E30 (1982 - 1993)
Old 08-24-2009, 08:53 PM
Krumchev2's Avatar
Krumchev2 Krumchev2 is offline
Straight Bimmin
Mein Auto: 91' 318ic
Check engine light on and off
Sometimes my check engine light comes on, usually at high speeds. But usually when i let off the gas quickly it turns off, but not if i ease off the gas? Any ideas?
Old 08-24-2009, 09:08 PM
bimmerboy08's Avatar
bimmerboy08 bimmerboy08 is offline
Mein Auto: 1988 BMW 325i
how old is your o2 sensor?
The E30 is what all actual driving enthusiasts are after. It's an unpretentious machine, quietly capable of spectacular feats of handling. It's light, simple design is rugged enough to run against $400k rally cars, but on the street it' communicative chassis delights even the most disinterested driver. It really is one of the world's ultimate driving machines
Old 08-24-2009, 10:49 PM
Krumchev2's Avatar
Straight Bimmin
Sh!t that was one of the things the guy said might need replacing. He gave me a new one with the car. Might have to install that.
Old 08-24-2009, 11:17 PM
anstead610 anstead610 is offline
dream chasin'
Send a message via AIM to anstead610
Mein Auto: 24v e30 -88 toyota pickup
i have the cluster trim here for you. its somewhere. what other **** did the guy give you. i want free parts.
This e30 is now being parted out. NO body panels are for sale, bumpers/fenders/hood/mirrors/valance or front turn signals. Everything else is up for grabs. Euro grills/cluster are sold, suspension/brakes/LSD/rear tails are already spoken for.
Old 08-25-2009, 07:32 PM
Krumchev2's Avatar
Straight Bimmin
I replaced the O2 sensor today. The guy who had my car stripped the sh!t out of the washer on the O2 sensor so i had to use a pipe wrench to get it off but what i ended up doing was breaking it in half. So when i finally got the sensor i found that the threads inside the exhaust pipe, so i had to go buy a tap to rethread it. Then when i went to put the sensor in the wires were too short. So i had to cut sections of wire out of the old O2 sensor and solder them to the new one to make them long enough. When all said and done it took me 4 hours to do this simple task (including driving to 3 hardware stores to find the right size tap)
Old 08-25-2009, 09:08 PM
Krumchev2's Avatar
Straight Bimmin
this is what the O2 sensor looked like when i was done with it
Old 08-25-2009, 09:33 PM
jeez. hopefully that fixes it.
Old 08-25-2009, 09:49 PM
iReef's Avatar
iReef iReef is offline
7 series are the cleanest
Mein Auto: 1993 750il
hope everthing goes well, sorry to butt in but my e32 does the same thing but my light goes off around 40mphs and sometime it just cuts off n on. I know they are different cars but could this be the same thing?
Old 08-26-2009, 08:26 AM
romeomike's Avatar
romeomike romeomike is offline
Running life's race...
Mein Auto: 91 318i
Congratulations on fighting through it and gaining the victory. For the record, what was the correct size tap?
On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
Old 08-26-2009, 11:15 AM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
MY moms minitank (aka ford windstar) had the exact same issue with the O2 sensor... the tap i finally found was for sparkplugs but it worked
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 08-26-2009, 06:37 PM
Krumchev2's Avatar
Straight Bimmin
thats the tap i used too. it was for spark plugs
