E36 325 Annoying squealing engine noise - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 07-14-2008, 10:38 AM
alexe34 alexe34 is offline
Mein Auto: BMW E36 325i
Question E36 325 Annoying squealing engine noise
Hi, my 1992 E36 325 manual has an extremely annoying squealing noise coming from the belt area. It is a constant sound at all revs.
I posted this problem before and tried many solutions but none have worked as of yet. The squealing noise is definately coming from the belt/engine area. I've had a new belt, new tensioner, alternator has been tested by my mechanic but neither of us can find the cause of this annoying noise.
Does anyone have any ideas??
Thanks very much
Old 07-14-2008, 11:14 AM
-Matt-'s Avatar
-Matt- -Matt- is offline
Mein Auto: 1999 528i SE
That type of noise is (as you say) usually associated with the belts and pulleys. In order to find which pulleys are causing the noise you can use a stethescope.
Failing that you can try pressing the pointy end of a large screwdriver on the (non moving) nut that holds each pulley. Put the handle of the screwdriver to your ear and you should be able to hear any bearing grinding noises over the general engine noise.
Using this technique you should be able to pinpoint which pulleys are giving you the problem.
You obviously need to be careful not to get the screwdriver caught up in the belts and getting access can be tricky. It may well be safer and easier to buy a cheap engineers stethescope. (Engineers stethescope has a pointy tip rather than flat plate like a doctors one).
Old 07-14-2008, 11:37 AM
Ok, my mechanic couldn't find anything wrong with the belt or the tensioners (which are new)
Is there anything else I can try?
Old 07-14-2008, 12:49 PM
B/\/\W's Avatar
B/\/\W B/\/\W is offline
Monacoblau mit beige
Mein Auto: E92 330i Manual
I'd say so, if you value your hearing! Touch a medical stethoscope onto any mechanical moving parts and you'll probably burst your ear drum.
330i SE coupé
Manual - N52K 262hp, 232ft-lb
Old 07-14-2008, 02:08 PM
-Matt-'s Avatar
I meant safer than the screwdriver method but
Well you said the noise was coming from that area - there must be something causing the noise. If you can locate which part is causing the noise then you are half way there to solving the problem. Don't just test the tensioning pulleys - check the ac compressor, water pump, etc.
Old 07-14-2008, 02:19 PM
Dave 330i's Avatar
Dave 330i Dave 330i is offline
The King of Common Sense
Mein Auto:
I would spray WD40 all over the place. Get it by the case.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton.
Old 07-14-2008, 07:54 PM
FadetoCrimson1's Avatar
FadetoCrimson1 FadetoCrimson1 is offline
Send a message via AIM to FadetoCrimson1
Mein Auto: 1993 BMW 325i
woaaaaa!!! what if a fire breaks out!
AEM Dryflow CAI- Depo Gen 4 Headlights with Angel Eyes and 6000k HIDS- Silver Instrument Cluster Rings- Euro Plate- Euro Clear Indicators- Euro Clear Taillights- Painted Skirts- Pioneer Headunit- Chrome Exhaust Tips- Pirelli Tires- Limo Tint Back, 20% Front- Red Gauge Needles- Bimmerfest Stickers!!!
-Andy
Old 07-14-2008, 08:58 PM
Edev's Avatar
Edev Edev is offline
BMW Genius @ BMW Portland
Mein Auto: M Coupe
ha. i have the same thing going on for mine. except it only happens in reverse..and in 1st gear..but then goes away in about 10 seconds or less. its really odd..i dont understand it. basically everything under the hood is brand new. i was told that one of the belts (alternator) is a tad bit too long. but also i should spray this stuff (not sure what its called) on the belts and components while the engine is on..just so it can get through the whole thing
BMW Genius @BMWPortland.
2000 Z3 M Coupe
Old 07-18-2008, 10:46 AM
Hi, ok I used a mechanic stethoscope and the squealing noise is at its loudest on the alternator. Is it certainly the alternator then?
Old 07-19-2008, 05:22 PM
E36 Phantom's Avatar
I Am The Machine
You could try disconnecting the belt over the alternator if you have the separate ones. If you have a serpentine you can't really tell easily.
Also, if your belt isn't OEM, it could be a little oversized and slipping on the pulleys.
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 07-21-2008, 11:40 AM
Flea7 Flea7 is offline
Mein Auto: E92 M3
I have this problem ...only when the car is cold and is not warmed up. The belt is loose somewhere?
Old 07-21-2008, 12:30 PM
Edev's Avatar
Mein Auto: M Coupe
yup. thats what my mechanic said. the belt on my alternator is a tad too long..even with the adjusters all the way out. someone mentioned wd40? or some other type of spray to make the squealing go away?
2000 Z3 M Coupe
Old 07-22-2008, 12:34 PM
This would be an option for me, however I have had a new belt put on and the squeaking noise is still there and exactly the same...
Old 07-28-2008, 01:10 AM
Edev's Avatar
Mein Auto: M Coupe
so does anyone know if there is some sort of spray that is available that will make the squealing go away?
2000 Z3 M Coupe
Old 07-28-2008, 01:34 AM
big-tex's Avatar
big-tex big-tex is offline
(Insert one liner here)
Mein Auto: Tha 'Runner
Just to chime it, I'm purddy sure WD-40 isn't flameable, just the propellant, so buy the gallon container and pour it on, there's also belt conditioners that might help, but nothing beats a tight belt. If y'alls problem isnt with a loose tensioner or bearing, I would go with the wd-40 idea. I think Gunk is the brand of belt conditioner I saw somewhere, but ask at any napa, autozone, ect. and they'll point you the right direction.
Old 07-28-2008, 07:17 AM
toddstaples toddstaples is offline
Send a message via AIM to toddstaples
Mein Auto: 1995 BMW 318i red
I had the same issue pretty much and it turned out to be two things. The tensioner pulley for my AC belt was bad so i replaced that and that noise went away. I found out it was that by taking the AC belt off and the noise went away.
So i fixed that and then started to hear a different squeal. That one turned out to be an old Serp. belt, replaced that one and the noise went away again. The way i found that was I sprayed WD40 on the belt and the noise would go away, then come back after 5 minutes. That told me that the WD dried up and the belt started squealing again.
Now if you have a serpentine belt that's not the right one, why dont you replace it with the right one with the right tension? Sounds like that's the solution right there? If you take the WD approach you'll just continuously be squirting that on your belts and it will just get annoying. The right belt for me cost 30 bucks at napa and i never have to worry about it again.
Old 08-19-2009, 12:38 PM
sillycar sillycar is offline
Mein Auto: 1994 325is
sounds like you need a new mechanic. the spray you're looking for is silicone spray, it lasts a bit longer than wd40 but won't make the squeal go away permanently.
i have the same squealing noise, and my mechanic incorrectly diagnosed the alternator as he probably didn't want to fix the idler pulley and just told me he inspected the belts and probably did nothing
i checked with a piece of wood or long screwdriver and it's not hte alternator. i am going to take it back to him and watch while he works, he didn't charge me anything last time
Old 07-25-2015, 01:37 PM
Keith843 Keith843 is offline
Mein Auto: 92 325i
I'm having this same issue. It didn't squeal until I put the new belt on. I've checked all the pulleys for play, dents, cracks. Checked the belt itself all the way around, and also checked the fan clutch tightness, because I took the fan off when I replaced the belt. I sprayed some WD-40 silicone spray on it and he swueal went away for about 20-30 minutes. So my question is, is my belt too tight? Since adding a lubricant to it, it sounds fine.
Old 07-25-2015, 09:29 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Adding lubricant to your belt is the absolute worst thing you could possibly do. Belts squeak because they are slipping. Adding a lubricant will temporarily cause the squeaking to go away because it's oily, but it will cause it to slip a lot more and make things worse in the end. Belts and pulleys should be 100% free of any oil or other lubricant.
Your belt can't be "too tight" because the tensioner is spring or hydraulically pressured and determines how tight the belt is at all times. Are you sure you were sold the correct length belt? Did you compare the old and new belts? I've had parts stores sell me the wrong belt on more than one occasion.
1998 BMW 328is
1966 Pontiac GTO
Old 07-27-2015, 02:55 PM
john kaminski john kaminski is offline
Check the serpentine belt alignment. If it is just a little off it will be noisy. Look where the belt comes from the grooved pulley to the smooth idler pulley - is it running perfectly straight onto the idler ?
The belt won't self center and you may need to take the tension off the idler and push the belt over to the proper alignment.
Cheap Trick
