Wtf??? Selflevl suspension inactive!?!?!?!?!?!!! - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 08-17-2009, 04:26 PM
thekingsim0n thekingsim0n is offline
Send a message via AIM to thekingsim0n
Mein Auto: BMW X5 4.4i
This is driving me FREAKIN INSANE!!!
Every now and then i get a light that comes up saying Self_Level Suspension Inactive. I turn off the car, turn it back on, it goes away, when the light coems back, i put the car in park, look and MEASURE both back tires, since in 4.4i the back tires are the only ones with air suspension, there both perfectly the same. the drive lately, however has been a LITTLE bumper then normal. but maybe its just me being paranoid? :/ the light comes on and off rarely and IDK what 2 do anymore!
Any one ever had this issue? if so how did you fix it? :/
it cant be that my air suspension is messed up because if that was the case then the back tires would be lower or higher then normal, and it isnt. :/
I do no that I have a bad / bended front right lower control arm but can that be the cause of the suspension light coming on? :/ I cant see how because its in the front but idk?
Please help!
Old 08-17-2009, 04:32 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
Good luck dude.
My X5's problem with the suspension is that the right side of the car sits lower after a while compared to the right, but once I turn on the car it levels up to the right level.
Old 08-17-2009, 05:17 PM
Yeah but DANNGG from your picture on the right side you keep ur X5 madd low :/
