E30 (1982 - 1993)
Old 08-12-2009, 11:18 PM
CrazyJew89 CrazyJew89 is offline
Send a message via AIM to CrazyJew89
Mein Auto: 1987 325is
Engine mount bracket?
So today one of the motor mount brackets on my car decided to tear itself in two. This did not seem like much of a problem until I started looking for the part and it does not seem to exist.
The bracket that comes up when you search is what I would describe as the upper bracket. Which is #2 in the picture. My broken one is the lower one which is positioned on the other side of and attached to part #7.
From what I could tell the bracket is sandwiched between the subframe cross member and the frame of the car.
Does anyone have any idea what this part would be called or where I could find one?
When I get off work I plan to start taking things apart so I can get a better idea of what the part is and maybe throw up a pic of it.
Name:	engine mount.jpg
Old 08-12-2009, 11:23 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
realoem.com
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 08-26-2009, 05:55 PM
sangeej sangeej is offline
Mein Auto: 1999 528i
i have discover that my bracket is also broken for 528I and can,t seem to find one u got any answers.
Old 08-26-2009, 09:24 PM
I found out that this is the front sub-frame. I got a friend w/ a welder to come over and used a hoist to get it into position. I also found out that this is a common problem and they make reinforcement kits. Also you can not easily get a new front sub-frame they are mostly refurbished or used.
Old 08-27-2009, 05:09 AM
downhiller's Avatar
livin large
i think that is the actual motor mount, not a bracket.
http://store.bimmerworld.com/shared/...t=products.asp
your welcome
