E46 (1999 - 2006)
Old 07-17-2009, 06:03 PM
raymondaecom raymondaecom is offline
Mein Auto: 2001 BMW 325i
code read..car stall
When I turn on the car, it start and then the rpm drop to 0 and stall. Check engine light is on. So, I check the code using the INPA software. IT turns out..there are 4 errors....all of them are:
90 TEG_up_1
N_32 672 rpm
MAF 119.84mg/stk
TCO 97.5 Grad C
V_TEG 0.02v
and also the other code called
92 TEG_down_1
What does TEG_up and down mean?
I have cleaned the MAF IAC and throttle body....the car gains power back to normal...however, the stall still happens sometime.....but not all the times...
Old 07-17-2009, 06:06 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP & 04 Honda VFR
What's INPA software? Use a standard ODB2 reader and give us a Pxxxx code...
Old 07-17-2009, 06:17 PM
I will try to get the PXXX code .....
I did try goggle on TEG_up or down...but nothing come up in english..
only come up in other lang. I cant read......hope someone can help and read it..
thanks
ray
