Changing water valve........ - Bimmerfest - BMW Forums
Old 07-16-2009, 02:26 AM
leisey leisey is offline
Mein Auto: 318i 2000 Model
Anything to watch out for when changing the water valve (heater control valve)? Looks fairly simple, couple of hose clamps and an electrical connection. Is their any chance of getting an air lock in the cooling system? If so, how can you tell and how do you fix.
Cheers
Dave
Old 07-16-2009, 08:03 AM
Spdu4ia Spdu4ia is offline
Mein Auto: X5 4.4i
i am doing mine soon too... I would assume you need to bleed the cooling system . Hopefully someone can chime in.
-Travis-
Old 07-16-2009, 01:39 PM
Can anyone help with bleeding cooling system?
Cheers
dave
Old 07-16-2009, 03:43 PM
Nando779's Avatar
Nando779 Nando779 is offline
Send a message via AIM to Nando779 Send a message via Yahoo to Nando779
Mein Auto: 2003 325Ci, Orient Blue
Cheers
dave
My guess to be safe would be to do a coolant flush. The cooling system is bled when you are SLOWLY refilling it with coolant with the bleeder screw loose.
http://www.bmw325i.net/maint_coolant_change.shtml
Old 07-17-2009, 12:36 AM
I changed the valve and only lost a thimble full of coolant - started it up to operating temp and all seems ok. I now have air con that can cool as well as heat.
Cheers
Dave
