Old 09-02-2009, 02:15 PM
H2O SKI H2O SKI is offline
Mein Auto: 2007 X3si
basic navi question
How do I make the checkered flag go away?
Used the destination guide only once to see if it actually works, now there's a checkered flag at that point which won't go away.
Tried the press "menu" twice in rapid succession as it states in the manual, this did nothing.
help...
Old 09-02-2009, 03:03 PM
Tolland Mark Tolland Mark is offline
Mein Auto: '09 X3
help...
Try this:
Activate the nave to the current destination by selecting directions.
Press right button and select information.
Select hide icons.
Hope that works
Old 09-10-2009, 11:44 AM
Apparently I'm the only one on the planet with this issue.
Update:
Hiding icons did not work.
While at dealer, had them try and figure this out. No less than five different people, including two techs attempted to fix the problem. One even removed the nav cd and reinstalled, that didn't work either.
Their solution is to remove the batter and reset the electronics. Told them I don't want to do that considering the various problems others have posted concerning battery related issues. Also stated I didn't want my transmission to start its recalibration method over again, as I don't have any of the nasty tranny issues associated with the '07 X3, except for the strange way it slows down.
They also say if I enter a new destination it will most likely remove the existing checkered flag and replace it at the new destination. I said, "most likely: Or, it could just keep adding checkered flags all over the place." They agreed this could happen.
So, if any of you have any ideas they would be much appreciated.
In the long run it's not a huge issue as I don't need the nav. Just get tired of seeing that flag every time I turn it on.
Old 09-10-2009, 03:30 PM
Mein Auto: '09 X3
I tested mine this past week and confirmed that the flag shows the last destination that was activated and can't be cleared manually.
It doesn't really bother me but a work around would probably be to add to your address book a destination far from you (ie NYC), activate it then terminate the guidance and the flag will show up there and not on your local map. Of course, if you enter a local destination after that, the flag shows up there but at least you can activate the NYC address to keep it out of view in the future.
My 2002 325 with nav didn't have the flag feature but used a dot which was cleared automatically after the destination was reached and the car shut off. Sounds like another programming oversight by BMW.
