in 8 months!
Yeah im excited about the fact that I dont have to jack the thing up!
BMW 328i 250
Old 07-15-2009, 07:29 PM
smolck's Avatar
ROLL TIDE!
Fixed with the appropriate smiley
Old 07-15-2009, 07:35 PM
kimmy's Avatar
kimmy kimmy is offline
Das rampen abwarten
Mein Auto: 04 330xi,Audi A6,AlfaSpid
Quick question regarding Mityvac.
Just got a 7201.
I usually have done oil changes with the engine warm to try to get more junk out. I am thinking, however, that temps like that might not be healthy for the PE tubing; and the last thing I want to do is end up with part of it softening/coming apart and jammed up in my pan or elsewhere.
Thoughts experience on temp?
Old 07-15-2009, 07:39 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Just got a 7201.
Yeah, I thought so too, at first. I usually let it cool approximately 1 hour before inserting the tube into the dipstick. I mean, the oil is hot, but not say, hotter than a bride's kiss, as my father (RIP) used to say.
No problems in about four years of use.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 07-15-2009, 07:48 PM
djstrachan's Avatar
As this is the OP's first experience with the Mityvac, I hope he doesn't take you seriously and think that is part of the process. Not that it would do any damage, or can cars go blind??.
I warmed my engine up to operating temp and used the Mityvac right away. No problems at all and the tubing showed absolutely no signs of softening. I do believe the hot oil temp was factored into the material design based on it's intended use.
Old 07-15-2009, 08:13 PM
Gryphon's Avatar
Gryphon Gryphon is offline
The Boss of Nobody
Mein Auto: 2005 ZHP, Wife's Prius
I run my engine for about 10min before I use my Mityvac 7201, temp hasn't been an issue. I use the largest tubing that will fit the dipstick. Insert the tubing until it hits the bottom of your oil pan, then withdraw the tubing just a bit so it's not in contact with the pan. Start pumping about 10-15 pumps, let it take up what it can on that amount of suction. Once it no longer has sufficient suction, I'll pump the vac again a few times. Once you start pulling air, sounds like little metal pinging, you can advance the mityvac tube fully to get any residual.
I have a plastic bag waiting immediately for when I remove the oil filter, wrap it in the grocery bag and tie it off.
Arthur John "Destroyer of Sleep"
Born 02-24-11
Sean David (has more rolls than a bakery)
Born 06-22-16
Old 07-15-2009, 11:28 PM
conzbmw's Avatar
thanks for the input guys.
Back in March I had a slight oil filter housing leak that stopped when the spring hit. Am I at any risk of triggering this problem by using the Mityvac. I read on a 325i DIY on this that you should check the oil filter housing once you've refilled the engine with oil.
BMW 328i 250
Old 07-16-2009, 05:04 AM
MicahO's Avatar
MicahO MicahO is offline
In my own cars again
Mein Auto: 330i ZHP
You don't need to check the filter housing, though you should circle back and check the oil level after the motor has run. Swap the filter, close the housing, put in the right amount of oil (~6-6.5qts), check for a good level. Run the motor then let it sit a few minutes, check the level again and top off if needed.
These filter housings don't need to be burped like the one on my old 535 did. That was messy once. Quick learning curve......
--Micah O'C
CCA 193374
'88 M5, Bilstein Sports/ST Springs, staggered BBS RS, Euro conversion
'92 M5 Touring - BL01001 - first M5 Touring ever built
2017 M2 V887285 - Mineral Grey, 6MT
'04 330i ZHP, Jet Black 6spd, hot seats, LightWerkz TFX-Xenon, Bilstein PSS10
UUC Strut/SwayBarbarians, PowerFlex CAB/TAB, Performance Gearing 3.38 LSD
Old 07-16-2009, 07:46 AM
Gryphon's Avatar
The Boss of Nobody
Just remember to wet the new filter housing o-ring with some excess fresh oil before you torque it down to ensure a proper seal.
Born 02-24-11
Born 06-22-16
Old 07-16-2009, 03:51 PM
...and make sure you pay attention to WHICH grove the ring sits in on the filter housing cover!
- J.C. Watts Jr.
Old 07-16-2009, 05:34 PM
djstrachan's Avatar
Not speaking from experience I hope? Now that would be a recipe for mess and damage!!
OP - if you are looking for the 36mm socket for the filter cover, Princess Auto has them for $9Cdn. It is a 3/4 drive but you can get a 1/2 to 3/4 adapter at Princes Auto for $8Cdn and you are set. This set up is cheap but effective and allows me to use my torque wrench for this process (18 Ft Lbs).
Old 07-16-2009, 06:03 PM
Absolutely not!
- J.C. Watts Jr.
Old 07-16-2009, 11:52 PM
conzbmw's Avatar
I thought there was just the one groove that the rubber ring fits into? anyone care to elaborate?
BMW 328i 250
Old 07-17-2009, 12:33 AM
djstrachan's Avatar
Just having some fun. The o ring goes on the last groove just under the cap. Push it all the way to the top and you are good to go.
If you're not sure how well your car had been maintained or how frequent the oil changes have been, you may want to change the 2 small o-rings within the filter housing as well. THey don't come with the oil filter kit so you would have to get them at an auto parts store or the BMW dealer. Probably cost .50 cents each. The Bentley Manual recommends these be changed with every oil change which, if you are following the BMW schedule, is every 25,000kms. I do my changes every 12,000kms and plan to change out the small o-rings every 24,000kms.
Old 07-17-2009, 04:08 AM
Gryphon's Avatar
The Boss of Nobody
Nice tip.
It's early and I'm on my first cup of coffee, I saw 20,000mi and 12,000mi instead of km....
I'm like that's awefully long between oil changes.
Born 02-24-11
Born 06-22-16
Old 07-17-2009, 08:39 AM
djstrachan's Avatar
Nice tip.
That would be a rather long interval. I wait until I have had at least 2 cups of coffee before I atempt to read anything remotely technical.
Old 07-17-2009, 10:50 AM
Melquin Melquin is offline
Mein Auto: 2005 330i
Nice tip.
I think you can be forgiven for that. NASA crashing the Mars Climate Orbiter into the planet because contractors forgot to convert imperial->metric is another story.
Old 07-17-2009, 01:14 PM
Gryphon's Avatar
The Boss of Nobody
Yeah, we were all laughing at them in Kinematics class....until we realized in the end we foot the bill.
Born 02-24-11
Born 06-22-16
