E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
The marine mechanics shop next to my work gave me a huuuuge mityvac that holds about 15 litres. So excited to have this addition for free!
Does anyone have an suggestions for this process. Im under the understanding that you just put the tube down the dip stick and start pumpin' (obv with removal of the oil filter etc). Is there anything else that I should be aware of seeing as I have never done an oil change on my e46 before. Thanks.
BMW 328i 250 |
Make sure you use some rags around the oil filter assembly when you take out the oil filter 'cause oil tends to drip. That's it!! No fuss no muss and no jacking!!!
"It is little use listening to other people as they will either be agreeing with you or saying stupid stuff" - Dogbert I'm not a pessimist. At some point the world sh!ts on everybody. Pretending it ain't sh!t makes you an idiot, not an optimist. 2004 325i - Sport package - 5MT- clears - CDV mod - M3 gauge faces w/silver gauge rings & red needles - SS exhaust tips - strut tower brace - Hotchkis anti-sway bars -50% tint - shadow grills - roof spoiler - silver CF trim |
awesome thanks you guys! Yeah its a great score! Im looking forward to doing it this weekend..ive put 4500 miles on it in 8 months!
Yeah im excited about the fact that I dont have to jack the thing up!
BMW 328i 250 |
Quick question regarding Mityvac.
Just got a 7201. I usually have done oil changes with the engine warm to try to get more junk out. I am thinking, however, that temps like that might not be healthy for the PE tubing; and the last thing I want to do is end up with part of it softening/coming apart and jammed up in my pan or elsewhere. Thoughts experience on temp? |
![]() No problems in about four years of use. |
![]() As this is the OP's first experience with the Mityvac, I hope he doesn't take you seriously and think that is part of the process. Not that it would do any damage, or can cars go blind??. Quote:
I run my engine for about 10min before I use my Mityvac 7201, temp hasn't been an issue. I use the largest tubing that will fit the dipstick. Insert the tubing until it hits the bottom of your oil pan, then withdraw the tubing just a bit so it's not in contact with the pan. Start pumping about 10-15 pumps, let it take up what it can on that amount of suction. Once it no longer has sufficient suction, I'll pump the vac again a few times. Once you start pulling air, sounds like little metal pinging, you can advance the mityvac tube fully to get any residual.
I have a plastic bag waiting immediately for when I remove the oil filter, wrap it in the grocery bag and tie it off.
Arthur John Born 02-24-11 Has already been awarded the title "Destroyer of Sleep" |
thanks for the input guys.
Back in March I had a slight oil filter housing leak that stopped when the spring hit. Am I at any risk of triggering this problem by using the Mityvac. I read on a 325i DIY on this that you should check the oil filter housing once you've refilled the engine with oil.
BMW 328i 250 |
These filter housings don't need to be burped like the one on my old 535 did. That was messy once. Quick learning curve......
--Micah O'C CCA 193374 '88 M5, Bilstein Sports/ST Springs, staggered BBS RS, Euro conversion '04 330i ZHP, Jet Black 6spd, hot seats, LightWerkz TFX-Xenon, Bilstein PSS10 UUC Strut/SwayBarbarians, PowerFlex CAB/TAB, Performance Gearing 3.38 LSD
Now that would be a recipe for mess and damage!!OP - if you are looking for the 36mm socket for the filter cover, Princess Auto has them for $9Cdn. It is a 3/4 drive but you can get a 1/2 to 3/4 adapter at Princes Auto for $8Cdn and you are set. This set up is cheap but effective and allows me to use my torque wrench for this process (18 Ft Lbs).
"It is little use listening to other people as they will either be agreeing with you or saying stupid stuff" - Dogbert I'm not a pessimist. At some point the world sh!ts on everybody. Pretending it ain't sh!t makes you an idiot, not an optimist. 2004 325i - Sport package - 5MT- clears - CDV mod - M3 gauge faces w/silver gauge rings & red needles - SS exhaust tips - strut tower brace - Hotchkis anti-sway bars -50% tint - shadow grills - roof spoiler - silver CF trim Last edited by djstrachan; 07-16-2009 at 05:40 PM. |
I thought there was just the one groove that the rubber ring fits into? anyone care to elaborate?
BMW 328i 250 |
If you're not sure how well your car had been maintained or how frequent the oil changes have been, you may want to change the 2 small o-rings within the filter housing as well. THey don't come with the oil filter kit so you would have to get them at an auto parts store or the BMW dealer. Probably cost .50 cents each. The Bentley Manual recommends these be changed with every oil change which, if you are following the BMW schedule, is every 25,000kms. I do my changes every 12,000kms and plan to change out the small o-rings every 24,000kms.
"It is little use listening to other people as they will either be agreeing with you or saying stupid stuff" - Dogbert I'm not a pessimist. At some point the world sh!ts on everybody. Pretending it ain't sh!t makes you an idiot, not an optimist. 2004 325i - Sport package - 5MT- clears - CDV mod - M3 gauge faces w/silver gauge rings & red needles - SS exhaust tips - strut tower brace - Hotchkis anti-sway bars -50% tint - shadow grills - roof spoiler - silver CF trim Last edited by djstrachan; 07-17-2009 at 12:41 AM. |
Nice tip. It's early and I'm on my first cup of coffee, I saw 20,000mi and 12,000mi instead of km.... I'm like that's awefully long between oil changes.
