E28 (1982 - 1988)
Old 07-27-2009, 09:11 PM
Sortma20 Sortma20 is offline
Mein Auto: 1983 528e
e 28 HELP ASAP
I need help with the torque specs and the head bolt sequence ASAP PLEASE HELP
thanks steve
Old 07-27-2009, 09:15 PM
for got to say it was a 1983 528E \
sorry
Old 07-27-2009, 09:25 PM
south26 south26 is offline
Mein Auto: 535i 1989
What kind of head bolts are you using?
I can tell you in the morning sorry I can not help now.
Andy
Old 07-27-2009, 09:28 PM
what do you mean
i think there 5/16 torques bolts
idk the manufacture
but i can wait till morning
Old 07-28-2009, 09:19 AM
Hi the reason that I asked about the bolts was because there are 2 different kinds. One is Torx head bolts and the other is hex head bolts and the torques are different. Also if you are putting the head back on youhave to tighten the bolts in a certain order or bad things can happen.
The order of tightening is as you are looking down at the head on the passenger side.
12 10 4 2 6 8 14
13 7 5 1 3 9 11
This is for torz head bolts, it can be done with the engine being cold and there is no time that you have to wait until you do the next stage.
Stage one 22 ft-lb
Stage two 90 degrees
Stage Three 90 degrees
This is for hex-head bolts
Stage one 29+4 ft-lb
Then wait 15 minutes
Stage 2 44+4 ft-lb
the run the engine until fully warm(about 25 minutes)
Stage 3 25+5 degrees
I hope this helps.
Andy
By the way where are you located in Ohio
Andy
