Hepu vs. Stewart waterpump - Bimmerfest - BMW Forums
Old 09-03-2009, 01:58 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Is that huge difference in $$$ worth it? (Stewart claims 20% more flow).
Or only for a SS application only? (the Stewart)
Thx
Old 09-03-2009, 02:03 PM
Jason5driver's Avatar
I just know that I am getting an EMP Stewart WP...
Old 09-03-2009, 07:27 PM
oembimmerparts oembimmerparts is offline
Mein Auto: 2001 Z3
On a street use only application you are paying for the peace of mind of not having it ever fall apart due to bearing failure. You will not see any advantage to the increase in flow if your car is a daily driver but as I stated you will never have to mess with the pump again( good thing if you drive a ton of miles or plan to keep the car long term)
Max
Old 09-03-2009, 08:11 PM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
I have a HEPU water pump comming Fedex Tomarrow or Monday.
Old 09-03-2009, 11:34 PM
ganesht's Avatar
ganesht ganesht is offline
(oOO)\(lll)(lll)/(OOo)
Mein Auto: 98 528i 5 speed
Max
ditto one less thing to worry about..
Alida:
Born: Friday, 9th January 1998
Arktissilber Metallic on Schwarz 528i/5
Fs: KAC-8103D, Kicker 08ts10l52
Old 09-04-2009, 05:41 AM
cn90 cn90 is offline
IMHO, Stewart Wp is way too pricey.
My philosophy is WP is like tires, after x miles, replace the WP.
An OEM BMW or HEPU WP should last at least 70-100K in a 6-cyl engine. So why try to be fancy with Stewart WP.
Plus you may sell the car way before the next WP change.
Just my 2 cents.
Old 09-04-2009, 07:38 AM
doru's Avatar
The obvious choices when changing the cooling system are:
OEM
Graf
Hepu
and/or the high performance Stewart with 20% more flow.
If the first 3 choices are pretty much the same, I would coose the cheapest one of them 3 variants - you will have to do the cooling system anyway after 80 - 100k.
The Stewart is 2 and 1/2 more pricier. My question is, if you don't have SS, would you actually benefit of running the Stewart pump? Will you increase the life of your cooling system assuming you flush it every 2 years?
As of today I still have my original cooling parts. I changed the thermostat 2 years ago (failed in the open position) and the bleeder screw (expansion tank) a few days ago. I also flush the coolant every 2 years.
So would you extend the life of the cooling system with the Stewart due to the 20% flow?
Old 09-04-2009, 08:21 AM
http://www.bimmerfest.com/forums/sho...d.php?t=247568
http://forums.bimmerforums.com/forum....php?t=1112585
Cooling System Pics
http://picasaweb.google.com/mmm635/CoolantSystemPics#
http://picasaweb.google.com/lh/photo...yoeXAAvGLkvAcw
Old 09-04-2009, 08:23 AM
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
I just had the EMP installed myself. Yeah it's over twice what the OEM waterpump is but piece of mind is priceless and it's definitely a quality unit.
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
Old 07-02-2011, 03:42 PM
junebug01 junebug01 is offline
Mein Auto: 2001 Z3 3.0i Roadste
Well kids I am a few days late, but, IMHO, the EMP Stewart water pump is the only proper replacement for your Ultimate driving machine. The others have flaws. Just like most BMW component, the EMP Stewart water pump is over engineered. I installed one in my 2000 528iT and loved the quality, fit, and finish. You get what you pay for. I am ordering one for my Z3 3.0i Roadster without reservation.$174.00...lifetime warranty..no brainer.
Old 07-02-2011, 05:46 PM
Mikes530 Mikes530 is offline
Mein Auto: 530
03 530 - A question about the Stewart pump. The web site lists only the 525 & 528 as correct applications but it also lists the 330. I'm assuming that this is a simple omission on their part and the pump will fit a 530. True or false?
Old 07-02-2011, 09:19 PM
Papabear426 Papabear426 is offline
Location: Kicking around on a piece of ground in my hometown
Mein Auto: '01 530i
I've started looking at part-cost selection in terms of the cost of a tank of gas ... 1-1/2 tanks of gas (extra) for a lifetime warranty? Put one in mine with Evans, and have high hopes of going way beyond (like 2x) 80-100K miles on this setup. Peace of mind.
Old 07-03-2011, 12:13 AM
By way of cross reference ...
- What brand of waterpump to buy (1)
